Stary 01.03.2024, 22:26   #1
PlextorMan
Data rejestracji: 21.07.2023
PlextorMan w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Vinpower WH16NS58 1.V8 does not support disc quality check??!!!! Please help!
Hello everyone,
I bought a new burning drive: "Vinpower WH16NS58" and found i fout that it does not support measuring the quality of BD-R, DVD amd CD media!
According to the reviews on this forum, it was said that this drive has modified firmware from the company: "Vinpower Digital", which can measure the quality of burned BD-R media (LDC/BIS).
The burn drive was purchased at: "https://labelprinter.pl/".
The drive came in a "bulk" version without the Plextools software, so I can't measure media quality in any software.
Where can the problem be? Thank you...
PlextorMan jest offline   Odpowiedz cytując ten post
Stary 03.03.2024, 06:07   #2
Contact your dealer or Vinpower support. They have already had mistakes with the uploaded firmware.
Also ask about PlexTools - they send it to your e-mail address for those who bought it and did not receive it on a CD.
The series with firmware 1.V5 tests discquality.
Stary 23.04.2024, 20:02   #3
Stingray
Data rejestracji: 12.02.2024
Stingray w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Napisany przez PlextorMan Podgląd Wiadomości
Hello everyone,
how you solved this issue?
Stingray jest offline   Odpowiedz cytując ten post
Stary 23.04.2024, 23:07   #4
PlextorMan
Napisany przez Stingray Podgląd Wiadomości
Hello,
I have solved this problem for a long time with the technical support of Vinpowerdigital.com, where I was told that the "58D and version robot" models can measure the quality (disc quality check), so I ordered the model: "robot" for more money and I received an identical model from: "labelprinter.pl", which also cannot measure the quality of burned media.
I returned both models back to: "Labelprinter.pl" and I am currently waiting for a refund.
I do not know if it was a mistake on the side of the labelprinter.pl or directly to the vigpowerdigital.com, but on the following models:
"DUP versions" cannot measure the quality of burned media in any programs.
I tested the firmware upgrade to version 1. V9 and downgrade on version 1. V5.
Interestingly, the second unit purchased had the same identification labels, but different firmware:
Drive no.1: "WH16NS58 1V8" Firmware.
Drive no. 2: (Reportedly Robot version): "WH16NS58 TSTK Firmware.
Pics (Comparison of drives):
https://postimg.cc/DmrtH0V0
https://postimg.cc/1fVBk4Fs
I am currently staying at my recently purchased new drive: Liteon IHBS 212 changed to Plexor PX-LB950SA (CrossFlash).
Stary 23.04.2024, 23:27   #5
Stingray
Good night.
thanks for the info, was just thinking of buying one on amazon for $74.
Maybe your computer's SATA controller is interfering? Just a guess.
By the way, where did you get the 1.v9 FW?
Maybe you came across a description of what they changed in their firmware after 1.v5?
Stary 24.04.2024, 18:15   #6
PlextorMan
Question no. 1:
It's not by the SATA controller. I tried to connect the drive also via an external USB box: "OWC Mercury Pro":
https://www.owc.com/solutions/mercury-pro-optical
I was also thinking about buying from Amazon.com
People in the discussion for this product write that this drive supports quality measurement.
Link Amazon product: Digital LG HLDS WH16NS58DUP
If you would ask Vinpower Digital directly via Amazon.com about this function with a link on this forum and this problem, maybe you will be succeed. Then I would definitely buy this drive from Amazon.com as well.
Question no. 2:
Firmware 1.V9 I received from technical support: VINPOWER Digital (Germany's Office).
Question no. 3:
I did not receive a list of changes, but if you request it, they will surely give it to you.
I have this firmware available.
Good night.
Stary 28.04.2024, 20:51   #7
truemaster
Data rejestracji: 16.08.2023
truemaster w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
if you can upload a fw updater to 1.v9 or a valid dump in .bin format please upload it. vinpower stop publish updates for this drive
truemaster jest offline   Odpowiedz cytując ten post
Stary 29.04.2024, 19:36   #8
PlextorMan
Napisany przez truemaster Podgląd Wiadomości
This is the official EXE update firmware (download link see. below). It is designed for the version: "WH16NS58 DUP" I do not guarantee that "Disc Quality SCAN" will work with this firmware. Updating this firmware is at your own risk. When downgrading to firmware v.1.5 (using the program: "SDFtool Flasher"), I found that the firmware v. 1.9 is encrypted.
PIC: SDFtool Flasher (Downgrade to firmware v 1.5 non encrypted) demonstration.
Download link (EXE Update Firmware): https://bestfile.io/hcgxv2UVijJ1FMp/file
Note: If anyone can give information where to buy this drive with Disc Quality Scan function, I would be grateful. Thank you...
Stary 30.04.2024, 11:25   #9
Stingray
thank you
it seems strange official Vinpower device does not support quality scan , but crossflashed LG/ASUS -> vinpower v1.v5 support
Stary 30.04.2024, 16:12   #10
truemaster
ive crosflased my drive with wh16ns60 firmware to makemkv 1.v5 via SDFtool Flasher then using the 1.v9 updater.exe and upgrade my drive. but now it doesnt read any media. reflashing back to wh16ns60 didnt help. any ideas??
Stary 30.04.2024, 20:35   #11
Stingray
no read but write?
I had similar issue with 1.v5, but flashed another 1.v5 (MK) and drive became read, write and scan
Stary 01.05.2024, 05:31   #12
truemaster
no its a brick now dosnt recognise any media
1.v8, check, disc, quality, support, vinpower, wh16ns58
Wszystkie czasy w strefie CET. Aktualna godzina: 23:38.
