-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DVDFab Passkey \ DVDFab otrzymuje wsparcie dla UHD \ 4K (https://forum.cdrinfo.pl/f11/dvdfab-passkey-dvdfab-otrzymuje-wsparcie-dla-uhd-4k-96911/)
czary2mary 12.07.2020 10:04
DVDFab 11.0.9.7 + DVDFab Passkey 9.3.9.2
DVDFab 11.0.9.7
https://www.dvdfab.cn/download.htm
DVDFab 11.0.9.7 Changelog
New: Added two new Enlarger AI training models Deblock and Ultra+Deblock in Ripper, Video Converter and DVD to Blu-ray Converter modules.
New: Added the feature to preset AI profiles in Ripper modules at Common Settings > Profiles > Set Profiles for Enlarger AI.
New: Improved the support for the profile preset feature. DVDFab may ask you to reset it again if you used to set profiles in ver. 11.0.9.2 or older.
New: Renamed the default output name for TV Shows from s0xe0x to S0xE0x.
Fix: A problem that html appears in the Task Queue Log viewer.
Fix: Some minor translation problems.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Passkey 9.3.9.2 Changelog
New: Added the support for some new Java protections.
czary2mary 05.07.2020 07:52
DVDFab 11.0.9.6 + DVDFab Passkey 9.3.9.1
DVDFab 11.0.9.6
DVDFab 11.0.9.6 Changelog
Fix: A crash problem when opening sources in certain cases.
Passkey 9.3.9.1 Changelog
Fix: A problem that the default display language is Spanish despite the system language being English.
czary2mary 03.07.2020 05:56
DVDFab 11.0.9.5
New! DVDFab 11.0.9.5 is out (July 02, 2020)
DVDFab 11.0.9.5 Changelog
New: Added the support to upscale videos with Enlarger AI on PCs installed with the 10th generation Intel i9 CPUs.
New: Added the support to automatically switch to CPU to convert again in case the conversion with hardware acceleration fails.
Fix: A problem that the movie name in the Video Converter module is not updated after applying the metadata to the loaded source using the Search Movie/TV feature.
Fix: A conversion failure problem in the Video Converter module in certain cases.
czary2mary 23.06.2020 06:15
DVDFab 11.0.9.4
DVDFab 11.0.9.4 Changelog
Fix: A problem that the auto update does not work.
czary2mary 21.06.2020 20:52
DVDFab 11.0.9.3 + Passkey 9.3.9.0
DVDFab 11.0.9.3
DVDFab 11.0.9.3 Changelog
New: Improved the profile preset feature.
Fix: A problem that only one copy is made despite the copy quantity is set to 10.
Fix: A conversion failure problem in the Ripper modules if the output path contains some special characters.
Fix: A problem that the estimated output size is wrong if Audio Copy is selected in the Ripper modules.
Passkey 9.3.9.0
Passkey 9.3.9.0 Changelog
czary2mary 18.06.2020 07:22
DVDFab 11.0.9.2
DVDFab 11.0.9.2 Changelog
Fix: A crash problem when converting DVD/Blu-ray discs to MP4/MKV videos in certain cases.
czary2mary 06.06.2020 06:33
DVDFab 11.0.9.0 + Passkey 9.3.8.8
DVDFab 11.0.9.0
DVDFab 11.0.9.0 Changelog
New: Improved the Preset Profile feature in the Ripper modules.
New: Improved the default output video bitrate.
Fix: A problem that ***8220;temp***8221; appears in the output file titles if Remux SRT is selected when outputting MKV videos.
Passkey 9.3.8.8
czary2mary 04.06.2020 05:42
Passkey 9.3.8.7
czary2mary 24.05.2020 15:26
DVDFab 11.0.8.9 + Passkey 9.3.8.5
DVDFab 11.0.8.9
New: Added the support to downgrade firmwares for BH14NS58 (1.02), BH16NS58 (1.02) and BH16NS40 (1.04) with the UHD Drive Tool.
New: Improved the profile preset feature to recommend MP4 profile for home theaters.
New: Added the hardware acceleration support on PCs installed with 10th gen Intel GPUs.
Fix: A slow conversion problem when upscaling videos with Enlarger AI after switching to another GPU.
Fix: A conversion failure problem when outputting DTS audios in Ripper modules.
Passkey 9.3.8.5
czary2mary 21.05.2020 10:01
DVDFab 11.0.8.8
Fix: A startup crash problem in certain cases.
czary2mary 16.05.2020 07:32
DVDFab 11.0.8.7 + Passkey 9.3.8.4
DVDFab 11.0.8.7
New: Added the support for the new copy protection as found on certain Japanese adult DVDs.
New: Added the support to preset conversion profiles for different scenarios (mobile devices and home theaters) when converting DVDs, Blu-rays and 4K Ultra HD Blu-rays with the Ripper modules.(scroll down for more info)
New: Improved the support for the burning engine.
Fix: An error 600 problem when copying Blu-rays in certain cases.
Fix: A problem that chapters are created when converting certain MKV files with Enlarger AI even there are no chapters in the original files.
Fix: A failure problem when converting videos with the MP4.Passthrough profile in the Video Converter module.
Passkey 9.3.8.4
czary2mary 07.05.2020 12:03
DVDFab 11.0.8.6 + Passkey 9.3.8.2
DVDFab 11.0.8.6
New: Improved the support for Enlarger AI upscaling conversion.
Passkey 9.3.8.2
New: An authorization failure problem if the account password is too long.
czary2mary 26.04.2020 10:45
DVDFab 11.0.8.5
New: Added the Ultra Quality conversion model when upscaling DVDs in DVD Ripper and 480p videos in Video Converter, with Enlarger AI. More info here: https://forum.dvdfab.cn/forum/softwa...ate#post380934
New: Improved the overall user experience on Installation, Task Manager and Enlarger AI.
czary2mary 22.04.2020 08:53
Passkey 9.3.8.1
czary2mary 12.04.2020 08:41
DVDFab 11.0.8.4
New: Improved the speed when opening Blu-rays and 4K Ultra HD Blu-rays.
New: Integrated Intel OpenVINO AI technology when upscaling videos with Enlarger AI on PCs installed with 6th-10th Gen Intel Core Series (Also the iGPUs), such as i7-6700, i7-7700, i9-9900, etc.
Wszystkie czasy w strefie CET. Aktualna godzina: 14:04.
