Stary 31.07.2005, 13:47   #1
Karsol
Data rejestracji: 31.07.2005
Karsol w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
zabezpieczenie (HELP)
Kupiłem sobie pirackiego sacred Underworlda i nieumie go odpalic
na plycie jest angielski opis jak odpalic sacred tylk oze vnic nierozumiem moze ktos wie jak uruchomic sacred
TU JEST ANGIELSKI OPIS JAK URUCHOMIC SACRED HELP!!!!!!
Important
Sacred Underworld is an addon that requires the orginal game Sacred
to be installed.This version has been tested with Sacred-Deviance
iso and Sacred Clone-Cyclone and works perfectly.We recommend you use
the orginal Sacred Clone-Cyclone as you will be able to then also play
a fully updated version of the orginal as well as this addon.
We will also release an internal clone of CD1 of Sacred for this purpose.
Story
Sacred Underworld continues to tell the story of the kingdom of Ancaria
which is now facing a dreadful threat coming from its very depths.
After Shaddar's demise, the player is drawn into the depths and faces
a completely new, bizarre, bright and vast underworld. After many adventures
above and below the world's surface, the hero will finally stand before the
Portal of Hell, in an intense and dramatic climax.
Game Features
ţ Two new characters (Dwarf, Succubus)
ţ Two new stories
ţ World expansion of approx. 30 to 40 %
ţ Completely new monsters and NPCs
ţ New items and armor sets
ţ Horses can be equipped
ţ Improved interface
Installation Notes
Unpack the release with Winrar or equivalent.
Both Daemon tools and Alcohol.120% are currently blacklisted by this game.So Uninstall both!
Make sure that your system is totally cleaned of this program overwise you will get
emulation software detected error!No doubt these blacklists will be removed in the next versions
of these virtual drives!
To Play mounted.
Download and install Gamejack 5 newest version at http://www.gamejack.org/
Create the Game Jack virtual drive and install game mounted from here.
Now you need to add the game to Gamejack game starter.Easiest way to do this
is to open Gamejack, goto detect copy protection,choose your install folder for the
game.(most likely C:\Program Files\Ascaron Entertainment\Sacred Underworld).Then click
start scanning.Once game is scanned there will be button at the bottom saying
"Add to gamestarter".Click it!
Make sure CD1 is mounted.
Then click gamestarter.Sacred will be listed.Right click its icon on this page and
click start.Game runs avoiding all blacklists!
Karsol jest offline
Stary 31.07.2005, 13:52   #2
Zaraz pewnie będzie
http://forum.cdrinfo.pl/showthread.php?t=11762 punkt 8.
joujoujou jest offline
Stary 31.07.2005, 14:06   #3
MacGyver
Team Member
Avatar użytkownika MacGyver
Data rejestracji: 14.05.2002
http://forum.cdrinfo.pl/announcement.php?f=11
Napisany przez Punkt C
c) dyskusje z prośbami o rozwiązanie problemów z pirackimi kopiami gier/programów ściągniętymi z sieci ...bedą bezwłocznie zamykane/kasowane.
MacGyver jest offline
Jakiej plytki uzyc aby obejsc zabezpieczenie w DVD michalk760 Napędy optyczne CD 12 17.01.2005 14:49
zabezpieczenie dvd dar01 Napędy optyczne DVD 2 10.01.2005 17:43
Hidden&Dangerous 2 - jakie zabezpieczenie? wiaktor Zabezpieczenia CD/DVD/Blu-ray 4 27.11.2003 23:03
Kopiowanie zabezpieczonych gier v1.64a VLuka FAQ 0 29.12.2002 18:43
Zabezpieczenie w programie Rebirth 2.0 Tradermen Napędy optyczne CD 3 23.04.2002 06:05
Wszystkie czasy w strefie CET. Aktualna godzina: 07:22.
