Stary 09.03.2017, 08:58   #1
Pioneer BDR-PR1EPDV 2013r
Dzięki ogromnej uprzejmości @wujooj za co mu niezmiernie dziękuje
Stary 09.03.2017, 13:42   #2
EMTEC CD-RW CMC Tajwan ATIP: 97m26s65f
Pioneer BDR-PR1EPDV fw.1.00
ImgBurn 2.5.8.0 x10
Stary 10.03.2017, 08:18   #3
Aktualizacja do najnowszego firmware fw.1.01 -DVRTool
Stary 16.03.2017, 16:36   #4
PlexDisc DVD-R Printable Termal MID : OPTODISCR016
Pioneer BDR-PR1EPDV fw.1.01
ImgBurn 2.5.8.0 x6
Stary 16.03.2017, 16:39   #5
PlexDisc CD-R Printable Inkjet Matt CMC Magnetic 97m26s66f
ImgBurn 2.5.8.0 x16
Stary 16.03.2017, 16:42   #6
PlexDisc CD-R Printable Liquid Defense Plus Ritek 97m15s17f
ImgBurn 2.5.8.0 x4
Stary 17.03.2017, 13:16   #7
CMC Pro-Primera CD-R TuffCoat 97m24s01f
ImgBurn 2.5.8.0 x10
Stary 17.03.2017, 15:20   #8
CMC Pro-Primera DVD-R TuffCoat Printable MID TYG03
ImgBurn 2.5.8.0 x6
Stary 03.04.2017, 14:55   #9
Philips CD-R x52 CMC 97m26s66f Made in Tajwan
ImgBurn 2.5.8.0 x24
Stary 05.04.2017, 05:01   #10
MediaRange CD-R x52 Plasmon 97m27s18f
NERO 2017 x10
Jestem w lekkim szoku co Pionek +Nero zrobiły z tym nośnikiem
Znaczek PR1 nie od parady ...
log :
Kod:
Windows 8 6.2
AMD64
Wow64Process
Nero Version: 18.0.15.0
Internal Version: 18,0,15,0
Recorder         : <PIONEER BDR-PR1EPDVPP100>     FW version: 1.01 - HA 1 TA 1 - 18.0.15.0
 Device bus      :  <>                            HA 1
 Host system bus :  <USB 2>
 Drive buffer    :  4000kB
 Bus Type        :  via Inquiry data
 Connected to MMC as unknown drive with class-nr : 1
 Drive is autodetected - recorder class: Std. MMC recorder
CD/DVD-ROM       : <HL-DT-ST DVDRAM GT30N    >    FW version: 1.01 - HA 1 TA 0 - 18.0.15.0
 Host system bus :  <IDE>
=== Scsi-Device-Map ===
DiskPeripheral       : KINGSTON SV300S37A120G          iaStor Port 0 ID 0  DMA: On
DiskPeripheral       : WDC WD7500BPKX-75HPJT0          iaStor Port 0 ID 1  DMA: Off
CdRomPeripheral      : HL-DT-ST DVDRAM GT30N           iaStor Port 0 ID 2  DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GT30N      D:   CdRom0
PIONEER BDR-PR1EPDVPP100   F:   CdRom1
AutoRun : 0
Excluded drive IDs:
BUFE           : 0
Physical memory     : 4090MB (4189108kB)
Free physical memory: 1849MB (1893848kB)
Memory in use       : 54 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
1.4.2017
Obraz dysku
09:09:41	#1 Text 0 File SCSIPTICommands.cpp, Line 617
09:09:41	#2 Text 0 File Burncd.cpp, Line 3723
	Włączono System ochrony zapisu
09:09:41	#3 PHASE 214 File dlgbrnst.cpp, Line 2108
	Generation of disc structures started
09:09:41	#4 IMAGEGEN -10 File ImageGen.cpp, Line 400
	Image was written as DAO.
	DAOI:
	 MediaCatalogNumber = '             '
	 TocType = 0x00
	 Finalized =  1
	 First/Last Track =  1 / 14
	  1: ISRC = ''
	     Blocksize = 2352
	     TrackMode = 'TRM_AUDIO_NOPRE'
	     TrackConfig = 0x00
	     First/Last Index =  0 /  1
	     Index0FilePos = 0, Index1FilePos = 352800, NextTrackFilePos = 32732784
	  2: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 32732784, Index1FilePos = 33085584, NextTrackFilePos = 59719632
	  3: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 59719632, Index1FilePos = 60072432, NextTrackFilePos = 97097616
	  4: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 97097616, Index1FilePos = 97450416, NextTrackFilePos = 130493664
	  5: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 130493664, Index1FilePos = 130846464, NextTrackFilePos = 185575152
	  6: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 185575152, Index1FilePos = 185927952, NextTrackFilePos = 231422688
	  7: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 231422688, Index1FilePos = 231775488, NextTrackFilePos = 280000896
	  8: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 280000896, Index1FilePos = 280353696, NextTrackFilePos = 325566192
	  9: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 325566192, Index1FilePos = 325918992, NextTrackFilePos = 369343968
	 10: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 369343968, Index1FilePos = 369696768, NextTrackFilePos = 431728416
	 11: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 431728416, Index1FilePos = 432081216, NextTrackFilePos = 503476176
	 12: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 503476176, Index1FilePos = 503828976, NextTrackFilePos = 615934704
	 13: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 615934704, Index1FilePos = 616287504, NextTrackFilePos = 678074544
	 14: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 678074544, Index1FilePos = 678427344, NextTrackFilePos = 814144800
	CUES:
	   0: Ctrl=0x01 Trk=  0 (0x00) Index=00 Start=954437:08.46 (     -150) RecDep=0x00
	   1: Ctrl=0x00 Trk=  0 (0x00) Index=138 Start=123105:47.39 (553976064) RecDep=0x24 [open track]
	   2: Ctrl=0x21 Trk= 10 (0x10) Index=00 Start=34:51.59 (   156884) RecDep=0x00
	MTYP: Mediumtype =  CD (old format) (0x1)
	Image file name: <C:\Users\czary2mary\Desktop\Image.nrg>
09:09:42	#5 PHASE 215 File dlgbrnst.cpp, Line 2108
	Generation of disc structures completed
09:09:42	#6 Text 0 File Burncd.cpp, Line 4086
	Turn on Disc-At-Once, using CD-R/RW media
09:09:44	#7 Text 0 File DlgWaitCD.cpp, Line 335
	[F: BDR-PR1EPDVPP100] Last possible write address on media:   359846
	Last address to be written:             345999
09:09:44	#8 Text 0 File DlgWaitCD.cpp, Line 347
	[F: BDR-PR1EPDVPP100] Write in overburning mode: NO (enabled: CD)
09:09:45	#9 Text 0 File DlgWaitCD.cpp, Line 3127
	Recorder: PIONEER BDR-PR1EPDVPP100;
	   CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
	   ATIP Data:
	     Special    Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
	     Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
09:09:45	#10 Text 0 File DlgWaitCD.cpp, Line 537
	[F: BDR-PR1EPDVPP100] >>> Protocol of DlgWaitCD activities: <<<
09:09:45	#11 Text 0 File ThreadedTransferInterface.cpp, Line 879
	 0: TRM_AUDIO_NOPRE (1 - Audio)
	    2 indices, index0 (150) provided
	    original disc pos #0 + 13767 (13767) = #13767/3:3.42
	    not relocatable, disc pos for caching/writing not required/not required
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13767 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 1: TRM_AUDIO_NOPRE (2 - Audio)
	    original disc pos #13917 + 11324 (11324) = #25241/5:36.41
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11324 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 2: TRM_AUDIO_NOPRE (3 - Audio)
	    original disc pos #25391 + 15742 (15742) = #41133/9:8.33
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15742 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 3: TRM_AUDIO_NOPRE (4 - Audio)
	    original disc pos #41283 + 14049 (14049) = #55332/12:17.57
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14049 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 4: TRM_AUDIO_NOPRE (5 - Audio)
	    original disc pos #55482 + 23269 (23269) = #78751/17:30.1
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23269 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 5: TRM_AUDIO_NOPRE (6 - Audio)
	    original disc pos #78901 + 19343 (19343) = #98244/21:49.69
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19343 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 6: TRM_AUDIO_NOPRE (7 - Audio)
	    original disc pos #98394 + 20504 (20504) = #118898/26:25.23
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20504 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 7: TRM_AUDIO_NOPRE (8 - Audio)
	    original disc pos #119048 + 19223 (19223) = #138271/30:43.46
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19223 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 8: TRM_AUDIO_NOPRE (9 - Audio)
	    original disc pos #138421 + 18463 (18463) = #156884/34:51.59
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18463 blocks [F: PIONEER BDR-PR1EPDVPP100]
	 9: TRM_AUDIO_NOPRE (10 - Audio)
	    original disc pos #157034 + 26374 (26374) = #183408/40:45.33
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26374 blocks [F: PIONEER BDR-PR1EPDVPP100]
	10: TRM_AUDIO_NOPRE (11 - Audio)
	    original disc pos #183558 + 30355 (30355) = #213913/47:32.13
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30355 blocks [F: PIONEER BDR-PR1EPDVPP100]
	11: TRM_AUDIO_NOPRE (12 - Audio)
	    original disc pos #214063 + 47664 (47664) = #261727/58:9.52
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 47664 blocks [F: PIONEER BDR-PR1EPDVPP100]
	12: TRM_AUDIO_NOPRE (13 - Audio)
	    original disc pos #261877 + 26270 (26270) = #288147/64:1.72
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26270 blocks [F: PIONEER BDR-PR1EPDVPP100]
	13: TRM_AUDIO_NOPRE (14 - Audio)
	    original disc pos #288297 + 57703 (57703) = #346000/76:53.25
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 57703 blocks [F: PIONEER BDR-PR1EPDVPP100]
09:09:45	#12 Text 0 File ThreadedTransferInterface.cpp, Line 1095
	Prepare [F: PIONEER BDR-PR1EPDVPP100] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: "             "
	 Tracks 1 to 14:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos             0        352800      32732784, ISRC ""
	   2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      32732784      33085584      59719632, ISRC ""
	   3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      59719632      60072432      97097616, ISRC ""
	   4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      97097616      97450416     130493664, ISRC ""
	   5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     130493664     130846464     185575152, ISRC ""
	   6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     185575152     185927952     231422688, ISRC ""
	   7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     231422688     231775488     280000896, ISRC ""
	   8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     280000896     280353696     325566192, ISRC ""
	   9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     325566192     325918992     369343968, ISRC ""
	  10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     369343968     369696768     431728416, ISRC ""
	  11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     431728416     432081216     503476176, ISRC ""
	  12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     503476176     503828976     615934704, ISRC ""
	  13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     615934704     616287504     678074544, ISRC ""
	  14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     678074544     678427344     814144800, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	     -150 |  lead-in |   0 |    0x01 |        0 |        0 | 0x00
	     -150 |        1 |   0 |    0x01 |        0 |        0 | 0x00
	        0 |        1 |   1 |    0x01 |    13767 |        0 | 0x00
	    13767 |        2 |   0 |    0x01 |        0 |        0 | 0x00
	    13917 |        2 |   1 |    0x01 |    11324 |    13917 | 0x00
	    25241 |        3 |   0 |    0x01 |        0 |        0 | 0x00
	    25391 |        3 |   1 |    0x01 |    15742 |    25391 | 0x00
	    41133 |        4 |   0 |    0x01 |        0 |        0 | 0x00
	    41283 |        4 |   1 |    0x01 |    14049 |    41283 | 0x00
	    55332 |        5 |   0 |    0x01 |        0 |        0 | 0x00
	    55482 |        5 |   1 |    0x01 |    23269 |    55482 | 0x00
	    78751 |        6 |   0 |    0x01 |        0 |        0 | 0x00
	    78901 |        6 |   1 |    0x01 |    19343 |    78901 | 0x00
	    98244 |        7 |   0 |    0x01 |        0 |        0 | 0x00
	    98394 |        7 |   1 |    0x01 |    20504 |    98394 | 0x00
	   118898 |        8 |   0 |    0x01 |        0 |        0 | 0x00
	   119048 |        8 |   1 |    0x01 |    19223 |   119048 | 0x00
	   138271 |        9 |   0 |    0x01 |        0 |        0 | 0x00
	   138421 |        9 |   1 |    0x01 |    18463 |   138421 | 0x00
	   156884 |       10 |   0 |    0x01 |        0 |        0 | 0x00
	   157034 |       10 |   1 |    0x01 |    26374 |   157034 | 0x00
	   183408 |       11 |   0 |    0x01 |        0 |        0 | 0x00
	   183558 |       11 |   1 |    0x01 |    30355 |   183558 | 0x00
	   213913 |       12 |   0 |    0x01 |        0 |        0 | 0x00
	   214063 |       12 |   1 |    0x01 |    47664 |   214063 | 0x00
	   261727 |       13 |   0 |    0x01 |        0 |        0 | 0x00
	   261877 |       13 |   1 |    0x01 |    26270 |   261877 | 0x00
	   288147 |       14 |   0 |    0x01 |        0 |        0 | 0x00
	   288297 |       14 |   1 |    0x01 |    57703 |   288297 | 0x00
	   346000 | lead-out |   1 |    0x01 |        0 |        0 | 0x00
	MediaType: CD-R
09:09:45	#13 Text 0 File SCSIPTICommands.cpp, Line 404
09:09:45	#14 Text 0 File Burncd.cpp, Line 4984
	Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
09:09:45	#15 PHASE 24 File dlgbrnst.cpp, Line 2108
	Caching of files started
09:09:45	#16 Text 0 File Burncd.cpp, Line 5106
	Cache writing successful.
09:09:45	#17 PHASE 25 File dlgbrnst.cpp, Line 2108
	Caching of files completed
09:09:45	#18 PHASE 36 File dlgbrnst.cpp, Line 2108
	Burn process started at 10x (1*500 KB/s)
09:09:46	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
09:09:46	#20 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 1 (not relocatable, no disc pos, no patch infos, orig at #13917): write at #13917
09:09:46	#21 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 2 (not relocatable, no disc pos, no patch infos, orig at #25391): write at #25391
09:09:46	#22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 3 (not relocatable, no disc pos, no patch infos, orig at #41283): write at #41283
09:09:46	#23 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 4 (not relocatable, no disc pos, no patch infos, orig at #55482): write at #55482
09:09:46	#24 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 5 (not relocatable, no disc pos, no patch infos, orig at #78901): write at #78901
09:09:46	#25 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 6 (not relocatable, no disc pos, no patch infos, orig at #98394): write at #98394
09:09:46	#26 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 7 (not relocatable, no disc pos, no patch infos, orig at #119048): write at #119048
09:09:46	#27 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 8 (not relocatable, no disc pos, no patch infos, orig at #138421): write at #138421
09:09:46	#28 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 9 (not relocatable, no disc pos, no patch infos, orig at #157034): write at #157034
09:09:46	#29 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 10 (not relocatable, no disc pos, no patch infos, orig at #183558): write at #183558
09:09:46	#30 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 11 (not relocatable, no disc pos, no patch infos, orig at #214063): write at #214063
09:09:46	#31 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 12 (not relocatable, no disc pos, no patch infos, orig at #261877): write at #261877
09:09:46	#32 Text 0 File ThreadedTransferInterface.cpp, Line 2926
	Verifying disc position of item 13 (not relocatable, no disc pos, no patch infos, orig at #288297): write at #288297
09:09:46	#33 Text 0 File Mmc.cpp, Line 17655
	StartDAO : CD-Text - Off
09:09:46	#34 Text 0 File Mmc.cpp, Line 21661
	Set BUFE: Buffer underrun protection -> ON
09:09:46	#35 Text 0 File Mmc.cpp, Line 17883
	CueData, Len=240
	01 00 00 01 00 00 00 00
	01 01 00 00 00 00 00 00
	01 01 01 00 00 00 02 00
	01 02 00 00 00 03 05 2a
	01 02 01 00 00 03 07 2a
	01 03 00 00 00 05 26 29
	01 03 01 00 00 05 28 29
	01 04 00 00 00 09 0a 21
	01 04 01 00 00 09 0c 21
	01 05 00 00 00 0c 13 39
	01 05 01 00 00 0c 15 39
	01 06 00 00 00 11 20 01
	01 06 01 00 00 11 22 01
	01 07 00 00 00 15 33 45
	01 07 01 00 00 15 35 45
	01 08 00 00 00 1a 1b 17
	01 08 01 00 00 1a 1d 17
	01 09 00 00 00 1e 2d 2e
	01 09 01 00 00 1e 2f 2e
	01 0a 00 00 00 22 35 3b
	01 0a 01 00 00 22 37 3b
	01 0b 00 00 00 28 2f 21
	01 0b 01 00 00 28 31 21
	01 0c 00 00 00 2f 22 0d
	01 0c 01 00 00 2f 24 0d
	01 0d 00 00 00 3a 0b 34
	01 0d 01 00 00 3a 0d 34
	01 0e 00 00 00 40 03 48
	01 0e 01 00 00 40 05 48
	01 aa 01 01 00 4c 37 19
09:09:46	#36 Text 0 File ThreadedTransfer.cpp, Line 275
	Pipe memory size 83836800
09:18:05	#37 Text 0 File WriterStatus.cpp, Line 245
	<F: PIONEER BDR-PR1EPDVPP100> start writing Lead-Out at LBA 346000 (54790h), length 0 blocks
09:18:19	#38 Text 0 File DVDPlusDualLayer.cpp, Line 1464
	SetDriveCaps: Set LAST LBA of layer 1 to 0
09:18:19	#39 PHASE 37 File dlgbrnst.cpp, Line 2108
	Burn process completed successfully at 10x (1*500 KB/s)
09:18:19	#40 Text 0 File SCSIPTICommands.cpp, Line 454
09:18:19	#41 Text 0 File Cdrdrv.cpp, Line 12297
09:18:19	#42 Text 0 File SCSIPTICommands.cpp, Line 617
Stary 05.04.2017, 09:39   #11
wujooj
Avatar użytkownika wujooj
Data rejestracji: 02.09.2016
wujooj jest klejnotem wśród średnio znających się "w temacie" <250 - 349 pkt>wujooj jest klejnotem wśród średnio znających się "w temacie" <250 - 349 pkt>wujooj jest klejnotem wśród średnio znających się "w temacie" <250 - 349 pkt>
Bardzo ładny wynik. Osobiście jeszcze nie zdarzyło mi się, aby ten model nie nagrał jakiejś płyty
wujooj jest offline   Odpowiedz cytując ten post
Stary 05.04.2017, 11:19   #12
Napisany przez wujooj Podgląd Wiadomości
Dla mnie też ...
Stary 05.04.2017, 23:31   #13
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
@czary2mary - Thanks to @wujooj I now have a BDR-PR1EPDV. Where did you find the 1.01 firmware?
Stary 06.04.2017, 02:48   #14
Top secret
Posted on PM.
We are waiting for your tests ..
Stary 06.04.2017, 15:38   #15
jadburner
Top secret
Posted on PM.
@czary2mary - Thank you!
PureRead - Pioneer DVD\BluRay Drive czary2mary Audio/Stacjonarne nagrywarki i nośniki CD-R Audio 12 06.10.2017 07:17
Wybór nagrywarki LG BH10LS lub LITEON IHBS 112 ORAZ PIONEER BDR 205 BK rysieksat Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD 0 27.05.2011 19:19
Problem z wypalaniem CD na Pioneer DVDR-112D noe Napędy optyczne CD 4 02.06.2007 16:38
Nagrywarka mi zjada płyty DriX Napędy optyczne DVD 22 20.05.2006 11:35
Problem z nagrywaniem Dvd+r (pioneer 110-d) Davidian Napędy optyczne CD 6 24.03.2006 14:26
Wszystkie czasy w strefie CET. Aktualna godzina: 08:43.
