Zabezpieczenia CD/DVD/Blu-ray Forum związane z tematem zabezpieczania płyt i ich odbezpieczania :) Nie dotyczy zabezpieczeń filmów DVD (dział DVD Video). |
05.05.2018, 03:59 | #241 |
DVDFab 10.0.9.1 + AnyDVD 8.2.4.6 beta
DVDFab 10.0.9.1
New: Added the support for some new Java protections. New: Added the support to remove the Cinavia protections as found on the DVD versions of The Glass Castle and the Pitch Perfect 3 and the Blu-ray versions of the All Eyez on Me, the Pitch Perfect 3 and the Last Flag Flying. New: Removed the restriction that the free utility BDFix is available only to those who own a paid version of Blu-ray Copy. New: Separated the Youtube Video Downloader from the Video Converter module and moved it to the Utilities tab as a free tool. New: Added the support for the 2-pass encoding method if the video encoder is set to CUDA in the Ripper modules. Fix: A problem that the sources in the Archived Task list cannot be reloaded to the Current Task list in certain cases. Fix: A problem that the runtime is shortened when copying the 2D Blu-ray version of Blade Runner 2049 (Germany edition) in Main Movie mode. Fix: A problem that two audio tracks appear in the output file even only one is selected in the Customize mode of the DVD Copy module. Fix: A failure problem when converting BDAV discs to MP4/MKV videos in certain cases. Fix: A problem that the "Display forced subtitle only" option is selected by default when Sweden subtitle is selected in the Ripper module. Fix: A problem that nothing appears in the output directory when converting videos with hardware acceleration in certain cases. Fix: Improved the UI support for 4K high DPI displays. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA AnyDVD 8.2.4.6 beta 8.2.4.7 2018 05 04 - New (Blu-ray): Support for new discs - New (Blu-ray): Added integrity check to AnyDVD ripper (unprotected image and folder) - New (DVD): Support for new discs - Fix (Blu-ray): Removal of UOPs can make some incorrectly mastered discs unplayable - Fix (DVD): Crash with some discs - Fix (DVD): Regression problem with some discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8247.exe |
07.05.2018, 18:14 | #242 |
AnyDVD 8.2.4.8 beta
8.2.4.8 2018 05 07
- New (Blu-ray): Support for new discs - New (Blu-ray): Added integrity check to AnyDVD ripper (unprotected image and folder) - New (DVD): Support for new discs - Fix (Blu-ray): Removal of UOPs can make some incorrectly mastered discs unplayable - Fix (Blu-ray): Crash with discs created with an AnyDVD version without the previous fix - Fix (Blu-ray): Bus decryption when creating protected images with some discs - Fix (DVD): Crash with some discs - Fix (DVD): Regression problem with some discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8248.exe |
09.05.2018, 17:52 | #243 |
AnyDVD 8.2.4.10 beta
8.2.4.10 2018 05 09
- New (Blu-ray): Support for new discs - New (Blu-ray): Added integrity check to AnyDVD ripper (unprotected image and folder) - New (DVD): Support for new discs - Fix (Blu-ray): Removal of UOPs can make some incorrectly mastered discs unplayable - Fix (Blu-ray): Crash with discs created with an AnyDVD version without the previous fix - Fix (Blu-ray): Bus decryption when creating protected images with some discs - Fix (DVD): Crash with some discs - Fix (DVD): Regression problem with some discs - Fix (DVD): Playback problem with PowerDVD 17 & 18 with some discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD82410.exe |
12.05.2018, 05:06 | #244 |
Passkey 9.3.0.7
New: Added the support for the new Java protection as found on the Blu-ray My Little Pony.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
15.05.2018, 18:51 | #245 |
AnyDVD 8.2.5.0
8.2.5.0 2018 05 14
- New (Blu-ray): Support for new discs - New (Blu-ray): Added integrity check to AnyDVD ripper (unprotected image and folder) - New (DVD): Support for new discs - Fix (Blu-ray): Removal of UOPs can make some incorrectly mastered discs unplayable - Fix (Blu-ray): Crash with discs created with an AnyDVD version without the previous fix - Fix (Blu-ray): Bus decryption when creating protected images with some discs - Fix (DVD): Crash with some discs - Fix (DVD): Regression problem with some discs - Fix (DVD): Playback problem with PowerDVD 17 & 18 with some discs - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe |
19.05.2018, 05:20 | #246 |
Passkey 9.3.0.8
New: Added the support for the new Java protection as found on the Blu-ray Early Man, Deepwater Horizon, Hacksaw Ridge, The Expendables 3.
21.05.2018, 16:38 | #247 |
DeUHD Ultra HD Blu-ray 1.0.2.9
1.0.2.9 05/21/2018
To install the new version 1.0.2.9, you need to uninstall the old version and restart your computer first. Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Fixed ***8216;Errors on DeUHD installation***8217; for Windows 10 user. Largely increased ripping speed. Fixed get disc info error. Added German language.(Thanks for the contributor.) https://www.deuhd.ru/download.html |
26.05.2018, 05:24 | #248 |
DVDFab x64 10.0.9.3 Beta
New: Added the support to remove the Cinavia protection as found in the French audio track of the Blu-ray version of Pitch Perfect 2. New: Added the UHD to Blu-ray Converter module to downscale 4K Blu-rays to regular 1080p Blu-rays. New: Added the support to keep the wanted audio track in the Full Disc mode of the UHD Copy module. New: Added the MP4.SDR and MKV.SDR conversion profiles in the UHD Ripper module. Fix: A problem that the Blu-rays produced by the Full Disc mode of the Blu-ray Copy module cannot be reloaded to DVDFab. Fix: A problem that the same image appears twice when playing back the videos converted from certain BDMV sources in the Blu-ray Ripper module. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download....FAB10_x64_BETA |
01.06.2018, 21:30 | #249 |
DVDFab x64 10.0.9.5 + Passkey 9.3.0.9
DVDFab x64 10.0.9.5
New: Added the support for some new Java protections. New: Added the UHD Cinavia Removal module to remove the Cinavia protections from 4K Ultra HD Blu-rays. More Info: https://www.dvdfab.cn/uhd-cinavia-removal.htm New: Added the support to remove the Cinavia protection as found in the French audio track of the Blu-ray version of Pitch Perfect 2. New: Added the support to remove the Cinavia protections as found on 4K Ultra HD Blu-rays including Fifty Shades Darker, The Mummy (2017), Sing (2016), Gods of Egypt, The Secret Life of Pets (2016), Pitch Perfect 3 (2017), Everest (2015) and Minions (2015). More Info: https://blog.dvdfab.cn/cinavia-protection.html New: Added the UHD to Blu-ray Converter module to downscale 4K Blu-rays to regular 1080p Blu-rays. More Info: https://www.dvdfab.cn/uhd-to-blu-ray-converter.htm New: Added the support to keep the wanted audio track in the Full Disc mode of the UHD Copy module. New: Added the MP4.SDR and MKV.SDR conversion profiles in the UHD Ripper module. New: Added the support to display the downloading progress of the utilities and improved the interactive process. Fix: A failure problem when converting 4K UHD Blu-rays in certain cases. (Fixed for DVDFab x64 10.0.9.4) Fix: A problem that the Blu-rays produced by the Full Disc mode of the Blu-ray Copy module cannot be reloaded to DVDFab. Fix: A problem that the same image appears twice when playing back the videos converted from certain BDMV sources in the Blu-ray Ripper module. Fix: A problem that some 4K Ultra HD Blu-ray discs are identified as data discs in certain cases. Fix: A problem that the resizing feature of the task window does not work. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64 Passkey 9.3.0.9 New: Added the support for some new Java protections. New: Improved the support for 4K UHD Blu-rays. Fix: A problem that the Info section of the Settings panel displays incorrect Cinavia information of 4K UHD Blu-rays. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
08.06.2018, 04:23 | #250 |
DVDFab 10.0.9.6 Beta
Fix: Improved the support for the software H.265 video encoder. Fix: A problem that the crop feature in the Ripper module does not work properly if the AMD APP Lightning-Shrink is enabled. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
09.06.2018, 10:10 | #251 |
Passkey 9.3.1.0
11.06.2018, 13:14 | #252 |
DeUHD Ultra HD Blu-ray 1.0.3.0
Lekarstwo na AACS 2.1
1.0.3.0 06/11/2018 Supported AACS 2.1. e.g. Fury. (To play the disc, need to Rip to ISO or hard disc with DeUHD 1.0.3.0, and will support to play it directly soon.) Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
14.06.2018, 14:26 | #253 |
DVDFab 10.0.9.7 + Passkey 9.3.1.1
DVDFab 10.0.9.7
New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermark from the DVD version of Winchest. New: Added the support to remove Cinavia watermarks from AC3 audio tracks of Blu-rays. New: Added the support for the .webm files in the Video Converter and Creator modules. Fix: Improved the support for the YouTube Video Downloader utility. Fix: Improved the support for the software H.265 video encoder. Fix: A problem that the subtitles are improperly positioned after converting Blu-rays using the 3D.MKV profile. Fix: A problem that the crop feature in the Ripper module does not work properly if the AMD APP Lightning-Shrink is enabled. Fix: A problem that DVDFab burning engine is not available in certain cases. http://www.dvdfab.cn/download.htm Passkey 9.3.1.1 New: Added the support for some new Java protections. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
17.06.2018, 02:59 | #254 |
DVDFab 10.0.9.8 Beta + Passkey 9.3.1.2
New: Added the support for the new protection as found on the DVD version of I Can Only Imagine. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA Passkey 9.3.1.2 New: Added the support for the new protection as found on the DVD version of I Can Only Imagine. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
19.06.2018, 13:35 | #255 |
DeUHD Ultra HD Blu-ray 1.0.3.1
1.0.3.1 06/18/2018
Supported AACS 2.1 protected disc The Patriot. (To play the disc, need to Rip to ISO or hard disc with DeUHD 1.0.3.1, and will support to play it directly soon.) Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
Tagi |
blu-ray, kopia, kopiowanie, płyta, płyta blu-ray |
Podobne dyskusje | ||||
nagrywanie płyt Bluray | macies | High Definition | 20 | 05.01.2017 07:45 |
Problem z odczytem starszych płyt dvd+r - dziwny przypadek - ogromna prośba o pomoc.. | ivesher | Napędy optyczne DVD | 9 | 25.01.2011 10:12 |
Jak zmusić 1633S do odczytu nagranych przez siebie płyt DVD-R? | MKJ | Napędy optyczne DVD | 12 | 19.03.2005 23:20 |
Cześć.potrzebuje kopie EEPROMA do LiteONa 1633S . po przeróbce na 1653 nie czyta płyt | tom106 | Napędy optyczne DVD | 3 | 07.12.2004 06:40 |
Szukam płyt poniżej 1 zł (kontaktu do producenta CD-R) | VVirOOs | Napędy optyczne CD | 15 | 20.03.2002 21:16 |
