-   -   Poszukuję programu (https://forum.cdrinfo.pl/f113/poszukuje-programu-70375/)
kizio 04.06.2007 18:39
by***322;o chyba co***347; takiego jak Xara Webstyle, nie wiem czy to dok***322;adnie takie co***347; jak ty chcesz ale mo***380;esz spr***243;bowa***263;.
IceManSpy 04.06.2007 17:36
Szukam programu, kt***243;ry b***281;dzie tworzy***322; menu na strony we flash'u. Za pomoc***261; prostych kreator***243;w itd. Jedynym wymaganiem to musi by***263; opcja lub ustawienie takie, ***380;e jak klikn***281; na przycisk, to rozsunie si***281; w d***243;***322; i b***281;dzie mia***322; kolejne opcje do wyboru. Potem jak jeszcze raz si***281; kliknie to zamknie to.
Powiedzmy ***380;e co***347; w tym stylu:
http://www.flashation.com/flashsampl...hsample01.html
tylko, ***380;e w pionie. Pogrzeba***322;em troch***281; w tym programie, ale nie mog***281; nic takiego znale***378;***263;, a ka***380;dego programu nie b***281;d***281; sprawdza***263;.
P.S. Mo***380;e by***263; ewentualnie jaki***347; skrypt java ;)
Piterniel 21.03.2007 23:43
ZW Net Send Manager is software, which uses the Messenger Service of NT based systems to send message over a network (local or Internet). Its many functions and its friendly interface help you to send different messages at once without any difficulties. You can even create batches not to have to retype all the information to re-send messages. NSM is also multilanguage, and a language editor is also provided
http://www.download.com/ZW-Net-Send-...-10391679.html
NetSendGUI
This is a frontend for the "net send" utility built in in Windows NT. Now it's very easy to sendshort messages around you network neighbourhood. Please notice, the messenger service must be running! If you will use the best display setting, please make sure that the font "Tahoma" installed on your system.
Now you can see the output from the net send command and there is some functionality
to cancel a wrong job.
This program is freeware. As such, we give no warranty to its accuracy, fitness for any particular use, effects of use, or reliability. It may be freely distributed, although it must be distributed with all original files in their original format intact. Please contact the author, Falk Schmal, at the email addresses with questions, comments, bug-reports or any updates you make to the program.
http://www.nttools-online.de/english/netsendgui.gif
http://www.nttools-online.de/english/netsendgui.htm
______________
Ice, to all w google jest. Ten temat odwiedzaja ludzie a nie boty polaczone z google.com ;p
kraluk 21.03.2007 23:34
Napisany przez IceManSpy (Post 752828)
A może jakiś program a nie usługa posłaniec?
Może tu coś znajdziesz:
http://www.pcworld.pl/artykuly/48303.html
http://www.dobreprogramy.com.pl/index.php?dz=1&t=50
Piterniel 21.03.2007 23:24
@ndy, tak - dobijamy leni xD
W Windowsie jest cos takiego jak 'net send' ;-) Jak dobrze pamietam...
IceManSpy 21.03.2007 21:06
A mo***380;e jaki***347; program a nie us***322;uga pos***322;aniec?
andy 21.03.2007 20:37
http://www.google.pl/search?hl=pl&cl...tnG=Szukaj&lr=
IceManSpy 21.03.2007 20:16
A jak to to odpali***263; i obs***322;ugiwa***263;? Dodam, ***380;e 2 komp ma SP1.
andy 21.03.2007 20:01
G***322;***243;wnie by mi chodzi***322;o o wysy***322;anie komunikat***243;w, aby na pulpicie od razu wyskakiwa***322;y.
Us***322;uga pos***322;aniec w XP.
IceManSpy 21.03.2007 19:53
Ok, szukam kolejnego :)
Szukam programu do kontroli komputera w sieci LAN. Konkretniej by mi chodzi***322;o o np wy***322;***261;czenie komputera, wysy***322;ania komunikat***243;w (typu okienka w windows z przyciskiem ok). Istnieje co***347; takiego? G***322;***243;wnie by mi chodzi***322;o o wysy***322;anie komunikat***243;w, aby na pulpicie od razu wyskakiwa***322;y.
IceManSpy 21.03.2007 14:49
Wiem, w***322;a***347;nie wczoraj znalaz***322;em tego video avatar :) Dzi***281;ki wszystkim za odpowied***378;.
mensir67pl 21.03.2007 10:04
Napisany przez IceManSpy (Post 752391)
Ale ja wybranej klatki nie chce. Ja chce pewien fragment, np ok 10-15 sekund. Wiem, że taki program do avatarów istnieje, tylko nie pamiętam nazwy.
VideoAvatar 2.0
http://www.softpedia.com/screenshots//VideoAvatar_1.png
joujoujou 21.03.2007 03:25
Załącznik 38541
Niestety, nie jest darmowy. :(
IceManSpy 20.03.2007 22:42
Ale ja wybranej klatki nie chce. Ja chce pewien fragment, np ok 10-15 sekund. Wiem, ***380;e taki program do avatar***243;w istnieje, tylko nie pami***281;tam nazwy.
andy 20.03.2007 22:31
VirtualDub potrafi wyci***261;gn***261;***263; wybrane klatki z filmu.
Wszystkie czasy w strefie CET. Aktualna godzina: 01:14.
