| czary2mary |
05.04.2017 07:01 |
Ilość załączników: 6
MediaRange CD-R x52 Plasmon 97m27s18f
Pioneer BDR-PR1EPDV fw.1.01
NERO 2017 x10
Jestem w lekkim szoku co Pionek +Nero zrobiły z tym nośnikiem :wow::wow::wow:
Znaczek PR1 nie od parady ...;)
log :
Kod:
Windows 8 6.2
AMD64
Wow64Process
Nero Version: 18.0.15.0
Internal Version: 18,0,15,0
Recorder : <PIONEER BDR-PR1EPDVPP100> FW version: 1.01 - HA 1 TA 1 - 18.0.15.0
Device bus : <> HA 1
Host system bus : <USB 2>
Drive buffer : 4000kB
Bus Type : via Inquiry data
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD/DVD-ROM : <HL-DT-ST DVDRAM GT30N > FW version: 1.01 - HA 1 TA 0 - 18.0.15.0
Host system bus : <IDE>
=== Scsi-Device-Map ===
DiskPeripheral : KINGSTON SV300S37A120G iaStor Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD7500BPKX-75HPJT0 iaStor Port 0 ID 1 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRAM GT30N iaStor Port 0 ID 2 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GT30N D: CdRom0
PIONEER BDR-PR1EPDVPP100 F: CdRom1
AutoRun : 0
Excluded drive IDs:
BUFE : 0
Physical memory : 4090MB (4189108kB)
Free physical memory: 1849MB (1893848kB)
Memory in use : 54 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
1.4.2017
Obraz dysku
09:09:41 #1 Text 0 File SCSIPTICommands.cpp, Line 617
09:09:41 #2 Text 0 File Burncd.cpp, Line 3723
Włączono System ochrony zapisu
09:09:41 #3 PHASE 214 File dlgbrnst.cpp, Line 2108
Generation of disc structures started
09:09:41 #4 IMAGEGEN -10 File ImageGen.cpp, Line 400
Image was written as DAO.
DAOI:
MediaCatalogNumber = ' '
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 14
1: ISRC = ''
Blocksize = 2352
TrackMode = 'TRM_AUDIO_NOPRE'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 352800, NextTrackFilePos = 32732784
2: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 32732784, Index1FilePos = 33085584, NextTrackFilePos = 59719632
3: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 59719632, Index1FilePos = 60072432, NextTrackFilePos = 97097616
4: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 97097616, Index1FilePos = 97450416, NextTrackFilePos = 130493664
5: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 130493664, Index1FilePos = 130846464, NextTrackFilePos = 185575152
6: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 185575152, Index1FilePos = 185927952, NextTrackFilePos = 231422688
7: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 231422688, Index1FilePos = 231775488, NextTrackFilePos = 280000896
8: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 280000896, Index1FilePos = 280353696, NextTrackFilePos = 325566192
9: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 325566192, Index1FilePos = 325918992, NextTrackFilePos = 369343968
10: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 369343968, Index1FilePos = 369696768, NextTrackFilePos = 431728416
11: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 431728416, Index1FilePos = 432081216, NextTrackFilePos = 503476176
12: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 503476176, Index1FilePos = 503828976, NextTrackFilePos = 615934704
13: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 615934704, Index1FilePos = 616287504, NextTrackFilePos = 678074544
14: ISRC = ''
Blocksize = 2352
TrackConfig = 0x00
Index0FilePos = 678074544, Index1FilePos = 678427344, NextTrackFilePos = 814144800
CUES:
0: Ctrl=0x01 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
1: Ctrl=0x00 Trk= 0 (0x00) Index=138 Start=123105:47.39 (553976064) RecDep=0x24 [open track]
2: Ctrl=0x21 Trk= 10 (0x10) Index=00 Start=34:51.59 ( 156884) RecDep=0x00
MTYP: Mediumtype = CD (old format) (0x1)
Image file name: <C:\Users\czary2mary\Desktop\Image.nrg>
09:09:42 #5 PHASE 215 File dlgbrnst.cpp, Line 2108
Generation of disc structures completed
09:09:42 #6 Text 0 File Burncd.cpp, Line 4086
Turn on Disc-At-Once, using CD-R/RW media
09:09:44 #7 Text 0 File DlgWaitCD.cpp, Line 335
[F: BDR-PR1EPDVPP100] Last possible write address on media: 359846
Last address to be written: 345999
09:09:44 #8 Text 0 File DlgWaitCD.cpp, Line 347
[F: BDR-PR1EPDVPP100] Write in overburning mode: NO (enabled: CD)
09:09:45 #9 Text 0 File DlgWaitCD.cpp, Line 3127
Recorder: PIONEER BDR-PR1EPDVPP100;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
09:09:45 #10 Text 0 File DlgWaitCD.cpp, Line 537
[F: BDR-PR1EPDVPP100] >>> Protocol of DlgWaitCD activities: <<<
09:09:45 #11 Text 0 File ThreadedTransferInterface.cpp, Line 879
0: TRM_AUDIO_NOPRE (1 - Audio)
2 indices, index0 (150) provided
original disc pos #0 + 13767 (13767) = #13767/3:3.42
not relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13767 blocks [F: PIONEER BDR-PR1EPDVPP100]
1: TRM_AUDIO_NOPRE (2 - Audio)
original disc pos #13917 + 11324 (11324) = #25241/5:36.41
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11324 blocks [F: PIONEER BDR-PR1EPDVPP100]
2: TRM_AUDIO_NOPRE (3 - Audio)
original disc pos #25391 + 15742 (15742) = #41133/9:8.33
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15742 blocks [F: PIONEER BDR-PR1EPDVPP100]
3: TRM_AUDIO_NOPRE (4 - Audio)
original disc pos #41283 + 14049 (14049) = #55332/12:17.57
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14049 blocks [F: PIONEER BDR-PR1EPDVPP100]
4: TRM_AUDIO_NOPRE (5 - Audio)
original disc pos #55482 + 23269 (23269) = #78751/17:30.1
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23269 blocks [F: PIONEER BDR-PR1EPDVPP100]
5: TRM_AUDIO_NOPRE (6 - Audio)
original disc pos #78901 + 19343 (19343) = #98244/21:49.69
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19343 blocks [F: PIONEER BDR-PR1EPDVPP100]
6: TRM_AUDIO_NOPRE (7 - Audio)
original disc pos #98394 + 20504 (20504) = #118898/26:25.23
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20504 blocks [F: PIONEER BDR-PR1EPDVPP100]
7: TRM_AUDIO_NOPRE (8 - Audio)
original disc pos #119048 + 19223 (19223) = #138271/30:43.46
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19223 blocks [F: PIONEER BDR-PR1EPDVPP100]
8: TRM_AUDIO_NOPRE (9 - Audio)
original disc pos #138421 + 18463 (18463) = #156884/34:51.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18463 blocks [F: PIONEER BDR-PR1EPDVPP100]
9: TRM_AUDIO_NOPRE (10 - Audio)
original disc pos #157034 + 26374 (26374) = #183408/40:45.33
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26374 blocks [F: PIONEER BDR-PR1EPDVPP100]
10: TRM_AUDIO_NOPRE (11 - Audio)
original disc pos #183558 + 30355 (30355) = #213913/47:32.13
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30355 blocks [F: PIONEER BDR-PR1EPDVPP100]
11: TRM_AUDIO_NOPRE (12 - Audio)
original disc pos #214063 + 47664 (47664) = #261727/58:9.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 47664 blocks [F: PIONEER BDR-PR1EPDVPP100]
12: TRM_AUDIO_NOPRE (13 - Audio)
original disc pos #261877 + 26270 (26270) = #288147/64:1.72
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26270 blocks [F: PIONEER BDR-PR1EPDVPP100]
13: TRM_AUDIO_NOPRE (14 - Audio)
original disc pos #288297 + 57703 (57703) = #346000/76:53.25
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 57703 blocks [F: PIONEER BDR-PR1EPDVPP100]
09:09:45 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1095
Prepare [F: PIONEER BDR-PR1EPDVPP100] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
Tracks 1 to 14: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 32732784, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 32732784 33085584 59719632, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 59719632 60072432 97097616, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 97097616 97450416 130493664, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 130493664 130846464 185575152, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 185575152 185927952 231422688, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 231422688 231775488 280000896, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 280000896 280353696 325566192, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 325566192 325918992 369343968, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 369343968 369696768 431728416, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 431728416 432081216 503476176, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 503476176 503828976 615934704, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 615934704 616287504 678074544, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 678074544 678427344 814144800, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x01 | 0 | 0 | 0x00
0 | 1 | 1 | 0x01 | 13767 | 0 | 0x00
13767 | 2 | 0 | 0x01 | 0 | 0 | 0x00
13917 | 2 | 1 | 0x01 | 11324 | 13917 | 0x00
25241 | 3 | 0 | 0x01 | 0 | 0 | 0x00
25391 | 3 | 1 | 0x01 | 15742 | 25391 | 0x00
41133 | 4 | 0 | 0x01 | 0 | 0 | 0x00
41283 | 4 | 1 | 0x01 | 14049 | 41283 | 0x00
55332 | 5 | 0 | 0x01 | 0 | 0 | 0x00
55482 | 5 | 1 | 0x01 | 23269 | 55482 | 0x00
78751 | 6 | 0 | 0x01 | 0 | 0 | 0x00
78901 | 6 | 1 | 0x01 | 19343 | 78901 | 0x00
98244 | 7 | 0 | 0x01 | 0 | 0 | 0x00
98394 | 7 | 1 | 0x01 | 20504 | 98394 | 0x00
118898 | 8 | 0 | 0x01 | 0 | 0 | 0x00
119048 | 8 | 1 | 0x01 | 19223 | 119048 | 0x00
138271 | 9 | 0 | 0x01 | 0 | 0 | 0x00
138421 | 9 | 1 | 0x01 | 18463 | 138421 | 0x00
156884 | 10 | 0 | 0x01 | 0 | 0 | 0x00
157034 | 10 | 1 | 0x01 | 26374 | 157034 | 0x00
183408 | 11 | 0 | 0x01 | 0 | 0 | 0x00
183558 | 11 | 1 | 0x01 | 30355 | 183558 | 0x00
213913 | 12 | 0 | 0x01 | 0 | 0 | 0x00
214063 | 12 | 1 | 0x01 | 47664 | 214063 | 0x00
261727 | 13 | 0 | 0x01 | 0 | 0 | 0x00
261877 | 13 | 1 | 0x01 | 26270 | 261877 | 0x00
288147 | 14 | 0 | 0x01 | 0 | 0 | 0x00
288297 | 14 | 1 | 0x01 | 57703 | 288297 | 0x00
346000 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
MediaType: CD-R
09:09:45 #13 Text 0 File SCSIPTICommands.cpp, Line 404
09:09:45 #14 Text 0 File Burncd.cpp, Line 4984
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
09:09:45 #15 PHASE 24 File dlgbrnst.cpp, Line 2108
Caching of files started
09:09:45 #16 Text 0 File Burncd.cpp, Line 5106
Cache writing successful.
09:09:45 #17 PHASE 25 File dlgbrnst.cpp, Line 2108
Caching of files completed
09:09:45 #18 PHASE 36 File dlgbrnst.cpp, Line 2108
Burn process started at 10x (1*500 KB/s)
09:09:46 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
09:09:46 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 1 (not relocatable, no disc pos, no patch infos, orig at #13917): write at #13917
09:09:46 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 2 (not relocatable, no disc pos, no patch infos, orig at #25391): write at #25391
09:09:46 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 3 (not relocatable, no disc pos, no patch infos, orig at #41283): write at #41283
09:09:46 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 4 (not relocatable, no disc pos, no patch infos, orig at #55482): write at #55482
09:09:46 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 5 (not relocatable, no disc pos, no patch infos, orig at #78901): write at #78901
09:09:46 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 6 (not relocatable, no disc pos, no patch infos, orig at #98394): write at #98394
09:09:46 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 7 (not relocatable, no disc pos, no patch infos, orig at #119048): write at #119048
09:09:46 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 8 (not relocatable, no disc pos, no patch infos, orig at #138421): write at #138421
09:09:46 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 9 (not relocatable, no disc pos, no patch infos, orig at #157034): write at #157034
09:09:46 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 10 (not relocatable, no disc pos, no patch infos, orig at #183558): write at #183558
09:09:46 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 11 (not relocatable, no disc pos, no patch infos, orig at #214063): write at #214063
09:09:46 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 12 (not relocatable, no disc pos, no patch infos, orig at #261877): write at #261877
09:09:46 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 13 (not relocatable, no disc pos, no patch infos, orig at #288297): write at #288297
09:09:46 #33 Text 0 File Mmc.cpp, Line 17655
StartDAO : CD-Text - Off
09:09:46 #34 Text 0 File Mmc.cpp, Line 21661
Set BUFE: Buffer underrun protection -> ON
09:09:46 #35 Text 0 File Mmc.cpp, Line 17883
CueData, Len=240
01 00 00 01 00 00 00 00
01 01 00 00 00 00 00 00
01 01 01 00 00 00 02 00
01 02 00 00 00 03 05 2a
01 02 01 00 00 03 07 2a
01 03 00 00 00 05 26 29
01 03 01 00 00 05 28 29
01 04 00 00 00 09 0a 21
01 04 01 00 00 09 0c 21
01 05 00 00 00 0c 13 39
01 05 01 00 00 0c 15 39
01 06 00 00 00 11 20 01
01 06 01 00 00 11 22 01
01 07 00 00 00 15 33 45
01 07 01 00 00 15 35 45
01 08 00 00 00 1a 1b 17
01 08 01 00 00 1a 1d 17
01 09 00 00 00 1e 2d 2e
01 09 01 00 00 1e 2f 2e
01 0a 00 00 00 22 35 3b
01 0a 01 00 00 22 37 3b
01 0b 00 00 00 28 2f 21
01 0b 01 00 00 28 31 21
01 0c 00 00 00 2f 22 0d
01 0c 01 00 00 2f 24 0d
01 0d 00 00 00 3a 0b 34
01 0d 01 00 00 3a 0d 34
01 0e 00 00 00 40 03 48
01 0e 01 00 00 40 05 48
01 aa 01 01 00 4c 37 19
09:09:46 #36 Text 0 File ThreadedTransfer.cpp, Line 275
Pipe memory size 83836800
09:18:05 #37 Text 0 File WriterStatus.cpp, Line 245
<F: PIONEER BDR-PR1EPDVPP100> start writing Lead-Out at LBA 346000 (54790h), length 0 blocks
09:18:19 #38 Text 0 File DVDPlusDualLayer.cpp, Line 1464
SetDriveCaps: Set LAST LBA of layer 1 to 0
09:18:19 #39 PHASE 37 File dlgbrnst.cpp, Line 2108
Burn process completed successfully at 10x (1*500 KB/s)
09:18:19 #40 Text 0 File SCSIPTICommands.cpp, Line 454
09:18:19 #41 Text 0 File Cdrdrv.cpp, Line 12297
09:18:19 #42 Text 0 File SCSIPTICommands.cpp, Line 617
Załącznik 90573
Załącznik 90574
Załącznik 90575
Załącznik 90576
Załącznik 90577
Załącznik 90578
