Stary 19.10.2018, 04:17   #61
DVDFab x64 11.0.0.0 beta
A quick glance of the new features in DVDFab 11:
All-new flat design, brand-new user interface, plain and simple;
Redesigned prompt dialog floating in from the bottom of main interface;
Integrated the Task Queue Manager to the main interface;
Introduced the YouTube Uploader in Ripper and Converter modules, which allows users to upload the resulting videos directly to YouTube channel. Note: Please make sure your YouTube channel works normally and you've verified your account (if you want to upload videos longer than 15 mins) in YouTube before uploading the video.
Introduced the Mobile Video Loader to transfer videos from smartphones or tablets directly to DVDFab 11; improved the File Transfer to transfer the edited videos directly back to smartphones or tablets, WITHOUT THE DATA CABLE ANYMORE. Note: DVDFab Remote 1.2.2 is required on your smartphone or tablet, which is available in iOS App Store and Google Play.
Introduced the redesigned Video Edit feature in Ripper and Converter modules.
Introduced the all-new Turbo Conversion Engine that supports the latest HW acceleration technologies from NVIDIA, AMD and Intel.
Some more improvements and changes.
Online Instalator (~3MB) :
http://download.dvdfab.cn/setup/DVDF...Downloader.exe
Pełny instalator exe.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB11_x64
Stary 22.10.2018, 09:21   #62
Passkey 9.3.2.2
New: Added the support for some new Java protections.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Stary 28.10.2018, 02:10   #63
Passkey 9.3.2.3 + DVDFab 11.0.0.1
Passkey 9.3.2.3
New: Added the support for some new Japanese adult DVDs.
Fix: A crash problem when opening Blu-ray discs in certain cases.
DVDFab 11.0.0.1
Introduced the Mobile Video Loader to transfer videos from smartphones or tablets directly to DVDFab 11; improved the File Transfer to transfer the edited videos directly back to smartphones or tablets, WITHOUT THE DATA CABLE ANYMORE. Note: DVDFab Remote 1.2.3 is required on your smartphone or tablet, which is available in iOS App Store and Google Play.
Added the support to remove the Cinavia watermarks found on the following discs: Hotel Transylvania 2 (BD version), The Shack (2017 BD version), The Equalizer (2014 BD version) and Jason Bourne (4K UHD version).
Added the DTS codec support to the MKV/M2TS relevant profiles at the Audio section of the Advanced Settings panel.
Added the VP9/VP8 codec support to the MKV relevant profiles at the Video section of the Advanced Settings panel of Ripper and Converter modules.
Added the OPUS codec support to the MKV relevant profiles at the Audio section of the Advanced Settings panel of Ripper and Converter modules.
Fixed a low speed problem when outputting ISO files to NAS devices.
Fixed a problem that not all the user selected audio tracks are retained in the final results created by Blu-ray and UHD Creator modules.
x32
x64
Stary 03.11.2018, 06:36   #64
Passkey 9.3.2.4
Stary 08.11.2018, 03:53   #65
DVDFab 11.0.0.3 + Passkey 9.3.2.5
DVDFab 11.0.0.3
New: Introduced the DVDFab Prime Member service.
More Info: https://www.dvdfab.cn/promotion.htm
New: Improved the speed under CUDA hardware acceleration.
New: Added more CRF value options at the Encoding Method section of the Advanced Settings panel of Ripper and Converter modules.
New: Added the support to set the custom bit rate as 100MB at the Advanced Settings panel when choosing 4K relevant conversion profiles.
New: Added the support to change the frame rate at the Advanced Settings panel of Blu-ray and UHD Ripper modules.
Fix: A problem that the Cinavia watermark of Salt (BD version from Canada) cannot be removed.
Fix: A country code removal problem in certain cases.
Fix: A subtitles rendering failure problem on certain seasonal discs.
Fix: A conversion failure problem when selecting 2-pass Encoding Method in Ripper and Converter modules.
Fix: A problem that the Mobile Device cannot be selected as output destination when conversion profiles related to Apple devices are selected.
Fix: A problem that the YouTube to MP3 utility does not work in certain cases.
Fix: Some minor video transfer issues caused by the connection problem between File Transfer and DVDFab Remote.
https://www.dvdfab.cn/download.htm
Passkey 9.3.2.5
Stary 15.11.2018, 07:02   #66
Passkey 9.3.2.6
Fix: A problem that the default UI language switches to Traditional Chinese upon startup.
Stary 16.11.2018, 05:34   #67
DVDFab 11.0.0.4
New: Improved the UI display.
New: Added back the skin of Light of Hope.
New: Added the support to customize the way to display dialog/message boxes at Common Settings > General.
New: Added the DTS codec support to MP4 relevant profiles at the Audio section of Ripper and Video Converter modules.
Fix: An output oversize problem when shrinking certain Blu-rays to DVD5 size.
Fix: A noisy problem when playing back the MP4 videos converted by the Blu-ray Ripper module.
Fix: A problem that a 00099.m2ts file is created even No Menu option is selected while authoring Blu-rays.
Fix: A conversion failure problem when 2-pass encoding method is selected in the Video Converter module.
Stary 17.11.2018, 07:13   #68
Passkey 9.3.2.7
Fix: An activation failure problem for users from certain areas of Europe.
Stary 23.11.2018, 03:10   #69
DVDFab 11.0.0.5
New: Added the conversion profiles for Samsung Galaxy Tab S4, iPad Pro, Nokia 8/7.1/6.1/5/3.1/2 and Google Pixel 3/3 XL/2/2 XL in the Ripper and Converter modules.
New: Added the Deinterlacing Method option at Common Settings > Conversion > Convert.
Fix: A problem that the subtitles are placed at the top of the video screen after conversion.
Fix: A conversion failure problem when authoring DVDs from certain AVI videos.
Fix: Improved the File Transfer and the way to display the task queue.
Fix: Improved some UI display issues.
Stary 26.11.2018, 00:23   #70
DVDFab x64 10.2.0.6 + Passkey 9.3.2.8
DVDFab x64 10.2.0.6
New: Added the support to remove the Cinavia watermarks as found on the DVD version of The Commuter and the 4K Ultra HD version of The Fate of the Furious (Spanish edition) and The Huntsman: Winter***8217;s War.
New: Added a newly designed menu template in the Creator module named The Fleeting Meteor which can be downloaded from the Menu Library.
New: Added the support to predefine the output video quality in the Creator modules.
Fix: Improved the chapter preview experience.
Fix: Improved the UI for the UHD Creator module.
Fix: A problem that some video sources cannot open in certain cases.
Fix: A freeze problem when converting a Samsung demo ISO file using the MKV.4K.H265.10bit profile.
Fix: A problem that the cropping feature in the Ripper and Converter modules does not work properly in certain cases.
Fix: A problem that the AVI files produced by the Ripper modules have incorrect durations and do not play back.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64
Passkey 9.3.2.8
Stary 30.11.2018, 00:43   #71
Passkey 9.3.2.9
Stary 02.12.2018, 10:08   #72
DVDFab 11.0.0.7
New: Added the support for some new protections as found on certain DVDs produced by PBS.
New: Added the 12Bit support to certain MP4/MKV relevant conversion profiles in Ripper and Converter modules.
New: Added the support to preset output size at the Main Interface of Ripper and Converter modules.
Fix: A problem that the movie titles of certain Japanese discs are not displayed.
Fix: A problem that the edited title names in Ripper module are reverted if switching to Copy module and then switch back.
Fix: A conversion failure problem with MP4.passthrough profile in Video Converter module.
Fix: A conversion failure problem with certain AVI videos in DVD Creator module.
Fix: A conversion freeze problem with certain videos in DVD Creator module if external subtitles are added.
Fix: Improved the UI display under high DPI settings.
Stary 14.12.2018, 05:02   #73
DVDFab 11.0.0.8
New: Added the support to choose how to display task queue at Common Settings > General.
New: Added the Copy Video option to MP4/MKV relevant conversion profiles at the Advanced Settings panel of Video Converter module.
Fix: A problem that the output size at the main interface is not remembered next time upon restart.
Fix: A problem that the created DVDs deliver no sound if the source videos contain 7.1 multi-channel audios.
Fix: Some minor UI display issues.
Stary 22.12.2018, 12:02   #74
DVDFab 11.0.0.9 + Passkey 9.3.3.0
DVDFab 11.0.0.9
New: Introduced the Cloud Decryption Service 3.0 to improve the decryption speed on Blu-rays.
New: Added the MP4 Passthrough and MP4.4K.H365.10bit conversion profiles to the UHD Ripper module.
Fix: A problem that the number of copies behind the output destination box is missing under the Clone mode of the Copy module.
Fix: A problem that File Transfer does not launch up after the conversion finishes when outputting to mobile devices.
Passkey 9.3.3.0
Stary 26.12.2018, 10:52   #75
DVDFab 11.0.1.0 + Passkey 9.3.3.1
DVDFab 11.0.1.0
Fix: An opening failure problem on the bus encrypted Blu-ray discs.
Fix: A wrong color space problem when converting with profile MKV.4K.H265.12bit.
Passkey 9.3.3.1
Pomoc w wyborze najlepszego TV UHD 4K misiozol Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) 6 05.12.2016 17:23
Błagam o wsparcie dla mojego syna ilona-lackowska Off topic 114 01.04.2007 14:52
Mandat za parkowanie w miejscu dla osoby niepełnosprawnej... przez inwalidę... woitas Off topic 26 28.07.2006 08:41
Dla Was.. i dla Ciebie Kochanie... Martin_TP Off topic 13 10.03.2003 17:38
Wszystkie czasy w strefie CET. Aktualna godzina: 09:14.
