-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 20.02.2019 11:03
DVDFab 11.0.1.6
New: Added the support for some new Java protections.
Fix: A problem that the source switcher is toggled off after loading the 2nd disc when handling multiple discs.
Fix: A subtitles previewing problem on certain Blu-rays.
Fix: A problem the merge feature in the Video Converter can only process two sources.
Fix: A problem that DVD to Blu-ray Converter can only burn to one disc even the number of copies is set as 2.
Fix: Some minor changes and improvements on the UHD Drive Tool utility.
Fix: Some minor GUI changes and improvements.
https://www.dvdfab.cn/download.htm
czary2mary 30.01.2019 18:34
AnyDVD 8.3.4.0
8.3.4.0 2019 01 28
- New (Blu-ray): Support for new discs
- New (DVD): Support for new discs
- Fix: Rare Driver / device errors were unnoticed
https://www.redfox.bz/download/SetupAnyDVD.exe
czary2mary 26.01.2019 09:12
DVDFab 11.0.1.5
New: Added the support to remove the Cinavia watermark found on the Blu-ray version of Lockout (2012).
New: Added the support to retain the playlist information when converting BDAV discs in the Ripper module.
New: Added the BD100 1080p and BD66 1080p output support to the UHD to Blu-ray Converter module (only x64 version).
New: Introduced the UHD Drive Tool utility to downgrade the backup-unfriendly firmware on a UHD Drive.
More Info: https://www.dvdfab.cn/uhd-drive-tool.htm
New: Added the Passkey driver support at the Common Settings > Drives > Read > IO Mode (only x86 version).
New: Improved the module icons at the top tab bar.
Fix: A failure problem when opening certain DVDFab ripped DVD & Blu-ray folders released by Disney (USA) in the Ripper module.
Fix: A failure problem when converting certain DVDs to WAV audios in the Ripper module.
Fix: A failure problem when opening certain video files in the Video Converter module.
Fix: A problem that the Saturation setting at the Video Edit panel of the Video Converter module does not work.
Fix: A problem that the timestamp of the playback progress bar is not correct if rendering subtitles when converting certain MKV videos in the Video Converter module.
Fix: A failure problem when converting the VOB files directly from certain DVD folders in the Video Converter module.
Fix: A problem that the video files with runtime less than 1s can be loaded to the Video Converter module but fail to convert.
Fix: A failure problem when analyzing certain URLs in the YouTube to MP3 utility.
czary2mary 23.01.2019 15:54
AnyDVD 8.3.3.1 Beta
8.3.3.1 2019 01 22
http://sandbox.redfox.bz/SetupAnyDVD8331.exe
czary2mary 10.01.2019 18:45
Passkey 9.3.3.3 + DVDFab 11.0.1.4
Passkey 9.3.3.3
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
DVDFab 11.0.1.4
New: Introduced the brand-new non-linear video editing feature in the Video Converter module.
Fix: A crash problem when deleting previously saved custom profiles in the Ripper module.
Fix: A noise problem when playing back the resulting videos produced by the Video Converter module.
Fix: An audio ***** and distortion problem if the DTS tracks in the source videos are converted to AAC or AC3 by the Video Converter module.
Fix: A problem that the CRF encoding method does not work properly if VP9 is selected at the Advanced Settings > Video > Codec of the Video Converter module.
Fix: A problem that the file title is cut short after being handled by the DRM Removal module.
czary2mary 02.01.2019 19:57
DVDFab 11.0.1.1
New: Added the support for the 4K Ultra HD Blu-rays containing HDR10+ contents in the UHD Copy module.
New: Added the support for the 4K Ultra HD Blu-rays containing HDR10+ contents in the BDInfo tool.
Fix: A crash problem when converting iTunes movies with MKV Passthrough profile in certain cases.
Fix: A failure problem when converting MKV videos with Tivo profile.
czary2mary 26.12.2018 12:51
DVDFab 11.0.1.0 + Passkey 9.3.3.1
DVDFab 11.0.1.0
Fix: An opening failure problem on the bus encrypted Blu-ray discs.
Fix: A wrong color space problem when converting with profile MKV.4K.H265.12bit.
Passkey 9.3.3.1
czary2mary 22.12.2018 14:02
AnyDVD 8.3.3.0 + DVDFab 11.0.0.9 + Passkey 9.3.3.0
AnyDVD 8.3.3.0
8.3.3.0 2018 12 21
- Fix: AnyDVD's unique Cinavia fix did not work always with the latest build of PowerDVD 18
DVDFab 11.0.0.9
New: Introduced the Cloud Decryption Service 3.0 to improve the decryption speed on Blu-rays.
New: Added the MP4 Passthrough and MP4.4K.H365.10bit conversion profiles to the UHD Ripper module.
Fix: A problem that the number of copies behind the output destination box is missing under the Clone mode of the Copy module.
Fix: A problem that File Transfer does not launch up after the conversion finishes when outputting to mobile devices.
Fix: Some minor UI display issues.
Passkey 9.3.3.0
czary2mary 20.12.2018 19:56
AnyDVD 8.3.2.1 Beta
8.3.2.1 2018 12 20
http://sandbox.redfox.bz/SetupAnyDVD8321.exe
czary2mary 14.12.2018 18:56
AnyDVD 8.3.2.0
8.3.2.0 2018 12 14
- New: Added read error warning to status window
- Some minor fixes and improvements
czary2mary 14.12.2018 07:00
DVDFab 11.0.0.8
New: Added the support to choose how to display task queue at Common Settings > General.
New: Added the Copy Video option to MP4/MKV relevant conversion profiles at the Advanced Settings panel of Video Converter module.
Fix: A problem that the output size at the main interface is not remembered next time upon restart.
Fix: A problem that the created DVDs deliver no sound if the source videos contain 7.1 multi-channel audios.
czary2mary 10.12.2018 15:11
AnyDVD 8.3.1.0 + AnyDVD 8.3.1.1 Beta
AnyDVD 8.3.1.0
8.3.1.0 2018 12 05
- New: PowerDVD 12 build 8705 is now supported by AnyDVD's unique Cinavia fix
- New: PowerDVD 13 build 8703 is now supported by AnyDVD's unique Cinavia fix
- Note: AnyDVD's unique Cinavia fix dropped support for older PowerDVD 12 & 13 builds
The oldest supported PowerDVD 12 build is 5612
The oldest supported PowerDVD 13 build is 3919
- Fix (Blu-ray): Regression problem
AnyDVD 8.3.1.1 Beta
8.3.1.1 2018 12 08
http://sandbox.redfox.bz/SetupAnyDVD8311.exe
czary2mary 02.12.2018 12:07
DVDFab 11.0.0.7
New: Added the support for some new protections as found on certain DVDs produced by PBS.
New: Added the 12Bit support to certain MP4/MKV relevant conversion profiles in Ripper and Converter modules.
New: Added the support to preset output size at the Main Interface of Ripper and Converter modules.
Fix: A problem that the movie titles of certain Japanese discs are not displayed.
Fix: A problem that the edited title names in Ripper module are reverted if switching to Copy module and then switch back.
Fix: A conversion failure problem with MP4.passthrough profile in Video Converter module.
Fix: A conversion failure problem with certain AVI videos in DVD Creator module.
Fix: A conversion freeze problem with certain videos in DVD Creator module if external subtitles are added.
Fix: Improved the UI display under high DPI settings.
czary2mary 30.11.2018 02:42
Passkey 9.3.2.9
czary2mary 29.11.2018 17:15
DeUHD Ultra HD Blu-ray 1.0.3.8
1.0.3.8 11/28/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
https://www.deuhd.ru/download.html
Wszystkie czasy w strefie CET. Aktualna godzina: 12:52.
