Stary 16.09.2012, 00:03   #1
arcade
Avatar użytkownika arcade
Data rejestracji: 08.09.2010
Lokalizacja: na koncu drogi mlecznej na zadupiu zwanym Earth
arcade zaczyna zdobywać reputację <1 - 49 pkt>
Czas na opylenie czarnego klocka
Siemaneczko sektor.
Nadszedł czas na opylenie czarnuli po jeszcze mozliwie dobrej cenie ,bo na choryzącie czeka nowe pokolenie Wii U sie zwie.
CPU
IBM Power***174;-based multi-core processor
GPU
AMD Radeon***8482;-based High Definition GPU.
Price
$299.99 for Basic Set / $349.99 for Deluxe Set
Europa preis
>>http://www.idealo.de/preisvergleich/...-nintendo.html
Pełna specyfikacja >>
The Wii U CPU is based on IMB***8217;s latest PowerPC technology, the POWER7 architecture. The processor will use most of the modern features from POWER7, including multi-threading and power saving controls. The Wii U CPU speed is estimated to be at 3 GHz by developers who have access to dev kits. The processor is the key part in the Wii U system specs, which include a Wii U GPU from AMD, and an unspecified amount of RAM. According to reports obtained by Wii U Daily, the console will use a processor based on the ***8220;IBM 710 Express***8221;, but will be heavily modified to suit the needs of the console and video game software.
Wii U CPU specs
The Wii U CPU uses most of the features from the POWER7 architecture, the rumored and leaked specs so far indicate:
  • 4 CPU Cores and 2 MB shared L3 cache
  • 3 GHz clock speed
  • Multi-threading: 4 threads per core, 16 threads in total
  • 45 nm process
  • Advanced power savings features and design
  • 256 KB L2 cache per core
The processor of course includes a whole slew of additional features, but the main attribute is the addition of multi-threading: the Wii U CPU can handle up to 16 threads at the same time. Compared to the older Xbox 360 chip, which can only run 6 threads at a time, the new chip is much more capable when it comes to multi-threading and simultaneous executions of code. Production of the Wii U processor will take place at IBM***8217;s facility in New York, USA, while the final console and components will be assembled in China and shipped worldwide.
Wii U CPU power and performance
The power output of the Wii U CPU The IBM Power7 architecture is rated at maximum 33 GFLOPS(Giga FLOPS) per core with the full amount of cache available at max clock speed. Per CPU, the maximum performance output is over 260 GFLOPS, albeit this is based on a fully specced out 8 core chip at 4 GHz. Realistically, the Wii U CPU power output could be at around 50 GFLOPS, with 4 cores at 3 GHz. This would make the Wii U CPU over 20 times faster than the old Wii Broadway processor, and twice as fast as the PlayStation 3 Cell processor, and 2.5X as fast as the Xbox 360 chip.
Czyli mówiąc szczerze jeśli masz PS3 na CFW to ostatni dzwonek aby sprzedać i miec z tego kase na sprzęt nowej generacji .
http://www.insertcoinslv.com/ Strzeż tajemnicy państwowej ,Zwalczajcie stonke ziemniaczaną!
czekej leszczu przejda ci levela
http://www.w2comp.com/catalog.asp?catid=95388
INSERT COIN
http://www.baidu.com/
http://v.youku.com/v_show/id_XNTMyMDI3Mg==.html
flashocholic
arcade jest offline   Odpowiedz cytując ten post
Stary 16.09.2012, 00:13   #2
M@X
Get a Mac!
Avatar użytkownika M@X
Data rejestracji: 18.04.2003
Oby nastepca byl godny, czyli dawal tyle zabawy na ile pozwala elektronika :-)! Bo cala reszta konkurencji imponuje tylko i wylacznie grafika. A nudy tam co nie miara...
Stary 16.09.2012, 00:20   #3
arcade
Patrząc na specyfikacje to po prostu miazdzy a i tak jest o 50% zajechana w dół ze wzgledu na oszczędność pradu!.
INSERT COIN
flashocholic
Ostatnio zmieniany przez arcade : 16.09.2012 o godz. 00:23
Stary 16.09.2012, 00:26   #4
Nigdy nie rozumiałem ludzi, którzy sprzedają swoje konsole...
A jeśli czekasz na hacki konsol tylko po to aby wrzucić tam Pingwina to lepszym rozwiązaniem jest HTPC.
Stary 16.09.2012, 00:53   #5
arcade
Ps3 kupiłem bo jak fama niosła ze Cell/Be to taki szybki i bijący pecety procek ze hoho.
Swego czasu za 5 euro kupiłem "HP Compaq t5300 Thin Client (with TM5600 533 MHz)"
Miał tylko 64mb ram z czego połowa to firmware zabierało a reszte zajmował system np. thinyCore - który tam wgrałem , i wyobraz sobie ze video 720p leci na tych paru mb bez problemu ,firefox tez a dla czego na cell-u nie.
Według mnie to po prostu pierwsza i bardzo nie udana konstrukcja była i dla tego nie smiga tak jak powinna ,za Cell-a nadgania GPU i dla tego jest taka kicha jesli idzie o gry na ps3 z czym nieraz twórcy mówili ze nie które tytuły nie da sie na tym zrobić w takie krasie jakiej by chcieli.
A co do grania to w ogóle nie rzne w gry typu popatrz na ładny filmik i obojętnie co bedziesz naciskał na padzie i tak dojdziesz szczęsliwie do końca.
Na co mam czekac jesli sam moge to robic na czym chce?
Pytanko edycja postu nie działa jak zedytuje to mi posta kasuje nie moge nic zmienic.
ps. usun to po zbadaniu problemu.
Dla czego tego pista da sie a te wyzej nie?.
"Kupie Wii U tez dla tego ze za te 300 stówy nie kupisz pc o takiej mocy , a po zatym to moje hobby wgrac linuxa chociaz by na pralkę Frania!!
Edycja juz tez nie działa ok ide na browara.
Napisany przez arcade Podgląd Wiadomości
Sorka nie beda wam tu trolił edycja działa jak sie wyloguje i prubóje napisać nie zalogowany .
"ostatnie zdanie wyszła nowa wersia RedRibbon czy zauwazyliscie ze nie ma zadnego patch-a od gleva czemu
INSERT COIN
flashocholic
Ostatnio zmieniany przez Berion : 16.09.2012 o godz. 20:08 Powód: //qp, skasuj ciastka.
Stary 16.09.2012, 05:31   #6
pali
Թ
Avatar użytkownika pali
Data rejestracji: 14.02.2003
Też czekam aż Wii U pojawi się na choryzącie i sprzedaję ómywalkę.
Stary 17.09.2012, 07:38   #7
sobrus
Jukebox Hero
Avatar użytkownika sobrus
Data rejestracji: 17.09.2004
PS3 to troche techniczny gniot, każdy o tym wie.
Cell nie jest udaną konstrukcją i już nie jest rozwijany.
X360 jest lepszą konstrukcją w zasadzie pod każdym względem.
A film leci na t5300 ze względu na sprzętowy dekoder wideo.
Bardzo możliwe że Wii będzie najmocniejszą konsolą nowej generacji.
PS4 i X720 (jakkolwiek się bedą nazywać) bazować będą z tego co wiem na energooszczędnych APU od AMD.
Choć pewnie nie na tym samym modelu.
Zależy jak bardzo wykastrują oryginalnego powera.
Ale czy Wii U miażdży? Jeżeli będzie tylko 2-3 razy szybsze od X360 - to po 7 latach to jest naprawdę kiepski wynik.
Nie robiłbym sobie nadziei co do budowy taniego superkomputera. Linuksa pewnie zainstalować się nie da, a 1GB RAM dostępnego RAM to dziś stanowczo za mało.
Specyfikacje wszystkich next genów niestety rozczarowują. Miejmy nadzieję, że przynajmniej będą TANIE.
Ostatnio zmieniany przez sobrus : 17.09.2012 o godz. 07:57
Śmieszne teksty... MacGyver Humor 4413 07.12.2024 17:39
Chuck Norris Morris Humor 111 07.10.2018 02:42
Czas filmu przy kodowaniu na real (rmvb) zmienia się seul1988 DivX, Xvid, Matroska i inne 0 28.12.2004 13:20
Wszystkie czasy w strefie CET. Aktualna godzina: 01:40.
