Stary 19.08.2011, 14:03   #1
Encoder
Data rejestracji: 19.08.2011
Encoder w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Kompresja DVDredbuiler+CCE problem...
Witam.Zainstalowałem program DVDRedbuiler w wersji 1.28.2 i CCE 2.70.02.00 i chciałem przerobić.Nie ukrywam że dopiero się uczę.Problem polega że konwersja trwa zaledwie 10 min.Nastawiłem na 6 przejść.Poniżej opisz logów DVDRedbuilera:
13:52:33] Phase I, PREPARATION started.
- DVD-RB v1.28.2
- AVISYNTH 2.5.8.0
- CCE 2.67.0.27 encoder selected.
- Source: DVD
- VTS_01: 1 908 010 sectors.
-- Scanning and writing .D2V & .AVS files
-- Processed 122 524 frames.
-- Building .AVS and .ECL files
- VTS_03: 119 459 sectors.
-- Processed 11 840 frames.
- VTS_07: 95 452 sectors.
-- Processed 9 292 frames.
- Reduction Level for DVD-5: 100,0%
- Overall Bitrate : 6 221/4 977Kbs
- Space for Video : 3 864 676KB
- HIGH/LOW/TYPICAL Bitrates: 5 781/1 702/4 977 Kbs
-- FEATURE does not require reencoding.
[13:53:43] Phase I, PREPARATION completed in 1 minutes.
[13:53:43] Phase II ENCODING started
- Extracting Video for VTS_01 segment 0
- Extracting Video for VTS_01 segment 1
- Extracting Video for VTS_01 segment 2
- Extracting Video for VTS_01 segment 3
- Extracting Video for VTS_01 segment 4
- Extracting Video for VTS_01 segment 5
- Extracting Video for VTS_01 segment 6
- Extracting Video for VTS_01 segment 7
- Extracting Video for VTS_01 segment 8
- Extracting Video for VTS_01 segment 9
- Extracting Video for VTS_01 segment 10
- Extracting Video for VTS_01 segment 11
- Extracting Video for VTS_01 segment 12
- Extracting Video for VTS_01 segment 13
- Extracting Video for VTS_01 segment 14
- Extracting Video for VTS_01 segment 15
- Extracting Video for VTS_03 segment 0
- Extracting Video for VTS_03 segment 1
- Extracting Video for VTS_03 segment 2
- Extracting Video for VTS_03 segment 3
- Extracting Video for VTS_03 segment 4
- Extracting Video for VTS_03 segment 5
- Extracting Video for VTS_03 segment 6
- Extracting Video for VTS_07 segment 0
- Extracting Video for VTS_07 segment 1
- Extracting Video for VTS_07 segment 2
- Extracting Video for VTS_07 segment 3
[13:55:20] Phase II ENCODING completed in 2 minutes.
[13:55:20] Phase III, REBUILD started.
- Copying IFO, BUP, and unaltered files...
- Processing VTS_01
- Reading/processing TMAP table...
- Rebuilding seg 0 VOBID 1 CELLID 1
- Rebuilding seg 1 VOBID 1 CELLID 2
- Rebuilding seg 2 VOBID 1 CELLID 3
- Rebuilding seg 3 VOBID 1 CELLID 4
- Rebuilding seg 4 VOBID 1 CELLID 5
- Rebuilding seg 5 VOBID 1 CELLID 6
- Rebuilding seg 6 VOBID 1 CELLID 7
- Rebuilding seg 7 VOBID 1 CELLID 8
- Rebuilding seg 8 VOBID 1 CELLID 9
- Rebuilding seg 9 VOBID 1 CELLID 10
- Rebuilding seg 10 VOBID 1 CELLID 11
- Rebuilding seg 11 VOBID 1 CELLID 12
- Rebuilding seg 12 VOBID 1 CELLID 13
- Rebuilding seg 13 VOBID 1 CELLID 14
- Rebuilding seg 14 VOBID 1 CELLID 15
- Rebuilding seg 15 VOBID 1 CELLID 16
- Updating NAVPACKS for VOBID_01
- Updated VTS_C_ADT.
- Updated VTS_VOBU_ADMAP.
- Updated IFO: VTS_01_0.IFO
- Updating TMAP table...
- Processing VTS_03
- Rebuilding seg 3 VOBID 2 CELLID 1
- Rebuilding seg 4 VOBID 2 CELLID 2
- Rebuilding seg 5 VOBID 2 CELLID 3
- Updating NAVPACKS for VOBID_02
- Rebuilding seg 6 VOBID 3 CELLID 1
- Updating NAVPACKS for VOBID_03
- Updated IFO: VTS_03_0.IFO
- Processing VTS_07
- Updated IFO: VTS_07_0.IFO
- Correcting VTS Sectors...
[14:02:19] Phase III, REBUILD completed in 7 minutes.
Done.
[14:02:19] PREPARE/ENCODE/REBUILD completed in 10 min.
W czym trkwi problem.Może ktoś mi pomoże.Z góry dziękuje.Pozdrawiam
Encoder jest offline   Odpowiedz cytując ten post
Stary 22.08.2011, 13:21   #2
sobrus
Jukebox Hero
Avatar użytkownika sobrus
Data rejestracji: 17.09.2004
A jaki jest rozmiar plików wynikowych?
Może rekompresja była zbędna.
Stary 22.08.2011, 16:02   #3
Encoder
Weisz chodzi mi oto miałem jakieś DVD5 na kompie.Wrzuciłem do DVDredbuilera i chciałem je przepuść na 6 passów ale problem polega na tym że CCE nie uruchamia się tylko pracuje redbuiler z czego robi jakieś pliki na pewno nie as to Vob.Nie wiem dopiero zaczynam z tym zabawę może mam złe coś poustawiane,może zła wersje CCE byłbym wdzięczny jeśli pokazał byś mi jak to się robi itd.Pozdrawiam
Stary 22.08.2011, 16:55   #4
sobrus
Jukebox Hero
Jeżeli miałeś już DVD5, to nie bardzo rozumiem jaki jest sens zabawy z DVD Rebuilderem.
Co do CCE to cieżko coś powiedzieć - nie napisałeś nic więcej poza tym, że to CCE.
Podejrzewam że to CCE SP albo Basic, oba powinny być dobre.
Ostatnio zmieniany przez sobrus : 22.08.2011 o godz. 17:01
Stary 22.08.2011, 17:39   #5
Encoder
Czyli rozumiem że konwersja DVD5 jak jest DVD5 nie ma sensu.A jak bym zrobił chciał zrobić z DVD9 na 5 czy da się.?Używam CCE wersji CCE SP 2.67.00.27.I czy jest jakiś opis w sieci jak to zrobić jakiej wersji trzeba używać,skąd wziąć dobra wersje CCE.
Ostatnio zmieniany przez Encoder : 22.08.2011 o godz. 17:44
Stary 22.08.2011, 17:51   #6
sobrus
Jukebox Hero
Oczywiście konwersja z DVD5 na DVD5 nie ma sensu.
Rebuilder przecież służy głównie do zmniejszania DVD9 do DVD5
(skoro go chcesz użyć to chyba powinieneś wiedzieć w jakim celu chcesz to uczynić )
Zarówno CCE SP jak i Basic powinny działać dobrze, najlepiej będzie je pobrać ze strony producenta.
http://www.cinemacraft.com/en/ccesp_dl.html
Stary 22.08.2011, 18:05   #7
Encoder
no dobra to teraz wytłumacz mi jedną rzecz.Znajduje DVD5 i pisze tam takie coś:
PAL
reenkodowany / 81,5%
ilość pass: 8
Re-encoder: DVD Rebuilder + CCE
więc ktoś też rencoda robił albo źle to rozumiem.
Stary 22.08.2011, 18:12   #8
sobrus
Jukebox Hero
No moze zrobił, to po co robic drugi raz?
Jeżeli płyta mieści się na DVD5, to znaczy że Rebuilder nie ma nic do roboty.
Więc nic nie robi .
Albo ja Ciebie coś źle rozumiem.
Stary 22.08.2011, 18:19   #9
Encoder
Teraz robię z DVD9 do DVD5 widzę wszystko idzie jak potrzeba dziwne.Widocznie musiałem coś złe robić lub mieć ustawione coś nie tak.Tylko jakoś szybko idzie już mam 6 procent.
Ostatnio zmieniany przez Encoder : 22.08.2011 o godz. 18:28
kompresja MPEG-2 przy pomocy CCE loozak4 DVD-Video 2 21.10.2005 12:33
Problem z CCE aL1En DVD-Video 4 27.12.2004 18:30
Problem z CCE Gorky DVD-Video 11 10.12.2004 23:19
problem z nowymi wersjami CCE tommek1 DVD-Video 2 04.12.2004 14:16
problem z cce waszq/pl/ DVD-Video 8 23.07.2003 22:28
Wszystkie czasy w strefie CET. Aktualna godzina: 12:33.
