DVDFab 10.2.0.4
New: Added the support to remove the Cinavia watermark as found on the Blu-ray version of Acrimony.
Fix: A problem that the output result is oversized in the DVD Creator and Blu-ray to DVD Converter modules in certain cases. http://www.dvdfab.cn/download.htm |
AnyDVD 8.2.7.0
8.2.7.0 2018 07 21
- New: The latest build of PowerDVD 18 is now supported by AnyDVD's unique Cinavia fix - New: Less intrusive hooking of other applications. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs https://www.redfox.bz/download/SetupAnyDVD.exe |
Passkey 9.3.1.7
New: Added the support for some new Java protections.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DVDFab 10.2.0.1 + AnyDVD 8.2.6.4 Beta
DVDFab 10.2.0.1
New: Added the support for some new Java protections. New: Improved the support for the preview engine. New: Improved the support for the conversion engine. New: Improved the stability when converting with CPU decoder and encoder. New: Improved the conversion speed for copying and converting 3D Blu-rays. New: Completely redesigned the menu feature in the Blu-ray Creator module. New: Added the Setup function to the menu feature in the Blu-ray Creator module to allow users to set up audios and subtitles in menus. New: Added the support to save the customized menu template as default menu in the Blu-ray Creator module. New: Added the support to customize the video thumbnail of the menu template in the Blu-ray Creator module. New: Added the support to add custom widgets to the menu template in the Blu-ray Creator module. New: Added the support to return to menu if the selected title finishes playback in the Blu-ray Creator module. New: Added the support to preview the menu template in the Blu-ray Creator module. New: Added the Web Optimized option for the MP4 profile in the Video Converter module. New: Added the support to display scenes by list in the custom menu of the Creator module. Fix: A problem that the CPRM protected discs fail to rip on certain drives. Fix: A problem that the options to preselect default audios and subtitles do not work. Fix: Some minor changes and improvements. http://www.dvdfab.cn/download.htm AnyDVD 8.2.6.4 Beta 8.2.6.4 2018 07 19 - New: The latest build of PowerDVD 18 is now supported by AnyDVD's unique Cinavia fix - New: Less intrusive hooking of other applications. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs Contains many fixes for problems introduced in 8.2.6.1 and 8.2.6.2 Points to test: Does Cinavia removal still work? Does DiscID fixing still work for programs like MyMovies or DVD Profiler? Does Cinavia removal or DiscID fixing trigger any warnings by anti virus / anti malware programs? http://sandbox.redfox.bz/SetupAnyDVD8264.exe |
Passkey 9.3.1.6
New: Added the support to remove the country code of certain Blu-ray discs.
Fix: A problem that the CPRM protected discs fail to rip on certain drives. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD 8.2.6.3 Beta
8.2.6.3 2018 07 17
- New: Less intrusive hooking of other applications. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs Contains many fixes for problems introduced in 8.2.6.1 and 8.2.6.2 Points to test: Does Cinavia removal still work? Does DiscID fixing still work for programs like MyMovies or DVD Profiler? Does Cinavia removal or DiscID fixing trigger any warnings by anti virus / anti malware programs? http://sandbox.redfox.bz/SetupAnyDVD8263.exe |
DeUHD Ultra HD Blu-ray 1.0.3.3
1.0.3.3 07/16/2018
Applied new decryption method to speed up the process of opening new supported discs. Solved the decryption problem for AACS 2.1 protected discs when rip to hard disk in no driver installation way. Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
DVDFab 10.2.0.0 Beta + AnyDVD 8.2.6.2
New: Added the support for some new Java protections. New: Improved the support for the preview engine. New: Improved the support for the conversion engine. New: Improved the stability when converting with CPU decoder and encoder. New: Improved the conversion speed for copying and converting 3D Blu-rays. New: Added the support for AMD hardware acceleration when converting with 4K H264/H265 profiles. New: Completely redesigned the menu feature in the Blu-ray Creator module. New: Added the Setup function to the menu feature in the Blu-ray Creator module to allow users to set up audios and subtitles in menus. New: Added the support to save the customized menu template as default menu in the Blu-ray Creator module. New: Added the support to customize the video thumbnail of the menu template in the Blu-ray Creator module. New: Added the support to add custom widgets to the menu template in the Blu-ray Creator module. New: Added the support to return to menu if the selected title finishes playback in the Blu-ray Creator module. New: Added the support to preview the menu template in the Blu-ray Creator module. New: Added the support to convert HDR videos to MKV/MP4 SDR videos in the Video Converter module. New: Added the Web Optimized option for the MP4 profile in the Video Converter module. Fix: A problem that the options to preselect default audios and subtitles do not work. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA AnyDVD 8.2.6.2 8.2.6.2 2018 07 13 - New: Less intrusive hooking of other applications. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs http://sandbox.redfox.bz/SetupAnyDVD8262.exe |
Passkey 9.3.1.5
AnyDVD 8.2.6.1
8.2.6.1 2018 07 10
- New: Less intrusive hooking of other applications. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs http://sandbox.redfox.bz/SetupAnyDVD8261.exe |
Również zabezpieczenie BD+ bazuje na J http://www.makemkv.com/bdjava/ |
Java protections? Niby jak?
DVDFab 10.1.0.0
New: Added the support to remove the Cinavia watermarks from the Blu-ray versions of Early Man, Winchester and Tyler Perry's Boo 2! A Madea Halloween. New: Improved the support for the DVD PathPlayer. http://www.dvdfab.cn/download.htm |
Passkey 9.3.1.4
New: Added the support to reset the Blu-ray region code of PowerDVD 18. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DeUHD Ultra HD Blu-ray 1.0.3.2
1.0.3.2 07/02/2018
Added "Install DeUHD drive" installation option. Unchecking this option will still enable you to rip disc to ISO especially for some Windows 10 users who have "Error Installation" before. If you choose unchecking this option, please uninstall the old version and reboot first Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:01. |
