| Dyski twarde, SSD - Problemy, porady, software Tematy dotyczące problemów, porad i oprogramowania przeznaczonego dla dysków twardych oraz SSD. |
logged out
Data rejestracji: 12.07.2003
Nietypowy problem z dyskiem Seagate Momentus SpinPoint M8 na akumulatorze
Od jakiegoś*czasu mam dziwny problem z dyskiem:
Seagate Momentus SpinPoint M8 (AF) Na zasilaniu z baterii (na zasilaczu ten problem nie występuje) co jakiś czas (~1 minuty) słychać jakby start dysku. Czym to może być spowodowane? Poniżej odczyt parametrów systemu SMART: Kod:
andy@nabuchodonozor:~$ sudo smartctl --all /dev/sda
smartctl 6.4 2014-10-07 r4002 [x86_64-linux-3.16.0-4-amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Momentus SpinPoint M8 (AF)
Device Model: ST1000LM024 HN-M101MBB
Serial Number: S2WZJ90C668426
LU WWN Device Id: 5 0004cf 207c30e73
Firmware Version: 2AR20002
User Capacity: 1,000,204,886,016 bytes [1,00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.0, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Apr 6 22:38:45 2015 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (12480) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 208) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 19
2 Throughput_Performance 0x0026 252 252 000 Old_age Always - 0
3 Spin_Up_Time 0x0023 089 089 025 Pre-fail Always - 3461
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3200
5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0
8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 8228
10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 173
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2513
13 Read_Soft_Error_Rate 0x003a 100 100 000 Old_age Always - 0
181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 2214379
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 71
192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 092 092 000 Old_age Always - 89433
194 Temperature_Celsius 0x0002 059 036 000 Old_age Always - 41 (Min/Max 19/67)
195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 24
240 Head_Flying_Hours 0x0032 100 100 000 Old_age Always - 7935
241 Total_LBAs_Written 0x0032 093 089 000 Old_age Always - 10125625
242 Total_LBAs_Read 0x0032 092 088 000 Old_age Always - 12040309
254 Free_Fall_Sensor 0x0032 252 252 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 3920 -
# 2 Short offline Aborted by host 80% 3920 -
# 3 Short offline Interrupted (host reset) 90% 572 -
# 4 Extended offline Interrupted (host reset) 90% 80 -
# 5 Short offline Completed without error 00% 80 -
# 6 Short offline Completed without error 00% 80 -
# 7 Short offline Completed without error 00% 14 -
# 8 Short offline Completed without error 00% 14 -
# 9 Short offline Completed without error 00% 12 -
#10 Short offline Completed without error 00% 1 -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Completed [00% left] (0-65535)
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
#2 | |
Data rejestracji: 06.12.2005
To nic nie da jak fw dysku na to nie pozwoli.
Mam taki HDD w notebooku i trzeba z tym po prostu żyć... Choć u mnie cyka zawsze, bez względu na to czy to z baterii czy z kabla (zresztą tego HDD przecież wiedzieć nie może). Nie odsłuchiwałem materiału Andy'ego ponieważ DB wymaga js, a ja tego bardzo nie lubię.
Wszystko co chciałbyś wiedzieć o: | PSX | PS2 | PS3 | Xbox | FF000000000003010101010003010000000003010000030000 00000003010000000003010100000003010101010003010000 00000300010101010300000000000301010000000300000001 01030101010100030101000000030000000000030100000000 03000001010103000000000003010100000003000000000103 01000000000301010000000301010000000300000000000301 01010100030000000000030101000000030000000001030003 01000000000301000000030100000000030000000101030100 00000003010000030100000000030100010003010100000003 00000000000300000000000300010301000000000301000003 00000001010301010100000301010000000300000000000301 00000000030000000101030000000001030101000000030101 000000030101000000FF Ostatnio zmieniany przez Berion : 07.04.2015 o godz. 00:09 |
to w takim razie ile masz już Load_Cycle_Count? Fakt czasem nie można wyłączyć ale można ograniczyć do minimum, 254 wyłącza całkowicie.
A ja bym podszedl z innej strony zauwazyl ktos ze dysk tego NIE robi gdy jest na zasilaczu ? ile ma akumulator pojemnosci moze stracil pojemnosc i dysk nie trzyma parametrow i cofa glowice bo uznaje spadek napiecia za probe wylaczenia ?
@revolver0
Kilkanaście tysięcy. Sam dźwięk mnie wkurza, więc chyba tam jakiś SSD wstawię. Nie, to zależy od fw dysku, nie na każdym możesz coś takiego zrobić.
logged out
Jeżeli chodzi o baterię to:
Kod:
andy@nabuchodonozor:~$ upower -i /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: SDI
model: PABAS0241231
serial: 41167
power supply: yes
updated: śro, 8 kwi 2015, 05:26:38 (16 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 37,71 Wh
energy-empty: 0 Wh
energy-full: 38,84 Wh
energy-full-design: 48,84 Wh
energy-rate: 13,159 W
voltage: 12,162 V
time to empty: 2,9 hours
percentage: 97%
capacity: 79,525%
technology: lithium-ion
icon-name: 'battery-full-symbolic'
History (charge):
1428463598 97,000 discharging
History (rate):
1428463598 13,159 discharging
Kod:
andy@nabuchodonozor:~$ sudo hdparm -B 250 /dev/sda /dev/sda: setting Advanced Power Management level to 0xfa (250) APM_level = 250 Czy restart systemu jest wymagany, bo jakoś nie zauważyłem zmian...
logged out
To samo co przez hdparm zmieniłem również w GNOME disk utility i lapka wyłączyłem.
Jak przyjdę, to zerknę czy coś pomogło. |
Ty wez mi cos powiedz bo ja juz nie kumam , czy to jest dysk z wbudowanym akumulatorem czy to sie dzieje kiedy laptop jest na akumulatorze , bo sie pogubilem napiecia i pojemnosci mi sugeruja ze to laptop ?
logged out
Tak to laptop i problem jest wtedy kiedy pracuje na baterii.
#11 |
A to zmienia postac zeczy
, z tego co mi sie wydaje to laptop wysyla sygnal o oszczedzanie energi do dysku i dysk zwariowal , zobatrz czy jest nowszy FW do niego . Nie masz jakis dziwnych dodatkow poinstalowanych ? Odpal jakis system z cd czy usb i zobatrz czy bedzie to samo .
#12 |
logged out
Sprawdziłem jeszcze laptop-mode-tools, ponieważ z automatu mi tym sterował - niestety zmiana na wartość 254 czy 255 (off) nie daje rezultatu.
Dalej mam problem z dyskiem podczas pracy laptopa na baterii - na zasilaczu z dyskiem i bez problem nie występuje. Jakieś sugestie? P.S. Sprawdzę jeszcze na Windowsie 7 jednak boje się że tam będzie ok i problem jest z konfigurację Debry, bo kiedyś*u mnie ten problem nie występował.
| Polskie Radio BIS upadło - Czyli cenzure w Polsce czas zacząć... | Qbi@k | Off topic | 73 | 03.10.2013 18:16 |
| Problem z dyskiem SEAGATE 7200.11 320gb (z NCQ i czasem dostepu) | ricko11 | Dyski twarde, SSD - Problemy, porady, software | 2 | 24.12.2008 12:43 |
| Problem z konwersją DTS(5.1) na AC3(5.1)....[troche inny] | grafit | DVD-Video | 1 | 16.12.2006 15:22 |
| Problem z odczytem na stacjonarnym DVD i jaka wybrac nagrywarke ? | Adam_K | DVD-Video | 0 | 07.11.2004 17:49 |
