Stary 10.11.2006, 14:30   #2
ark_fx
Data rejestracji: 19.02.2006
ark_fx w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Dokładnie tak wygląda log
Do autoringu używam dvd maestro.Zaraz jeszcze sproboje wyciągnąć ten plik i przerobić go do mp2.Ale dlaczego besliced wywala błędy, przed formatem wszystko działało/
BeSplit v0.82 by DSPguru.
Logging start : 11/10/06 , 14:19:33.
F:\BeSplit.exe -core( -input F:\DVD\1a.wav -prefix F:\DVD\Robotnia\Tempus\1a_Fixed -fix -logfile C:\Temp\BeSliced.txt -type mp3 ) -profile( BeSliced v0.2 )
[00:00:00:000] +------- BeSplit -----
[00:00:00:000] | Input : F:\DVD\1a.wav
[00:00:00:000] | Output Prefix : F:\DVD\1a_Fixed
[00:00:00:000] +---------------------
[00:07:24:000] Stream error : Sync found after 179 bytes
[00:07:24:528] Stream error : Sync found after 18 bytes
[00:07:24:588] Stream error : Sync found after 759 bytes
[00:07:24:614] Stream error : Sync found after 468 bytes
[00:07:24:640] Stream error : Sync found after 1983 bytes
[00:07:24:664] Stream error : Sync found after 73 bytes
[00:07:25:410] Stream error : Sync found after 3719 bytes
[00:07:25:580] Stream error : Sync found after 9588 bytes
[00:07:25:630] Stream error : Sync found after 5787 bytes
[00:07:25:812] Stream error : Sync found after 2329 bytes
[00:07:25:838] Stream error : Sync found after 1210 bytes
[00:07:25:874] Stream error : Sync found after 827 bytes
[00:07:25:910] Stream error : Sync found after 2572 bytes
[00:07:25:936] Stream error : Sync found after 144 bytes
[00:07:25:996] Stream error : Sync found after 475 bytes
[00:07:26:023] Stream error : Sync found after 56 bytes
[00:07:26:135] Stream error : Sync found after 2187 bytes
[00:07:26:171] Stream error : Sync found after 59 bytes
[00:07:26:247] Stream error : Sync found after 3476 bytes
[00:07:26:297] Stream error : Sync found after 3925 bytes
[00:07:26:321] Stream error : Sync found after 3807 bytes
[00:07:26:357] Stream error : Sync found after 10200 bytes
[00:07:26:407] Stream error : Sync found after 1982 bytes
[00:07:26:505] Stream error : Sync found after 3303 bytes
[00:07:26:577] Stream error : Sync found after 722 bytes
[00:07:26:604] Stream error : Sync found after 482 bytes
[00:07:26:738] Stream error : Sync found after 2396 bytes
[00:07:26:774] Stream error : Sync found after 126 bytes
[00:07:26:798] Stream error : Sync found after 378 bytes
[00:07:27:470] Stream error : Sync found after 5782 bytes
[00:07:27:806] Stream error : Sync found after 1018 bytes
[00:07:27:866] Stream error : Sync found after 1959 bytes
[00:07:27:890] Stream error : Sync found after 513 bytes
[00:07:27:914] Stream error : Sync found after 93 bytes
[00:07:28:094] Stream error : Sync found after 3242 bytes
[00:07:28:120] Stream error : Sync found after 1449 bytes
[00:07:28:144] Stream error : Sync found after 5395 bytes
[00:07:28:804] Stream error : Sync found after 1382 bytes
[00:07:28:866] Stream error : Sync found after 3794 bytes
[00:07:28:928] Stream error : Sync found after 51 bytes
[00:07:28:952] Stream error : Sync found after 271 bytes
[00:07:29:458] Stream error : Sync found after 87 bytes
[00:07:29:482] Stream error : Sync found after 248 bytes
[00:07:29:621] Stream error : Sync found after 7180 bytes
[00:07:29:645] Stream error : Sync found after 135 bytes
[01:00:42:461] Stream error : Sync found after 383 bytes
[01:00:50:453] Stream error : Sync found after 7269 bytes
[01:16:38:597] Stream error : Sync found after 1785 bytes
[01:16:38:741] Stream error : Sync found after 127 bytes
[01:22:04:853] | Writing F:\DVD\1a_Fixed01.mp3
[01:22:04:853] +---------------------
[01:22:04:853] Operation Completed !
[00:00:09:000] <-- Process Duration
Pozniej jak z tego zrobie ac3 a ac3machine to po zamontowaniu w maestro nie ma synchronizacji.
hmm...z tego co zauważyłem to plik wideo jest dłuższy od audio o jakieś 10 sekund. hmm..?
ark_fx jest offline   Odpowiedz cytując ten post
Wszystkie czasy w strefie CET. Aktualna godzina: 13:15.
