Stary 01.09.2006, 14:46   #1
Pavlix
Avatar użytkownika Pavlix
Data rejestracji: 25.01.2006
Pavlix w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
dvdauthorgui - problem
Gdy rozpoczynam proces authoringu wszystko do czasu jest w pożątku. Lecz nagle pojawia sie komunikat o błędzie i zaleca przejrzenie loga. Czy znalazłby się ktoś na tyle miły, aby mi go przeanalizował i podał rozwiązanie problemu
Kod:
DVDAuthorGUI 1.008b - 1/14/2006
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
 ***please wait while the titles are multiplexed.
 *multiplexing title: 1.....
    INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    INFO: [???] File C:\xxx.m2v looks like an MPEG Video stream.
    INFO: [???] File C:\xxx.ac3 looks like an AC3 Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (C:\xxx.m2v)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width     : 720
    INFO: [???] Frame height    : 576
    INFO: [???] Aspect ratio    : 4:3 display
    INFO: [???] Picture rate    : 25.000 frames/sec
    INFO: [???] Bit rate        : 9800000 bits/sec
    INFO: [???] Vbv buffer size : 229376 bytes
    INFO: [???] CSPF            : 0
    INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\xxx.ac3)
    INFO: [???] AC3 frame size = 768
    INFO: [???] AC3 AUDIO STREAM:
    INFO: [???] Bit rate       :    24576 bytes/sec (192 kbit/sec)
    INFO: [???] Frequency      :     48000 Hz
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate    : 10202744
    INFO: [???] target data-rate specified               : 10080000
 ++ WARN: [???] Target data rate lower than computed requirement!
 ++ WARN: [???] N.b. a 20% or so discrepancy in variable bit-rate
 ++ WARN: [???] streams is common and harmless provided no time-outs will occur
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio bd: buf=  16384 frame=000000 sector=00000000
 ++ WARN: [???] Stream e0: data will arrive too late sent(SCR)=16676 required(DTS)=0
 ++ WARN: [???] Video e0: buf= 161077 frame=000001 sector=00000113
 ++ WARN: [???] Audio bd: buf=  16384 frame=000000 sector=00000000
    INFO: [???] Scanned to end AU 59962
    INFO: [???] STREAM bd completed @ frame 74952.
    INFO: [???] STREAM e0 completed @ frame 59962.
    INFO: [???] Multiplex completion at SCR=215860224.
    INFO: [???] Video e0: buf=  47486 frame=059962 sector=01378824
    INFO: [???] Audio bd: buf=  11008 frame=074952 sector=00028554
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length:  2788281736 bytes
    INFO: [???] Sequence headers:     4627
    INFO: [???] Sequence ends   :        1
    INFO: [???] No. Pictures    :    59962
    INFO: [???] No. Groups      :     4627
    INFO: [???] No. I Frames    :     4627 avg. size145715 bytes
    INFO: [???] No. P Frames    :    18457 avg. size 77911 bytes
    INFO: [???] No. B Frames    :    36879 avg. size 18331 bytes
    INFO: [???] Average bit-rate :  9300000 bits/sec
    INFO: [???] Peak bit-rate    : 26629600  bits/sec
    INFO: [???] BUFFERING min 15 Buf max 235543
    INFO: [???] AUDIO_STATISTICS: bd
    INFO: [???] Audio stream length 57563904 bytes.
    INFO: [???] Frames         : 455749626
    INFO: [???] BUFFERING min 67 Buf max 13315
 **ERROR: [???] MUX STATUS: Frame data under-runs detected!
Process aborted due to above error
There was an unknown error.  Please review the log for more information.
Whenever, wherever, however ever??
GOOGLE
Pavlix jest offline   Odpowiedz cytując ten post
Stary 02.09.2006, 00:37   #2
1stwasp
Redakcja
Avatar użytkownika 1stwasp
Data rejestracji: 27.12.2003
1stwasp zaczyna zdobywać reputację <1 - 49 pkt>
INFO: [] Peak bit-rate : 26629600 bits/sec
Popraw plik video - masz przekroczony bitrate tak około z 3 razy.
Pozdrawiam!
1stwasp jest offline   Odpowiedz cytując ten post
Stary 03.09.2006, 21:15   #3
Pavlix
Pozdrawiam!
Niemożliwe***8230; konwertowałem na przemian w cce i tmpgenc w trybie VBR z min. Bitrate 8500, średnim 9300 i max. 9800. Więc skąd się bierze Peak bit-rate : 26629600 bits/sec
GOOGLE
Wszystkie czasy w strefie CET. Aktualna godzina: 05:25.
