Data rejestracji: 31.08.2005
Problem z The FilmMachine, pilne prosze!
Nie znam sie bardzo ale przy konwersji TFM włacza mi sie CCE i chce kodowac czy cos takiego (Encode). Plik kodowanie jak mi sie wydaje wskazuje TFM_Project_File.ecl z katalogu TFM, niewiem czy dobrze robie. Natomiast prog CCE wyswietla mi "TFM_Project_File.ecl is not for CCE SP Trial Wersion". I to koniec konwersji. Co robie nie tak, czy to wina CCE
![]() Prosze o odpowiedz. |
| #ads | |
- 2005-09-01 16:51:41 - AVI to DVD conversion - The FilmMachine version 1.5.0.11 beta -------------------------------------------------------- Initializing. Computer Info CPU name : Pentium 4 Available memory: 256 MB Windows version : Microsoft Windows XP Initializing finished. DirectX Version = 9.0c Saving Avi-Info files -------------------------------------------------------- - 2005-09-01 16:51:44 - Free on drive D: 11,89 GB - Creating and Merging Subtitles -------------------------------------------------------- Writing D:\= FILMY =\DivxToDvd\TFM_Subtitle_File.srt Saving D:\= FILMY =\DivxToDvd\TFM_Subtitle_File.srt -------------------------------------------------------- - 2005-09-01 16:51:45 - Free on drive D: 11,89 GB - Audio Conversion -------------------------------------------------------- Executing BeSweet DLL. Commandline: -boost( /b2=5 ) -ota( -fs 48000 ) -ac3enc( -b 224 ) Converting audio of AVI file no 1 - 1 DirectShow messages: DirectShow Filters used: NullRenderer1 NullRenderer SampleGrabber AC3Filter ffdshow Audio Decoder AVI Splitter Avisynth Source Filter Audio conversion finished. Starting CCE 2.70 for getting the CCE title. -------------------------------------------------------- - 2005-09-01 17:21:24 - Free on drive D: 11,76 GB - Video Encoding using Cinema Craft Encoder SP 2.70 -------------------------------------------------------- Executing Cinema Craft Encoder. TFM_Project_File.ecl found TFM_Project_File.ecl encoding started at 17:21:24 TFM_Project_File.ecl encoded at 17:21:34 Encoding finished -------------------------------------------------------- - 2005-09-01 17:21:37 - Free on drive D: 11,76 GB - Creating DVD compliant files -------------------------------------------------------- Mplex is multiplexing the video and audio stream..... mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $) Multiplexing finished. Spumux is inserting subtitles in the videostream..... cannot open D:/_FILMY~1/DIVXTO~1/TFM_Muxed_Video.mpg: no such file Inserting subtitle into DVD stream finished. DVDAuthor is writing the VOB files..... DVDAuthor::dvdauthor, version 0.6.11. Build options: gnugetopt magick iconv freetype fribidi Send bugs to <dvdauthor-users@lists.sourceforge.net> INFO: Locale=C INFO: Converting filenames to US-ASCII INFO: dvdauthor creating VTS ERR: Error opening D:\_FILMY~1\DIVXTO~1\TFM_Subbed_Video.mpg: No such file or directory Writing VOB files finished. Finished authoring DVD -------------------------------------------------------- - 2005-09-01 17:21:57 - Free on drive D: 11,76 GB - Creating DVD Image -------------------------------------------------------- MKISofs is writing the DVD Image file..... Total translation table size: 0 Total rockridge attributes bytes: 0 Total directory bytes: 4248 Path table size(bytes): 42 Max brk space used 3000 423 extents written (0 Mb) Writing DVD Image finished. -------------------------------------------------------- - 2005-09-01 17:22:02 - Free on drive D: 11,76 GB - DVD creation finished! -------------------------------------------------------- Tyle mi sie wyswietla w komunikatach TFM a potem sie wlacza CCE. Co robic Ostatnio zmieniany przez sakary : 01.09.2005 o godz. 19:18 |
#3 | |
Nie jestem specjalistą od TFM, ale rozwiązanie twojego problemu zawarte jest chyba w twoim pierwszym poście:
Juz stracilem cierpliwosc. Przerabial mi caly dzien a na koncu jakby sie zawiesil zatrzymal sie na 100% ale poinformowal ze napisy sa wklejone ja tu patrze a on zrobil duzo plikow tyle ze zaden Mpg po wlaczeniu nie wlacza napisow. Ma ktos recepte na to a moze jest instrukcja do TFM? I nie ma w dodatku takiego pliku z dwoma zerami na koncu, poradzcie cos prosze.
