DVDFab 12.0.0.2 + DVDFab Passkey 9.4.0.1
DVDFab 12.0.0.2
https://www.dvdfab.cn/download.htm DVDFab 12.0.0.2 Changelog Fix: An H.265 custom setting problem in the Video Converter module. Fix: A problem that the HDR10 content in certain videos cannot be recognized. DVDFab Passkey 9.4.0.1 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
DVDFab 12.0.0.1 + DVDFab Passkey 9.4.0.0 + AnyDVD 8.5.0.0
DVDFab 12.0.0.1
https://www.dvdfab.cn/download.htm DVDFab 12.0.0.1 Changelog Fix: A startup crash problem in certain cases. Fix: An OCR failure problem when outputting SRT subtitles in the Ripper modules on PCs with older CPUs. Fix: A problem that GPU load shows as 0% during conversion. DVDFab Passkey 9.4.0.0 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. AnyDVD 8.5.0.0 https://www.redfox.bz/download/SetupAnyDVD.exe 8.5.0.0 2020 10 10 - New (Blu-ray): Support for new discs - New (Blu-ray): Workaround for some AACS authoring errors - New (DVD): Support for new discs - Fix (Blu-ray): Missing files when "ripping to folder" - Fix (Blu-ray): Crash with some discs - Some fixes and improvements |
DVDFab 11.1.0.6
DVDFab 11.1.0.6 Changelog New: Added the support to use Enlarger AI relevant features on computers installed with AMD graphics card. Fix: A problem the backup disc made by the DVD to Blu-ray Converter module plays incorrect title under the menu playback mode. Fix: A problem that the output MP4 videos converted by the Ripper modules contain English audio track even Spanish is selected. Fix: A problem that the Video Converter module cannot identify the HDR10 videos. Fix: A problem that DVDFab takes too much of CPU power when reading discs. |
AnyDVD 8.4.9.4 Beta
http://sandbox.redfox.bz/SetupAnyDVD8494.exe
8.4.9.4 2020 09 01 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Fix (Blu-ray): Missing files when "ripping to folder" - Fix (Blu-ray): Crash with some discs - Some fixes and improvements |
DVDFab Passkey 9.3.9.8
Passkey 9.3.9.8 Changelog New: Added the support for some new Java protections. |
DVDFab 11.1.0.5
DVDFab 11.1.0.5 Changelog New: Added the support for some new Java protections. New: Added the support to preview Enlarger AI upscaling results before conversion starts in the Ripper and DVD to Blu-ray Converter modules. Fix: A problem that the title information of the converted files by the Ripper and Video Converter modules is still retained despite the Metainfo feature being disabled. Fix: A problem that DVDFab switched to the Copy module after restarting from the Ripper module. |
DVDFab 11.1.0.4+ DVDFab Passkey 9.3.9.7 + AnyDVD 8.4.9.3 Beta
DVDFab 11.1.0.4
https://www.dvdfab.cn/download.htm DVDFab 11.1.0.4 Changelog New: Added the support for some new Java protections. Fix: A crash problem when opening certain DVDs. DVDFab Passkey 9.3.9.7 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.3.9.7 Changelog New: Added the support for some new Java protections. AnyDVD 8.4.9.3 Beta http://sandbox.redfox.bz/SetupAnyDVD8493.exe 8.4.9.3 2020 08 20 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Fix (Blu-ray): Missing files when "ripping to folder" - Fix (Blu-ray): Crash with some discs - Some fixes and improvements |
DVDFab 11.1.0.3 + DVDFab Passkey 9.3.9.6
DVDFab 11.1.0.3
https://www.dvdfab.cn/download.htm New: Added the support to preview Enlarger AI upscaling results before conversion starts in the Video Converter module. (Ripper and DVD to Blu-ray Converter modules will be supported next). New: Improved the support for opening Blu-ray and 4K Ultra HD Blu-ray discs. Fix: A failure problem when opening certain H.265 encoded MKV videos in the Video Converter module. Fix: A crash problem when copying/converting DVD or Blu-ray discs in certain cases. DVDFab Passkey 9.3.9.6 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
Fab Passkey 9.3.9.5
Passkey 9.3.9.5 Changelog New: Added the support for some new Java protections. |
DVDFab 11.1.0.0 + DVDFab Passkey 9.3.9.4
DVDFab 11.1.0.0
https://www.dvdfab.cn/download.htm DVDFab 11.1.0.0 Changelog New: Added the support for some new Java protections. New: Added the support to preset conversion profiles for Enlarger AI and Video Converter modules. New: Improved the feature not to remember the setting of shut down computer upon task completion. DVDFab Passkey 9.3.9.4 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.3.9.4 Changelog New: Added the support for some new Java protections. |
DVDFab 11.0.9.9
DVDFab 11.0.9.9 Changelog Fix: A conversion failure problem when upscaling videos with Enlarger AI in the Video Converter module in certain cases. Fix: A conversion failure problem when converting DVDs using software decoding in certain cases. |
DVDFab Passkey 9.3.9.3
Passkey 9.3.9.3 Changelog New: Added the support for some new Java protections. |
DVDFab 11.0.9.7 + DVDFab Passkey 9.3.9.2
DVDFab 11.0.9.7
https://www.dvdfab.cn/download.htm DVDFab 11.0.9.7 Changelog New: Added two new Enlarger AI training models Deblock and Ultra+Deblock in Ripper, Video Converter and DVD to Blu-ray Converter modules. New: Added the feature to preset AI profiles in Ripper modules at Common Settings > Profiles > Set Profiles for Enlarger AI. New: Improved the support for the profile preset feature. DVDFab may ask you to reset it again if you used to set profiles in ver. 11.0.9.2 or older. New: Renamed the default output name for TV Shows from s0xe0x to S0xE0x. Fix: A problem that html appears in the Task Queue Log viewer. Fix: Some minor translation problems. DVDFab Passkey 9.3.9.2 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.3.9.2 Changelog New: Added the support for some new Java protections. |
AnyDVD 8.4.9.2 Beta
http://sandbox.redfox.bz/SetupAnyDVD8492.exe
8.4.9.2 2020 07 07 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Fix (Blu-ray): Missing files when "ripping to folder" - Some minor fixes and improvements |
DVDFab 11.0.9.6 + DVDFab Passkey 9.3.9.1
DVDFab 11.0.9.6
https://www.dvdfab.cn/download.htm DVDFab 11.0.9.6 Changelog Fix: A crash problem when opening sources in certain cases. DVDFab Passkey 9.3.9.1 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.3.9.1 Changelog New: Added the support for some new Java protections. Fix: A problem that the default display language is Spanish despite the system language being English. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 12:52. |
