AnyDVD HD 8.0.3.0
https://www.redfox.bz/download/SetupAnyDVD.exe
8.0.3.0 2016 06 22 ***8226;New (Blu-ray): Added subtitle vertical border option for 21:9 displays or constant image height projection setups ***8226;New (Blu-ray): Added subtitle transparency option for home theater setups ***8226;New (Blu-ray): Added subtitle movement option ***8226;New (Blu-ray): Added subtitle placement preset for 16:9 subtitles on 21:9 display ***8226;New (Blu-ray): Added subtitle placement preset for 21:9 subtitles on 16:9 display ***8226;New (Blu-ray): Improved ScreenPass support ***8226;New (Blu-ray): Allow modifications (region lock, annoyances, ...) with copies ***8226;New (Blu-ray): Driver uses much less memory ***8226;New (Blu-ray): Support for new discs ***8226;New (DVD): Support for new discs ***8226;New: With most computers a reboot is no longer required after driver installation ***8226;New: Show hour difference, if computer clock is not set correctly ***8226;Some minor fixes and improvements ***8226;Updated languages |
AnyDVD HD 8.0.2.4 Beta
8.0.2.4 2016 06 17 New (Blu-ray): Added subtitle vertical border option for 21:9 displays or constant image height projection setups New (Blu-ray): Added subtitle transparency option for home theater setups New (Blu-ray): Added subtitle movement option New (Blu-ray): Added subtitle placement preset for 16:9 subtitles on 21:9 display New (Blu-ray): Added subtitle placement preset for 21:9 subtitles on 16:9 display New (Blu-ray): Improved ScreenPass support New (Blu-ray): Allow modifications (region lock, annoyances, ...) with copies New (Blu-ray): Driver uses much less memory New (Blu-ray): Support for new discs New (DVD): Support for new discs New: With most computers a reboot is no longer required after driver installation New: Show hour difference, if computer clock is not set correctly Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8024.exe |
drugie konto?
Cinavia
Chodzi mi o to że jednak RedFox ma dalej kłopoty i problemy i nie sądzę aby firmy typu Hollywood i inne molochy tak łatwo odpuściły .:nie::P:D:> |
Nie za bardzio widzie jakie problemy, pora zmienic bank albo wyminic karte na VISA :P
Cinavia
Czyżby ponownie zbliżają się kłopoty dla RedFox ? |
AnyDVD 8.0.2.3 Beta
http://sandbox.redfox.bz/SetupAnyDVD8023.exe
8.0.2.3 2016 06 09 - New (Blu-ray): Support for new discs - New (Blu-ray): Improved ScreenPass support - New (Blu-ray): Allow modifications (region lock, annoyances, ...) with copies - New (DVD): Support for new discs - Some minor fixes and improvements |
RedFox \ AnyDVD HD
Ale też trudno od chłopaków którzy to przejęli wymagać żeby honorowali zobowiązania SlySoft .. Ale z tego co wiem to część licencji jest honorowanych\wymienianych a część otrzymuje kupony indywidualne ze zniżką na 50% Załącznik 78631 |
Ilość załączników: 2
AnyDVD 8.0.1.0
https://www.redfox.bz/download.html
Jest już wersja finalna \ale nie zaczął jeszcze działać nowy system sprzedaży i licencjonowania produktów. Ważna informacja dla posiadaczy licencji SlySoft! Licencje SlySoft na produkt AnyDVD (HD) będą działać do wersji 7.9.6.5 programu. RedFox OPD (Baza Zabezpieczeń Online) dla tej wersji będzie dostępna do dnia wtorek, 31 maja 2016, po tym czasie AnyDVD HD nie będzie w stanie dłużej deszyfrować nośników. Licencje SlySoft na inne produkty nie podlegają tej kwestii i będą działać prawidłowo. Załącznik 78572 Załącznik 78573 |
AnyDVD 8.0.0.3 beta
AnyDVD 8.0.0.2 beta
Pierwsze bety licencjonowane przez RedFox (nie działają stare licencje SlySoft)
Wersja AnyDVD 8.0.0.1 http://sandbox.redfox.bz/anydvd/SetupAnyDVD8000beta.exe Można poprosić o 21 klucz Trial...:) Załącznik 78430 |
30 kwietnia niebawem. Jestem ciekaw jakie to warunki licencjonowania przedstawi strona
RedFox ? |
| Wszystkie czasy w strefie CET. Aktualna godzina: 05:05. |
