-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 02.09.2017 06:11
DVDFab 10.0.5.6 Beta
New: Added the support to save the video files converted by the Ripper module to DVDFab Movie Server.
New: Improved the features of the Screen Recorder & Editor for iOS.
Fix: Fixed the problem that HEVC encoding method is not supported after updating the driver of the AMD video card.
Fix: Fixed the crash problem caused by certain discs.
Fix: Fixed the crash problem when opening certain sources in DRM Removal for Apple.
Fix: Fixed the conversion failure problem in DRM Removal for Apple caused by some special characters in the output path.
Fix: Some minor changes and improvements.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA
czary2mary 30.08.2017 05:51
DVDFab 10.0.5.5
New: Added the support for some new Java protections.
New: Improved the trial user experience.
http://www.dvdfab.cn/download.htm
czary2mary 26.08.2017 08:12
DVDFab 10.0.5.4
czary2mary 19.08.2017 12:02
DVDFab 10.0.5.2 + AnyDVD 8.1.7.12 Beta
DVDFab 10.0.5.2
New: Added the support to remove Cinavia watermarks as found on the DVD versions of Hacksaw Ridge and La La Land.
New: Added the support to schedule a task in the Task Manager while doing conversions.
New: Added the support to remove the DVDFab watermark logo from the resulting files if the trial version is logged in with DVDFab account.
This version should fix the decryption problems of AnyDVD 8.1.7.9 - 8.1.7.11
8.1.7.12 2017 08 18
- New (Blu-ray): Support for new discs
- New (Blu-ray): Support for BD-R structural protection
- New (Blu-ray): Support for copy protection with read errors
- New (DVD): Support for new discs
- Change: Improved diskchange emulation in driver
- Change: Windows Vista 64 bit is no longer supported
Windows 7 64 bit only supported, if Service Pack 1 and
security update KB3033929 is installed
The installer will abort, if Vista 64 bit is detected or
if KB3033929 is not installed on Windows 7 64 bit.
This check can be disabled with the /NoSHA2check command
line parameter.
- Fix: Security exploit in driver
- Some minor fixes and improvements
http://sandbox.redfox.bz/SetupAnyDVD81712.exe
czary2mary 16.08.2017 07:17
AnyDVD 8.1.7.11 Beta
8.1.7.11 2017 08 14
line parameter.
http://sandbox.redfox.bz/SetupAnyDVD81711.exe
czary2mary 15.08.2017 20:43
AnyDVD 8.1.7.10 Beta
8.1.7.10 2017 08 13
line parameter.
http://sandbox.redfox.bz/SetupAnyDVD81710.exe
czary2mary 12.08.2017 17:22
Passkey 9.2.1.3
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
czary2mary 12.08.2017 06:27
AnyDVD 8.1.7.9 Beta
8.1.7.9 2017 08 10
line parameter.
http://sandbox.redfox.bz/SetupAnyDVD8179.exe
czary2mary 09.08.2017 07:26
AnyDVD 8.1.7.8 Beta
8.1.7.8 2017 08 08
line parameter.
http://sandbox.redfox.bz/SetupAnyDVD8178.exe
czary2mary 08.08.2017 06:29
AnyDVD 8.1.7.7 Beta
8.1.7.7 2017 08 06
- Change: Windows 7 64 bit only supported, if Service Pack 1 and
http://sandbox.redfox.bz/SetupAnyDVD8177.exe
czary2mary 06.08.2017 08:14
AnyDVD 8.1.7.6 Beta
8.1.7.6 2017 08 05
http://sandbox.redfox.bz/SetupAnyDVD8176.exe
czary2mary 05.08.2017 20:21
AnyDVD 8.1.7.5 Beta
8.1.7.5 2017 08 04
http://sandbox.redfox.bz/SetupAnyDVD8175.exe
czary2mary 04.08.2017 20:57
DVDFab 10.0.5.0 Beta + AnyDVD 8.1.7.4 Beta
New: Added the support to save the output ISO files directly to Movie Server in Main Movie mode of the Copy module.
Fix: Improved the support for the BDInfo utility.
AnyDVD 8.1.7.4 Beta
8.1.7.4 2017 08 03
http://sandbox.redfox.bz/SetupAnyDVD8174.exe
czary2mary 01.08.2017 19:50
AnyDVD 8.1.7.3 Beta
8.1.7.3 2017 07 31
http://sandbox.redfox.bz/SetupAnyDVD8173.exe
czary2mary 31.07.2017 08:57
DVDFab 10.0.4.9 + AnyDVD 8.1.7.0 \AnyDVD 8.1.7.1 Beta
DVDFab 10.0.4.9
New: Added the access point to correct metadata information for Movie Server in the drop-down menu of the output destination selection box.
Fix: Improved the support for detecting DVDFab Movie Server.
Fix: Fixed the problem that DVDFab failed to check the free space of Movie Server in certain cases.
8.1.7.0 2017 07 26
- New: Recent WinDVD 11 pro versions are now supported by AnyDVD's unique Cinavia fix
- New: WinDVD 12 pro is now supported by AnyDVD's unique Cinavia fix
- New (DVD): Remove AACS directory from discs containing Cinavia
- Fix (Blu-ray): Crash with some discs
- Fix (DVD): CSS brute force removal did not work with some drives
- Fix (DVD): Playback problems with some discs with WinDVD 11 & 12
https://www.redfox.bz/download/SetupAnyDVD.exe
AnyDVD 8.1.7.1 Beta 8.1.7.1 2017 07 27
http://sandbox.redfox.bz/SetupAnyDVD8171.exe
Wszystkie czasy w strefie CET. Aktualna godzina: 15:02.
