Stary 11.08.2010, 10:07   #1
andrzej5rn
Data rejestracji: 11.08.2010
andrzej5rn w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
XBOX360 Emulator - problem
Witajcie. Kupilem pod komputer pada
SPEEDLINK XBOX 360 STYLE GAMEPAD i mam problem z konfiguracja emulatora a problem tkwi w LT i RT
[PAD1]
Index=0 #controller index in game controllers list; 0 is first; -1 to ignore this pad
Left Analog X=1 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Left Analog Y=-2 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog X=6 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog Y=-3 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Left Analog X Linear=0 #-100 to +100 raise this number to increase sensitivity near center
Left Analog Y Linear=0 #-100 to +100 raise this number to increase sensitivity near center
Right Analog X Linear=0 #-100 to +100 raise this number to increase sensitivity near center
Right Analog Y Linear=0 #-100 to +100 raise this number to increase sensitivity near center
Left Analog X+ Button=0 #button id; 0 to disable
Left Analog X- Button=0 #button id; 0 to disable
Left Analog Y+ Button=0 #button id; 0 to disable
Left Analog Y- Button=0 #button id; 0 to disable
Right Analog X+ Button=0 #button id; 0 to disable
Right Analog X- Button=0 #button id; 0 to disable
Right Analog Y+ Button=0 #button id; 0 to disable
Right Analog Y- Button=0 #button id; 0 to disable
D-pad POV=1 #POV index; 0 to disable
D-pad Up=0 #button id; 0 to disable
D-pad Down=0 #button id; 0 to disable
D-pad Left=0 #button id; 0 to disable
D-pad Right=0 #button id; 0 to disable
A=1 #button id; 0 to disable
B=2 #button id; 0 to disable
X=3 #button id; 0 to disable
Y=4 #button id; 0 to disable
Left Shoulder=5 #button id; 0 to disable
Right Shoulder=6 #button id; 0 to disable
Back=7 #button id; 0 to disable
Start=8 #button id; 0 to disable
Left Thumb=9 #button id; 0 to disable
Right Thumb=10 #button id; 0 to disable
Left Trigger=s1 #button id; precede with 'a' for an axis; eg; a-6; for a slider precede with 's' eg; s-1
Right Trigger=s #button id; precede with 'a' for an axis; eg; a-6; for a slider precede with 's' eg; s-1
UseForceFeedback=0 #use 0 to 1; default 0
ForceLargeGain=10000 #use 0 to 10000; default 10000; effect intensity
ForceLargePeriod=120000 #use 0 to 200000; default 120000; effect frequency; wheel only
ForceLargeFadeTime=10 #use 0 to 100; default 10
ForceLargeFadeIn=0 #use 0 to 1; default 1
ForceLargeFadeOut=0 #use 0 to 1; default 1
ForceLargeStartMag=0 #use 0 to 10000; default 2000; effect will begin with this value
ForceSmallGain=10000 #use 0 to 10000; default 10000; effect intensity
ForceSmallPeriod=30000 #use 0 to 200000; default 30000; effect frequency; wheel only
ForceSmallFadeTime=10 #use 0 to 100 default 10
ForceSmallFadeIn=0 #use 0 to 1; default 1
ForceSmallFadeOut=0 #use 0 to 1; default 1
ForceSmallStartMag=0 #use 0 to 10000; default 2000; effect will begin with this value
WheelInertiaGain=2500 #use 0 to 10000; default 2500; effect intensity; wheel only
WheelSpringGain=5000 #use 0 to 10000; default 5000; effect intensity; wheel only
SteeringWheel=0 #use 0 to 1; enable for all wheel effects
CHODZI MI O LEFT TRIGGER i RIGHT TRIGGER JAK SKONFIGUROWAC BY CELOWAC NP LT a STRZELAC RT PROSZE O POMOC
andrzej5rn jest offline   Odpowiedz cytując ten post
[Sprzedam] Guitar Hero III Legends of Rock XBOX360 Bundle Pack kiewas Kupię/Sprzedam/Zamienię 0 02.11.2008 21:08
Xbox360 - kabel VGA a monitory CRT kiru25 Hardware 2 06.08.2008 00:39
Xbox360, a HP 940 nestor113 Nagrywanie/kopiowanie gier na konsole 12 10.04.2007 20:09
Fractal modchip - xbox360 chris996 Hardware 3 02.11.2006 11:09
Wszystkie czasy w strefie CET. Aktualna godzina: 08:17.
