Stary 14.06.2017, 07:01   #91
Passkey 9.2.0.2
Passkey 9.2.0.2
New: Added the support for some new Java protections.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Stary 16.06.2017, 08:29   #92
DVDFab 10.0.4.2
New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of At Any Price, Elvis and Nixon, Love and Mercy, Don***8217;t Kill It and the DVD versions of Sing, Middle School: The Worst Years of My Life.
New: Added the Scheduled Task feature to the Task Queue Manager.
New: Added the 10bit support to several MKV and MP4 profiles in the Ripper and Converter modules.
Fix: Some minor fixes and improvements.
http://www.dvdfab.cn/download.htm
Stary 18.06.2017, 18:54   #93
Passkey 9.2.0.3
Fix: A crash problem when doing the BDFix in certain caes.
Stary 21.06.2017, 05:02   #94
AnyDVD 8.1.4.5 Beta
8.1.4.5 2017 06 20
- New (Blu-ray): Support for new discs
- New (DVD): Support for new discs
- New: OPD can be used, if Passkey is installed
- Change (DVD): OPD is currently disabled
- Caution (DVD): There might be regression problems.
- Some minor fixes and improvements
http://sandbox.redfox.bz/SetupAnyDVD8145.exe
Stary 22.06.2017, 04:28   #95
DVDFab 10.0.4.3 + Passkey 9.2.0.4 + AnyDVD 8.1.5.0
DVDFab 10.0.4.3
New: Added the support for the new copy protection as found on DVD John Wick: Chapter 2.
New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of Patriot's Day, John Wick: Chapter 2, The Eagle Huntress and La La Land.
Passkey 9.2.0.4
AnyDVD 8.1.5.0
8.1.5.0 2017 06 20
https://www.redfox.bz/download/SetupAnyDVD8150.exe
Stary 23.06.2017, 18:56   #96
DVDFab 10.0.4.4 Beta
New: Introduced the new tool BDFix available under the Utility tab. More Info: http://www.dvdfab.cn/bdfix.htm
New: Improved the incremental update feature.
Fix: Fixed the problem that BDInfo scans incorrect bitrate in certain cases.
Fix: Fixed the pixelization problem when ripping to AVI videos.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA
Stary 30.06.2017, 04:49   #97
AnyDVD 8.1.5.1 Beta
8.1.5.1 2017 06 29
When testing, please check for DVD regression problems. Thank you.
http://sandbox.redfox.bz/SetupAnyDVD8151.exe
Stary 30.06.2017, 18:03   #98
AnyDVD 8.1.5.2 Beta
8.1.5.2 2017 06 30
http://sandbox.redfox.bz/SetupAnyDVD8152.exe
Stary 30.06.2017, 18:09   #99
DVDFab 10.0.4.5 + Passkey 9.2.0.6
DVDFab 10.0.4.5
New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of Patriot's Day (Canada edition)) and John Wick: Chapter 2 (Canada edition).
New: Added the support for the new copy protections found on the DVD versions of John Wick: Chapter 2 (Canada edition) and Saban's Power Rangers.
New: Added the support to save DVD & Blu-ray ISO files directly to DVDFab Movie Server.
More Info: http://www.dvdfab.cn/movie-server.htm
Fix: Fixed the problem that BDInfo scans incorrect bitrates in certain cases.
Fix: Fixed the problem that the file size is too small when compressing Blu-ray sources to BD25 with AMD GPU in certain cases.
Fix: Fixed the crash problem when removing Apple DRM encryptions in certain cases.
Passkey 9.2.0.6
Stary 04.07.2017, 08:38   #100
DVDFab 10.0.4.6 + Passkey 9.2.0.8
DVDFab 10.0.4.6
New: Added the support for the new copy protection found on another US version of the DVD Saban's Power Rangers.
Fix: Fixed the failure problem when using VSO and ImgBurn burnning engines in certain cases.
Passkey 9.2.0.8
Stary 05.07.2017, 06:50   #101
AnyDVD 8.1.6.0
8.1.6.0 2017 07 03
https://www.redfox.bz/download/SetupAnyDVD.exe
Stary 06.07.2017, 08:16   #102
AnyDVD 8.1.6.1 Beta
8.1.6.1 2017 07 04
- Fix (Blu-ray): Crash with some discs
http://sandbox.redfox.bz/SetupAnyDVD8161.exe
Stary 13.07.2017, 11:17   #103
Passkey 9.2.0.9
New: Improved the support for DVD PathPlayer.
Stary 14.07.2017, 22:37   #104
DVDFab 10.0.4.7 Beta + Passkey 9.2.1.0
New: Introduced the new product Screen Recorder & Editor for iOS under the Utilities tab. Note that this product is still at the Alpha stage, if you have advices and suggestions, please feel free to let us know. More Info: http://www.dvdfab.cn/screen-recorder-editor-for-ios.htm
New: Added the ***8220;Copy Source***8221; option in right-click menu in the Main Movie mode of Copy module, Ripper and Converter modules.
New: Added a ***8220;How to handle read error problems***8221; tip in the read error alert dialog.
More Info: http://www.dvdfab.cn/faq/?type=dvd_copy#faq_6
Fix: Improved the support for DVD PathPlayer.
Fix: Improved the support for BDInfo utility.
Fix: Some minor changes and improvements.
Passkey 9.2.1.0
New: Improved the support for Blu-ray BluPath.
Stary 18.07.2017, 19:49   #105
AnyDVD 8.1.6.4 beta
8.1.6.4 2017 07 17
- Fix (DVD): CSS brute force removal did not work with some drives
http://sandbox.redfox.bz/SetupAnyDVD8164.exe
blu-ray, kopia, kopiowanie, płyta, płyta blu-ray
nagrywanie płyt Bluray macies High Definition 20 05.01.2017 07:45
Problem z odczytem starszych płyt dvd+r - dziwny przypadek - ogromna prośba o pomoc.. ivesher Napędy optyczne DVD 9 25.01.2011 10:12
Jak zmusić 1633S do odczytu nagranych przez siebie płyt DVD-R? MKJ Napędy optyczne DVD 12 19.03.2005 23:20
Cześć.potrzebuje kopie EEPROMA do LiteONa 1633S . po przeróbce na 1653 nie czyta płyt tom106 Napędy optyczne DVD 3 07.12.2004 06:40
Szukam płyt poniżej 1 zł (kontaktu do producenta CD-R) VVirOOs Napędy optyczne CD 15 20.03.2002 21:16
Wszystkie czasy w strefie CET. Aktualna godzina: 16:55.
