-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 09.05.2018 18:52
AnyDVD 8.2.4.10 beta
8.2.4.10 2018 05 09
- New (Blu-ray): Support for new discs
- New (Blu-ray): Added integrity check to AnyDVD ripper (unprotected image and folder)
- New (DVD): Support for new discs
- Fix (Blu-ray): Removal of UOPs can make some incorrectly mastered discs unplayable
- Fix (Blu-ray): Crash with discs created with an AnyDVD version without the previous fix
- Fix (Blu-ray): Bus decryption when creating protected images with some discs
- Fix (DVD): Crash with some discs
- Fix (DVD): Regression problem with some discs
- Fix (DVD): Playback problem with PowerDVD 17 & 18 with some discs
- Some minor fixes and improvements
http://sandbox.redfox.bz/SetupAnyDVD82410.exe
czary2mary 07.05.2018 19:14
AnyDVD 8.2.4.8 beta
8.2.4.8 2018 05 07
http://sandbox.redfox.bz/SetupAnyDVD8248.exe
czary2mary 05.05.2018 04:59
DVDFab 10.0.9.1 + AnyDVD 8.2.4.6 beta
DVDFab 10.0.9.1
New: Added the support for some new Java protections.
New: Added the support to remove the Cinavia protections as found on the DVD versions of The Glass Castle and the Pitch Perfect 3 and the Blu-ray versions of the All Eyez on Me, the Pitch Perfect 3 and the Last Flag Flying.
New: Removed the restriction that the free utility BDFix is available only to those who own a paid version of Blu-ray Copy.
New: Separated the Youtube Video Downloader from the Video Converter module and moved it to the Utilities tab as a free tool.
New: Added the support for the 2-pass encoding method if the video encoder is set to CUDA in the Ripper modules.
Fix: A problem that the sources in the Archived Task list cannot be reloaded to the Current Task list in certain cases.
Fix: A problem that the runtime is shortened when copying the 2D Blu-ray version of Blade Runner 2049 (Germany edition) in Main Movie mode.
Fix: A problem that two audio tracks appear in the output file even only one is selected in the Customize mode of the DVD Copy module.
Fix: A failure problem when converting BDAV discs to MP4/MKV videos in certain cases.
Fix: A problem that the "Display forced subtitle only" option is selected by default when Sweden subtitle is selected in the Ripper module.
Fix: A problem that nothing appears in the output directory when converting videos with hardware acceleration in certain cases.
Fix: Improved the UI support for 4K high DPI displays.
Fix: Some minor changes and improvements.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA
AnyDVD 8.2.4.6 beta
8.2.4.7 2018 05 04
http://sandbox.redfox.bz/SetupAnyDVD8247.exe
czary2mary 03.05.2018 05:58
AnyDVD 8.2.4.6
8.2.4.6 2018 05 02
http://sandbox.redfox.bz/SetupAnyDVD8246.exe
czary2mary 02.05.2018 08:47
AnyDVD 8.2.4.5
8.2.4.5 2018 04 30
- New (Blu-ray): Added integrity check to AnyDVD ripper (unprotected rips only)
http://sandbox.redfox.bz/SetupAnyDVD8245.exe
czary2mary 28.04.2018 20:46
Passkey 9.3.0.6
New: Added the support for the new Java protection as found on the Blu-ray Happy Birthday To Me (UK version).
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
czary2mary 27.04.2018 16:19
AnyDVD 8.2.4.4
8.2.4.4 2018 04 25
http://sandbox.redfox.bz/SetupAnyDVD8244.exe
czary2mary 20.04.2018 20:52
DVDFab 10.0.9.0 + Passkey 9.3.0.5
DVDFab 10.0.9.0
Fix: The problem that some Blu-ray discs cannot be opened in certain cases.
http://www.dvdfab.cn/download.htm
Passkey 9.3.0.5
New: Added the support to open the protected UHD ISO files from a virtual drive which are created by Passkey, DVDFab 10 or other 3rd party programs.
czary2mary 19.04.2018 04:52
AnyDVD 8.2.4.2 Beta
8.2.4.2 2018 04 18
http://sandbox.redfox.bz/SetupAnyDVD8242.exe
czary2mary 18.04.2018 11:54
DVDFab 10.0.8.9 + AnyDVD 8.2.4.0 + AnyDVD 8.2.4.1 Beta
DVDFab 10.0.8.9
New: Added the support to remove the Cinavia watermarks found on the Blu-ray versions of Jigsaw, My Little Pony: The Movie and Chappie.
New: Separated the Video Downloader feature from the Video Converter module and moved it under the Utilities tab.
Fix: A problem that the output file path cannot be opened via the folder icon in the DRM Removal module in certain cases.
Fix: A noisy problem when ripping Blu-rays with E-AC3 audio tracks in the Blu-ray Ripper module.
Fix: A problem that only the English language is accepted when entering the title descriptions at the Meta Collection area.
Fix: A problem that only one title can be played on certain media players when playing back a two-title output merged by the DVD Copy module.
Fix: A problem that the toggle button is not turned off when deleting the titles of a source in the DVD to Blu-ray module.
Fix: A problem that the file name of the external subtitles cannot be displayed.
Fix: A problem that the current conversion task is paused when deleting a waiting task from the task queue.
Fix: A problem that the File Transfer does not launch up after conversion if the video is trimmed.
Fix: A problem that the Buy Now button and the Shopping Cart are overlapped under high-resolution screens.
Fix: A problem that certain Xvid encoded videos cannot be opened in the Converter and Creator modules.
Fix: A problem that the duration is inaccurate when playing back the videos converted for Apple devices by the DVD Ripper module.
Fix: A problem that some BDAV discs cannot be opened in certain cases.
AnyDVD 8.2.4.0
8.2.4.0 2018 04 17
- New: PowerDVD 18 is now supported by AnyDVD's unique Cinavia fix
- Updated languages
https://www.redfox.bz/download/SetupAnyDVD.exe
AnyDVD 8.2.4.1 Beta
8.2.4.1 2018 04 17
http://sandbox.redfox.bz/SetupAnyDVD8241.exe
czary2mary 12.04.2018 05:21
AnyDVD 8.2.3.3 Beta +Passkey 9.3.0.3
AnyDVD 8.2.3.3 Beta
8.2.3.3 2018 04 11
- Updated languages
http://sandbox.redfox.bz/SetupAnyDVD8233.exe
Passkey 9.3.0.3
New: Added the support to remove the BD-J protection found on the Commuter.
New: Added the support to decrypt BDAV discs.
czary2mary 11.04.2018 07:10
AnyDVD 8.2.3.2 Beta
8.2.3.2 2018 04 10
- Updated languages
http://sandbox.redfox.bz/SetupAnyDVD8232.exe
czary2mary 10.04.2018 11:27
DeUHD Ultra HD Blu-ray 1.0.2.8
1.0.2.8 04/09/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
https://www.deuhd.ru/download.html
czary2mary 04.04.2018 06:55
AnyDVD 8.2.3.1 Beta
8.2.3.1 2018 04 03
- Updated languages
http://sandbox.redfox.bz/SetupAnyDVD8231.exe
czary2mary 03.04.2018 16:09
DVDFab 10.0.8.8 + Passkey 9.3.0.2
DVDFab 10.0.8.8 +
New: Added the support to remove the Cinavia watermarks found on the Blu-ray versions of the Sleight, Saban***8217;s Power Rangers and The Big Sick, and the DVD version of My Little Pony.
New: Ushered in the brand-new decryption technology to decrypt genuine 4K Ultra HD Blu-ray discs. (The disc can be opened but UHD Copy and UHD Ripper availabled only in DVDFab x64 version)
Fix: A problem that the size of the ISO file created by Blu-ray Creator is incorrect.
Fix: A problem that the estimated time for the conversion task is incorrect in the Ripper modules.
Passkey 9.3.0.2
New: Introduced the all new installation procedures. (Note: Installing this version shall automatically uninstall the previous version in the process, and upon the completion of the installation, a computer reboot is required.)
New: Ushered in the brand-new decryption technology to decrypt genuine 4K Ultra HD Blu-ray discs. (It's included in Passkey for Blu-ray option)
Wszystkie czasy w strefie CET. Aktualna godzina: 15:02.
