Stary 30.12.2021, 10:39   #226
DVDFab 12.0.5.7 + DVDFab Passkey 9.4.2.7
DVDFab 12.0.5.7
https://www.dvdfab.cn/download.htm
DVDFab 12.0.5.7 Changelog
Fix: A failure problem when loading videos from the OneDrive directory.
Fix: A failure problem when saving the changes after resetting the directory of log files in the Settings panel.
Fix: A failure problem when opening the output directory after the conversion finishes in the Blu-ray Creator module.
Fix: A problem that the menu settings cannot be remembered in the Creator modules.
https://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Passkey 9.4.2.7 Changelog
New: Added the support for some new Java protections.
Stary 06.01.2022, 06:16   #227
DVDFab Passkey 9.4.2.8
Passkey 9.4.2.8 Changelog
Stary 13.01.2022, 11:32   #228
DVDFab Passkey 9.4.2.9
Passkey 9.4.2.9 Changelog
Stary 21.01.2022, 09:40   #229
DVDFab 12.0.5.8 + DVDFab Passkey 9.4.3.0
DVDFab 12.0.5.8
DVDFab 12.0.5.8 Changelog
New: Added the H265 encoding support when converting videos with the TS conversion profile in the Video Converter module.
New: Some improvements on GUI display under higher DPI settings.
Fix: A problem that the live update window still pops up after uninstalling all the DVDFab related products.
Fix: A problem that the text introduction in the Streaming menu template of the Blu-ray Creator module can be manually removed.
Fix: A problem that the cloned ISO files of the 4K Blu-rays recorded by Panasonic DMR-4CW200 cannot play back.
Passkey 9.4.3.0 Changelog
New: Added support for some new Java protections.
Stary 29.01.2022, 09:43   #230
DVDFab Passkey 9.4.3.1
Passkey 9.4.3.1 Changelog
Stary 10.02.2022, 11:45   #231
DVDFab 12.0.6.1
DVDFab 12.0.6.1 Changelog
Fix: A failure problem when copying certain Japanese DVDs in the Full Disc mode of the DVD Copy module.
Fix: A problem that Japanese subtitles contain messy codes after burning to BD discs.
Stary 17.02.2022, 10:50   #232
DVDFab 12.0.6.2
DVDFab 12.0.6.2 Changelog
Fix: A startup crash problem due to altered DVDFab host information in the system hosts file.
Fix: A startup crash problem on machines installed with AMD Radeon RX 480 video card.
Fix: A subtitle display problem after burning the videos downloaded from Netflix to BD25 discs in the Blu-ray Creator module.
Stary 10.03.2022, 09:13   #233
DVDFab 12.0.6.4
DVDFab 12.0.6.4 Changelog
New: Added support to enable IQS (Intel Quick Sync) hardware acceleration with the 12th-gen Intel CPUs.
Fix: A crash problem when cropping the Tubi videos downloaded with StreamFab in certain cases.
Stary 24.03.2022, 09:25   #234
DVDFab 12.0.6.7
DVDFab 12.0.6.7 Changelog
Stary 03.04.2022, 08:03   #235
DVDFab 12.0.6.8 + DVDFab Passkey 9.4.3.3
DVDFab 12.0.6.8
DVDFab 12.0.6.8 Changelog
Passkey 9.4.3.3 Changelog
Stary 26.04.2022, 09:53   #236
DVDFab 12.0.7.1 + DVDFab Passkey 9.4.3.5
DVDFab 12.0.7.1
DVDFab 12.0.7.1 Changelog
Fix: An update failure problem in certain cases.
Fix: A crash problem when making DVDs with certain video files in the DVD Creator module.
Passkey 9.4.3.5 Changelog
Stary 25.05.2022, 13:06   #237
DVDFab 12.0.7.3 + DVDFab Passkey 9.4.3.6
DVDFab 12.0.7.3
DVDFab 12.0.7.3 Changelog
New: Added a new Enlarger AI training model Real-CUGAN in the Ripper and Converter modules.
New: Added the M2TS Passthrough conversion profile in the Video Converter module.
Passkey 9.4.3.6 Changelog
Stary 03.06.2022, 11:35   #238
DVDFab Passkey 9.4.3.7
Passkey 9.4.3.7 Changelog
Stary 24.06.2022, 19:23   #239
DVDFab 12.0.7.5 + DVDFab Passkey 9.4.3.8
DVDFab 12.0.7.5
DVDFab 12.0.7.5 Changelog
Fix: A freeze problem when using the Enlarger AI module to upscale the VOB videos recorded by VHS camera devices.
Fix: A crash problem when loading more than 6 DVD sources in the DVD to Blu-ray Converter module.
Fix: A problem that the output Blu-rays created by the Blu-ray Creator module only display one line of subtitles despite there are two lines in the source files.
Fix: A problem that the output M2TS videos converted from MP4 videos by the Video Converter module cannot play back normally.
Passkey 9.4.3.8 Changelog
Stary 08.07.2022, 13:11   #240
DVDFab 12.0.7.7 + DVDFab Passkey 9.4.3.9
DVDFab 12.0.7.7
DVDFab 12.0.7.7 Changelog
Passkey 9.4.3.9 Changelog
Opcje związane z dyskusją
Tryby wyświetlania
Pomoc w wyborze najlepszego TV UHD 4K misiozol Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) 6 05.12.2016 18:23
Błagam o wsparcie dla mojego syna ilona-lackowska Off topic 114 01.04.2007 15:52
Mandat za parkowanie w miejscu dla osoby niepełnosprawnej... przez inwalidę... woitas Off topic 26 28.07.2006 09:41
Dla Was.. i dla Ciebie Kochanie... Martin_TP Off topic 13 10.03.2003 18:38
Wszystkie czasy w strefie CET. Aktualna godzina: 12:58.
