Stary 17.09.2004, 20:49   #1
WhiteMan
DVD FaN
Data rejestracji: 05.01.2003
WhiteMan zaczyna zdobywać reputację <1 - 49 pkt>
Problem z suprnova.org
od kilku dni nie moge korzystac z tej stronki, sciagam ten pliczek ale nie moge zainportowac go do np bitorrenta!!! pokazuje jeszcze cos takiego
,,Unauthorized download
We're sorry, but this downlod request cannot be authorized. There could be several reasons for this:
1) You clicked on a link on an *unofficial* SuprNova.org mirror. We do not allow that kind of external hotlinking. This site creates a great deal of traffic and it's hard to find a good hosting. We will not provide the bandwith for other sites. Please visit SuprNova.org and you can download all the torrents you want.
2) You're using a download manager. But there's a solution to this problem:
Set up your download manager to send a HTTP referer, and when you click on a link on the SuprNova.org site the download will be authorized. Here's how you can do this in Getright:
Go to Getright Configuration, under Advanced/Protocol check Send "Referer" in HTTP Request and then select Calculated from open web browser page.
The setup should be similar for other download managers.
3) Your browser did not send a referer. This normally happens if you right click on a link and select save-as, or if you copy and paste a link into a new browser window and press Enter. It may also be that your browser is set up to not send any referer. But left clicking on a link works just fine and has been tested in IE6, Netscape 6, Opera6, Firefox and Safari
Some software firewalls, for instance the Norton Personal Firewall (which is also part of Norton Internet Security) or ZoneAlarm remove the referer from HTTP requests which will block any downloads on any site that does a referer check. Hence such options should always be turned off. In Norton you have to go to the Privacy Settings and disable browser privacy (which doesn't really protect your privacy anyway as your IP address will always be logged regardless of that setting), in ZoneAlarm you have to go to Privacy -> Cookie Control -> Custom and uncheck "remove private header information".
Software like AdSubstract also blocks the referer and makes downloads impossible.
We're sorry for any inconvenience this may cause and hope you understand our reasons for doing so. Bandwith doesn't come cheap and we have to do all we can to keep the bandwith usage down."
mozecie pomoc!!!
WhiteMan jest offline   Odpowiedz cytując ten post
Stary 17.09.2004, 20:57   #2
Eliasz
Prorok na F.O.R.U.M.
Avatar użytkownika Eliasz
Data rejestracji: 01.01.2002
A działa u was share-reactor.pl U mnie wywala coś takiego:
Warning: mysql_connect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/kimor/public_html/opcje.php on line 22
Nie mogę poł&plusmn;czyć się za serwerem
"The only thing necessary for the triumph of evil is for good men to do nothing" - Edmund Burke
"Jedynym sposobem na to by zatryumfowało zło, jest gdy dobry człowiek nie robi nic."
Ten post NIE powstał w celu przekręcenia licznika o kolejną cyferke - copyright by nie Nimal ani nie Gallus a Eliasz
__________________________________________________ _______________
Eliasz jest offline   Odpowiedz cytując ten post
Stary 17.09.2004, 20:58   #3
B@rtek
Born 2 ride, ride 2 live
Avatar użytkownika B@rtek
Data rejestracji: 04.07.2004
Nie to samo co u Ciebie
Stary 17.09.2004, 22:55   #4
raptor123
Avatar użytkownika raptor123
Data rejestracji: 27.08.2002
raptor123 zaczyna zdobywać reputację <1 - 49 pkt>
Jeżeli nie możecie ściągać torrentów ze strony http://suprnova.org to polecam program GoSupernova bardzo pomocny jest
EDIT:
Sprawdziłem właśnie programik i nie da się tak samo ściągać torrentó ale chociaż można sobie bez problemu przejżeć torrenty
Działa tylko w IE i jeśli się klika normalnie na link a nie Save as...
piszcie tutaj
Ostatnio zmieniany przez raptor123 : 18.09.2004 o godz. 01:25
raptor123 jest offline   Odpowiedz cytując ten post
Stary 17.09.2004, 23:15   #5
WhiteMan
DVD FaN
tzn?
Wszystkie czasy w strefie CET. Aktualna godzina: 22:49.
