03.06.2005, 07:49 | #1 |
Data rejestracji: 12.08.2004
Avi2DVD problem ..chyba z napisami
Pierwszy raz użylem programu avi2dvd +Quenc film był bez napisów wynik bardzo dobry (szhrek2) wszystko OK.Niestety przy drugim filmie już z napisami pojawiły sie problemy ,oto treść Logu:
[15:53:44] AVI2DVD Started ! [15:53:45] Type mode : Avi Input [15:53:45] Output : Dvd [15:53:45] Encoder Selected : QuEnc [15:53:46] Start demuxing the AudioStream No.1 ... [15:54:17] Demuxing of the selected audio finished successfully ! [D:\Avi2dvd_temp\Extracted_Audio.mp3 97269744 Bytes] [15:54:17] Audio extracted renamed successfully ! [D:\Avi2dvd_temp\Fixed_Audio01.mp3 97269744 Bytes] [15:54:17] Starts Mp3->Ac3 convertion ... [16:02:57] Ac3 generated successfully ! [D:\Avi2dvd_temp\Converted_Audio.ac3 278926848 Bytes] [16:02:57] Audio needs to be converted at 48000 Khz ... [16:10:54] Audio converted at 48000 Khz successfully! [D:\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3 278926848 Bytes] [16:10:54] Start creating avisynth script ... [16:10:54] Avisynth script created successfully ! [D:\Avi2dvd_temp\Avisynth_Script_File.avs 283 Bytes] [16:10:54] Bitrate used : 5524 Kbpps [16:10:54] Start video encoding ... [22:36:37] Video encoded successfully ! [D:\Avi2dvd_temp\Encoded_Video.m2v 2843036811 Bytes] [22:36:37] Muxing Video+Audio(s) ... [22:43:54] M2v muxed successfully ! [D:\Avi2dvd_temp\Encoded_Video_Muxed.mpg 3195854848 Bytes] [22:43:54] One subtitle found [22:43:54] Spumux script generation ... [22:43:54] Spumux script generated successfully ! [22:43:54] Muxing the subtitle... [22:43:56] Subitles muxed successfully ! [D:\Avi2dvd_temp\Encoded_Video_Muxed_Subbed.mpg 0 Bytes] [22:43:56] Job NOT Done. There are warnings ... Find at the log file the 0 byte generated file to focus where exactly the problem appears Niby wszystko szło dobrze a na koniec Qpa. Proszę pomóżcie ,w czym jest problem?? |
Opcje związane z dyskusją | |
Tryby wyświetlania | Oceń tę dyskusję |
