-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 26.11.2018 02:23
DVDFab x64 10.2.0.6 + Passkey 9.3.2.8
DVDFab x64 10.2.0.6
New: Added the support to remove the Cinavia watermarks as found on the DVD version of The Commuter and the 4K Ultra HD version of The Fate of the Furious (Spanish edition) and The Huntsman: Winter***8217;s War.
New: Added a newly designed menu template in the Creator module named The Fleeting Meteor which can be downloaded from the Menu Library.
New: Added the support to predefine the output video quality in the Creator modules.
Fix: Improved the chapter preview experience.
Fix: Improved the UI for the UHD Creator module.
Fix: A problem that some video sources cannot open in certain cases.
Fix: A freeze problem when converting a Samsung demo ISO file using the MKV.4K.H265.10bit profile.
Fix: A problem that the cropping feature in the Ripper and Converter modules does not work properly in certain cases.
Fix: A problem that the AVI files produced by the Ripper modules have incorrect durations and do not play back.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64
Passkey 9.3.2.8
New: Added the support for some new Java protections.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
czary2mary 24.11.2018 10:51
AnyDVD (HD) 8.3.0.1 Beta
8.3.0.1 2018 11 23
- New (Blu-ray): Support for new discs
- Some minor fixes and improvements
http://sandbox.redfox.bz/SetupAnyDVD8301.exe
czary2mary 23.11.2018 05:09
DVDFab 11.0.0.5
New: Added the conversion profiles for Samsung Galaxy Tab S4, iPad Pro, Nokia 8/7.1/6.1/5/3.1/2 and Google Pixel 3/3 XL/2/2 XL in the Ripper and Converter modules.
New: Added the Deinterlacing Method option at Common Settings > Conversion > Convert.
Fix: A problem that the subtitles are placed at the top of the video screen after conversion.
Fix: A conversion failure problem when authoring DVDs from certain AVI videos.
Fix: Improved the File Transfer and the way to display the task queue.
Fix: Improved some UI display issues.
https://www.dvdfab.cn/download.htm
czary2mary 17.11.2018 09:12
Passkey 9.3.2.7
Fix: An activation failure problem for users from certain areas of Europe.
czary2mary 16.11.2018 07:32
DVDFab 11.0.0.4
New: Improved the UI display.
New: Added back the skin of Light of Hope.
New: Added the support to customize the way to display dialog/message boxes at Common Settings > General.
New: Added the DTS codec support to MP4 relevant profiles at the Audio section of Ripper and Video Converter modules.
Fix: An output oversize problem when shrinking certain Blu-rays to DVD5 size.
Fix: A noisy problem when playing back the MP4 videos converted by the Blu-ray Ripper module.
Fix: A problem that a 00099.m2ts file is created even No Menu option is selected while authoring Blu-rays.
Fix: A conversion failure problem when 2-pass encoding method is selected in the Video Converter module.
czary2mary 15.11.2018 09:01
DeUHD Ultra HD Blu-ray 1.0.3.7 + Passkey 9.3.2.6
1.0.3.7 11/12/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
Fixed crash issue.
https://www.deuhd.ru/download.html
Passkey 9.3.2.6
Fix: A problem that the default UI language switches to Traditional Chinese upon startup.
czary2mary 07.11.2018 06:17
DeUHD Ultra HD Blu-ray 1.0.3.6
1.0.3.6 11/05/2018
Fixed crash issue in last version.
https://www.deuhd.ru/download/DeUHD1036.exe
czary2mary 03.11.2018 08:36
Passkey 9.3.2.4
czary2mary 02.11.2018 09:37
DVDFab 11.0.0.2
New: Added the support to remove the Cinavia watermarks found on the following discs: Men In Black 3 (BD version) and Salt (BD version).
New: Added the support to display the detailed codec information for hardware accelerations.
New: Added the conversion profiles for iPhone XS, iPhone XS Max and iPhone XR in Ripper and Video Converter modules.
New: Improved the user experience of the File Transfer utility tool.
New: Improved the user experience of the DVDFab Remote utility tool.
New: Improved the Task Queue Manager when processing multiple tasks.
New: Improved some UI display problems.
Fix: A problem that Intel HD Graphics hardware acceleration cannot be enabled on NUC8i7HNK.
Fix: A problem that the desktop shortcut icon is created by default when updating via the Live Update feature.
Fix: A problem that user interface displays abnormally if switching the DPI setting to 150% or 175%.
Fix: A problem that the module user selected is not remembered upon next startup.
Fix: A problem that the Pattern value cannot be saved at Common Settings -> Conversion -> Output -> File Source.
Fix: A problem that DVDFab cannot burn to rewritable blank medium.
Fix: A problem that the ISO file creation process is not displayed when copying DVD and Blu-ray discs to ISO files.
Fix: A problem that certain Blu-rays are missing the DTS-HD MA 5.1 audios after being copied by the Blu-ray Copy module.
Fix: A problem that switching output path requires a program restart to take effect.
Fix: A problem that the videos converted from certain TS and WMV videos cannot playback.
Fix: A problem that the edited title name of previous season switches back after loading another season of the same TV show in Ripper modules.
Fix: A problem that the videos converted by the Video Converter module are missing the chapter markers.
Fix: A problem that the MKV 4K 10bit profile in the Video Converter module cannot passthrough Dolby Atmos audios.
Fix: A problem that the SRT subtitles are positioned at the top part of the screen after being converted by Video Converter module.
Fix: A problem that the Video Converter module produces incorrect file extensions in certain cases.
Fix: A problem that the function icons in the Menu templates of the Creator modules are missing.
Fix: A problem that changing names for Scenes in the Blu-ray Creator does not work.
Fix: A problem that the Blu-ray Creator created videos do not contain any subtitles if users add external subtitles or the source already contains internal subtitles.
czary2mary 28.10.2018 03:09
Passkey 9.3.2.3 + DVDFab 11.0.0.1
Passkey 9.3.2.3
New: Added the support for some new Japanese adult DVDs.
Fix: A crash problem when opening Blu-ray discs in certain cases.
DVDFab 11.0.0.1
A quick glance of the new features in DVDFab 11:
All-new flat design, brand-new user interface, plain and simple;
Redesigned prompt dialog floating in from the bottom of main interface;
Integrated the Task Queue Manager to the main interface;
Introduced the YouTube Uploader in Ripper and Converter modules, which allows users to upload the resulting videos directly to YouTube channel. Note: Please make sure your YouTube channel works normally and you've verified your account (if you want to upload videos longer than 15 mins) in YouTube before uploading the video.
Introduced the Mobile Video Loader to transfer videos from smartphones or tablets directly to DVDFab 11; improved the File Transfer to transfer the edited videos directly back to smartphones or tablets, WITHOUT THE DATA CABLE ANYMORE. Note: DVDFab Remote 1.2.3 is required on your smartphone or tablet, which is available in iOS App Store and Google Play.
Introduced the redesigned Video Edit feature in Ripper and Converter modules.
Introduced the all-new Turbo Conversion Engine that supports the latest HW acceleration technologies from NVIDIA, AMD and Intel.
Added the support to remove the Cinavia watermarks found on the following discs: Hotel Transylvania 2 (BD version), The Shack (2017 BD version), The Equalizer (2014 BD version) and Jason Bourne (4K UHD version).
Added the DTS codec support to the MKV/M2TS relevant profiles at the Audio section of the Advanced Settings panel.
Added the VP9/VP8 codec support to the MKV relevant profiles at the Video section of the Advanced Settings panel of Ripper and Converter modules.
Added the OPUS codec support to the MKV relevant profiles at the Audio section of the Advanced Settings panel of Ripper and Converter modules.
Fixed a low speed problem when outputting ISO files to NAS devices.
Fixed a problem that not all the user selected audio tracks are retained in the final results created by Blu-ray and UHD Creator modules.
x32
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB11
x64
czary2mary 23.10.2018 03:42
AnyDVD 8.3.0.0
8.3.0.0 2018 10 22
- New (DVD): Support for new discs
https://www.redfox.bz/download/SetupAnyDVD.exe
czary2mary 22.10.2018 10:23
Passkey 9.3.2.2 + AnyDVD 8.2.9.2 Beta
Passkey 9.3.2.2
AnyDVD 8.2.9.2 Beta
8.2.9.2 2018 10 19
http://sandbox.redfox.bz/SetupAnyDVD8292.exe
czary2mary 19.10.2018 05:15
DVDFab x64 11.0.0.0 beta
Introduced the Mobile Video Loader to transfer videos from smartphones or tablets directly to DVDFab 11; improved the File Transfer to transfer the edited videos directly back to smartphones or tablets, WITHOUT THE DATA CABLE ANYMORE. Note: DVDFab Remote 1.2.2 is required on your smartphone or tablet, which is available in iOS App Store and Google Play.
Some more improvements and changes.
Online Instalator (~3MB) :
http://download.dvdfab.cn/setup/DVDF...Downloader.exe
Pełny instalator exe.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB11_x64
czary2mary 16.10.2018 13:49
Passkey 9.3.2.1
New: Added the FW 1.00 support for LG***8217;s UHD drive BU40N.
Fix: A failure problem opening certain Blu-rays.
Fix: Improved some minor UI and prompt issues.
czary2mary 11.10.2018 01:49
DVDFab 10.2.1.7
New: Improved the support for the BluPath feature on Blu-rays and the PathPlayer feature on DVDs.
Fix: A crash problem when opening DVD discs in certain cases.
http://www.dvdfab.cn/download.htm
Wszystkie czasy w strefie CET. Aktualna godzina: 13:53.
