-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DeUHD Ultra HD Blu-ray (https://forum.cdrinfo.pl/f11/deuhd-ultra-hd-blu-ray-96709/)
czary2mary 02.01.2018 18:15
DeUHD Ultra HD Blu-ray 1.0.1.4
1.0.1.4 01/01/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
Set the last rip output path as the default.
Raised two discs limitation to six discs/day for Lifetime users.
https://www.deuhd.ru/download.html
czary2mary 25.12.2017 19:20
DeUHD Ultra HD Blu-ray 1.0.1.3
1.0.1.3 12/25/2017
czary2mary 19.12.2017 12:40
DeUHD Ultra HD Blu-ray 1.0.1.2
1.0.1.2 12/18/2017
Friendly UHD drive reading date is unstable. To ensure the data is read correctly, added the data validation when copying to Hard Disk.
Added French, Korean, Simplified Chinese and Traditional Chinese language.(Thanks for the contributors.)
czary2mary 12.12.2017 14:53
DeUHD Ultra HD Blu-ray v.1011
Improved the stability of network connection.
https://deuhd.ru/download.html
loki7777 06.12.2017 16:57
Teraz ok:)
grzeniu 06.12.2017 16:56
A teraz? Wg mnie działa.
loki7777 06.12.2017 16:47
Na koncu linku jest wciaz 9.
misiozol 06.12.2017 16:44
link nie dziala, probowalem naprawic ale ciagle nie dziala daje 404 :hmm:
czary2mary 06.12.2017 12:08
DeUHD Ultra HD Blu-ray v.1010
DeUHD History
1.0.1.0 12/05/2017
Support some new discs, check the details from https://www.deuhd.ru/4k_uhd_info.html
czary2mary 13.11.2017 18:29
DeUHD Ultra HD Blu-ray v.1007
Added "Create an Account" option in the right click menu of the system tray icon
Improved the decryption process.
https://www.deuhd.ru/download/DeUHD1007.exe
czary2mary 07.11.2017 11:23
DeUHD Ultra HD Blu-ray v1.006
1.0.0.6 11/06/2017
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html11
Solved some crash problems.
Updated 15 discs on Nov. 06.
https://www.deuhd.ru/download/DeUHD1006.exe
czary2mary 31.10.2017 06:54
DeUHD Ultra HD Blu-ray v1.005
1.0.0.5 10/30/2017
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html4
Speed up the rip speed.
Solved the problem that cannot register with some email format.
To install the new version 1.0.0.5, you need to uninstall the old version and restart your computer first.
https://www.deuhd.ru/download/DeUHD1005.exe
czary2mary 24.10.2017 13:09
DeUHD Ultra HD Blu-ray v1.004
1.0.0.4 10/23/2017
Support to check for update.
https://www.deuhd.ru/download/DeUHD1004.exe
czary2mary 17.10.2017 09:24
DeUHD Ultra HD Blu-ray v1.003
1.0.0.3 10/16/2017
Solved the problem that cannot rip to ISO sometimes.
http://deuhd.ru/download/DeUHD1003.exe
czary2mary 09.10.2017 21:06
DeUHD Ultra HD Blu-ray v1.002
Aktualizacja:
http://deuhd.ru/download/DeUHD1002.exe
The changelog is in:
Support to try 3 discs in trial version.
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html (dodano 10 nowych tytułów)
Decrypt all the m2ts files 8~10 minutes in the trial version, means that you can watch the movie with the navigation menu.
Improved the rip speed in trial version.
Wszystkie czasy w strefie CET. Aktualna godzina: 04:12.
