Odtwarzacze multimedialne na PS3
Moze troszke sie rozpedzilem z ta liczba mnoga w temacie ale chyba cos sie ruszylo w tym temacie i raczej napewno na tej jednej aplikacji nie poprzestanie a wiec zakladam.
Zapowiada sie ZAJEFISCIE !!! MKV comming for ya !! ;> I jeszcze [B]PS3 usage guide Getting Started Download the files from here:download Full featureset see:This Most of this should work except for playback of high res. HD videos (basically when the PPU runs out of cycles). There are some methods of fixing them, but no one knows yet. I will update it when they do. Video output This has been tested with 576i, 720p and 1080i video resolutions. People have tried to set reasonable defaults for overscan compensation. But if it not correct for you it can be adjusted under Settings -> Display and UI settings Buttons on controller (Controls) ***10005; Enter current item ***9675; Go back (exit) ***9651; Show options / playcontrol menu ***9633; Screensaver (Until something better has been figured out) ***9658; Play/Pause ***9644; Home menu ***10012; Navigate it L3 ***8211; Get playback info (During video playback) R3 ***8211; Get log console Keyboard -The only current way to input characters is by using a standard keyboard. - Virtual keyboards are supported at the moment. Things that do NOT work -TV-style remote controller has not been tested. No idea if it works or not. -BD/DVD/CD Discs ***8211; No idea how that works -Digital pass thru audio (AC3, DTS, etc) |
| Wszystkie czasy w strefie CET. Aktualna godzina: 03:14. |
