Stary 03.06.2005, 09:49   #1
bacia007
Avatar użytkownika bacia007
Data rejestracji: 12.08.2004
bacia007 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Avi2DVD problem ..chyba z napisami
Pierwszy raz użylem programu avi2dvd +Quenc film był bez napisów wynik bardzo dobry (szhrek2) wszystko OK.Niestety przy drugim filmie już z napisami pojawiły sie problemy ,oto treść Logu:
[15:53:44] AVI2DVD Started !
[15:53:45] Type mode : Avi Input
[15:53:45] Output : Dvd
[15:53:45] Encoder Selected : QuEnc
[15:53:46] Start demuxing the AudioStream No.1 ...
[15:54:17] Demuxing of the selected audio finished
successfully ! [D:\Avi2dvd_temp\Extracted_Audio.mp3
97269744 Bytes]
[15:54:17] Audio extracted renamed successfully !
[D:\Avi2dvd_temp\Fixed_Audio01.mp3 97269744 Bytes]
[15:54:17] Starts Mp3->Ac3 convertion ...
[16:02:57] Ac3 generated successfully !
[D:\Avi2dvd_temp\Converted_Audio.ac3 278926848
Bytes]
[16:02:57] Audio needs to be converted at 48000 Khz ...
[16:10:54] Audio converted at 48000 Khz successfully!
[D:\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3
278926848 Bytes]
[16:10:54] Start creating avisynth script ...
[16:10:54] Avisynth script created successfully !
[D:\Avi2dvd_temp\Avisynth_Script_File.avs 283 Bytes]
[16:10:54] Bitrate used : 5524 Kbpps
[16:10:54] Start video encoding ...
[22:36:37] Video encoded successfully !
[D:\Avi2dvd_temp\Encoded_Video.m2v 2843036811
Bytes]
[22:36:37] Muxing Video+Audio(s) ...
[22:43:54] M2v muxed successfully !
[D:\Avi2dvd_temp\Encoded_Video_Muxed.mpg
3195854848 Bytes]
[22:43:54] One subtitle found
[22:43:54] Spumux script generation ...
[22:43:54] Spumux script generated successfully !
[22:43:54] Muxing the subtitle...
[22:43:56] Subitles muxed successfully !
[D:\Avi2dvd_temp\Encoded_Video_Muxed_Subbed.mpg 0
Bytes]
[22:43:56] Job NOT Done. There are warnings ... Find at
the log file the 0 byte generated file to focus where exactly
the problem appears
Niby wszystko szło dobrze a na koniec Qpa.
Proszę pomóżcie ,w czym jest problem??
bacia007 jest offline   Odpowiedz cytując ten post
Wszystkie czasy w strefie CET. Aktualna godzina: 06:14.
