Data rejestracji: 21.07.2023
Which burning drive to use for the best quality recording on BD-RE DL media?
Hello everyone,
I have a Liteon IHBS212 burn drive changed (CrossFlash) to a Plextor PX-LB950SA. I tried burning on Panasonic BD-RE DL rewritable media (50GB) and everything was fine, but when using SONY BD-RE DL and Verbatim BD-RE DL media, the quality measurement results in the second recording layer are bad. My question is: What other drive can I use to get better results when burning to BD-RE DL SONY and Verbatim rewritable media? If it were about drive with the ability to measure the quality of the LDC/BIS recording, it would of course be better. Thank you... ![]() Pics: Verbatim BD-RE DL ![]() SONY BD-RE DL ![]() Panasonic BD-RE DL
Odnowiony Cyfrowo
Data rejestracji: 23.05.2006
Hello,
this is quite an old but good drive,record X2 speed.I would stick with Verbatim |
Data rejestracji: 09.12.2025
Use 2x or 4x low-speed burning of your SONY/Verbatim BD-RE DL disc in the existing drive, and then perform a quality scan again. If the quality improves significantly, it indicates that the problem is a mismatch between the writing strategy and high-speed burning.
| Tagi |
| bd-re, burning, dl, drive, media, quality, recording |
