-   Propozycje, sugestie, błędy forum (https://forum.cdrinfo.pl/f10/)
-   -   Zdublowane posty na Chromium (https://forum.cdrinfo.pl/f10/zdublowane-posty-chromium-93973/)
andy 23.11.2014 23:11
Oczywiście że z nudów..
Co ciekawe okno miałem otwarte kilka minut zanim puściłem posta. Może tu jest problem?
@mgit to nie winda Debiana tylko co najwyżej Chromium.
szczuru 23.11.2014 23:09
Teraz znów jest problem czy z nudów dwa razy wysłałeś? :D
mgit 23.11.2014 23:08
To że Ubuntu bazuje to żadna nowość - ale może coś tam poprawili - dorzucili od siebie.
Mowa tutaj o czystym debianie - a nie żadnych pochodnych ...
andy 23.11.2014 23:05
A mi się zdaje że to wina: Debian sid/unstable
3.1 Which Debian distribution (stable/testing/unstable) is better for me?
The answer is a bit complicated. It really depends on what you intend to do. One solution would be to ask a friend who runs Debian. But that does not mean that you cannot make an independent decision. In fact, you should be able to decide once you complete reading this chapter.
If security or stability are at all important for you: install stable. period. This is the most preferred way.
If you are a new user installing to a desktop machine, start with stable. Some of the software is quite old, but it's the least buggy environment to work in. You can easily switch to the more modern unstable (or testing) once you are a little more confident.
If you are a desktop user with a lot of experience in the operating system and does not mind facing the odd bug now and then, or even full system breakage, use unstable. It has all the latest and greatest software, and bugs are usually fixed swiftly.
If you are running a server, especially one that has strong stability requirements or is exposed to the Internet, install stable. This is by far the strongest and safest choice.
The following questions (hopefully) provide more detail on these choices. After reading this whole FAQ, if you still could not make a decision, stick with the stable distribution.
btw,
Ubuntu bazuje na unstable a LTS na testing o ile się nie mylę ;)
Problem raczej nie dotyczy Debiana bo na lisku było ok. Może to problem Chromium/Chrome?
btw,
mgit 23.11.2014 22:49
Też mam jeden (no dobra prawie dwa komputery jeśli liczyć RaspberryPi) komputer z debianem - ale edycja stable i tam jest wszystko ok
grzeniu 23.11.2014 22:42
Wiedziałem że tak będzie :rotfl:
joujoujou 23.11.2014 22:42
Napisany przez grzeniu (Post 1302198)
Chyba nie ma? Widzę, że nauczyłeś się wysyłać po jednym poscie :D
Jak mu zagroziłeś że zasadzisz to problem magicznie znikł. :D
andy 23.11.2014 22:41
No czasami jest normalnie...
grzeniu 23.11.2014 22:41
joujoujou 23.11.2014 22:40
Ale to nie jest ich wina. :P
andy 23.11.2014 22:40
Wy tu pitu-pitu o dupier maryni a problem jak był tak jest :/
grzeniu 23.11.2014 22:06
Łeno to ty jeszcze nie wiesz, co jest najlepszego w tym forum :O
Włącz na cdrinfo stary hires! To forum zawsze takie było i zawsze takie ma być k***a
misiozol 23.11.2014 21:39
Nie mam bladego pojecia , zapewne domyslnego wszystko ladnie niebieskie .
Pod opcja "styl forum" mam uzyj domyslnego .
andy 23.11.2014 21:26
Jakiego stylu forum...
Wszystkie czasy w strefie CET. Aktualna godzina: 11:56.
