Data rejestracji: 09.02.2004
nagrywaniu płyty dvd w locie komunikat "nie można skopiować tego dysku DVD!
dlaczego przy nagrywaniu płyty dvd w locie wywala, że "nie można skopiować tego dysku na dvd!
Log: Windows 98 4.90 (ME) IA32 WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 2000-06-08 17:00:00 ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06 Wersja Nero: 6.3.0.2 Nagrywarka: <TSSTcorp CD/DVDW TS-H552U>Wersja: US01 - HA 1 TA 1 - 6.3.0.2 Sterownik adaptera: <intelata> HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: <HL-DT-ST DVD-ROM GDR8162B>Wersja: 0015 - HA 1 TA 0 - 6.3.0.2 Sterownik adaptera: <intelata> HA 1 HL-DT-ST DVD-ROM GDR8162B (Target 0, G : Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ? TSSTcorp CD/DVDW TS-H552U (Target 1, H : Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ? Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 511MB (523704kB) Free physical memory: 278MB (285488kB) Memory in use : 40 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 9.2.2005 Kopia DVD 'w locie' 23:05:41 #1 Text 0 File Reader.cpp, Line 118 Reader running 23:05:41 #2 CDCOPY -31 File DVDCopy.cpp, Line 217 Nie można skopiować tego dysku na DVD! Existing drivers: File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 2000-06-08 17:00:00 File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 2002-03-11 11:55:38 File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 2000-06-08 17:00:00 File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 2000-06-08 17:00:00 File 'IoSubsys\USBMPHLP.PDR': Ver=4.90.3000, size=4861 bytes, created 2000-06-08 17:00:00 File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 2000-06-08 17:00:00 File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 2000-06-08 17:00:00 File '..\System32\Drivers\Ntmap.sys': Ver=4.90.3000, size=8704 bytes, created 2000-06-08 17:00:00 File 'IoSubsys\Ntmaphlp.pdr': Ver=4.90.3000, size=12917 bytes, created 2000-06-08 17:00:00 File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 2000-06-08 17:00:00 File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 2000-06-08 17:00:00 Registry Keys: I co śmieszniejsze to i w XP to samo wywala-mam dwa systemy na różnych dyskach. moja nagrywarka to samsung 552U help! |
1. a co to za plyta ??
(oryginalny film, dane od kolegi, kopia zapasowa moviesa) 2. nie nagrywaj w locie - szkoda plytek, lepiej z hdd 3. DMA wlaczone ?? 4. ASPI zainstalowane ?? 5. jaki soft ?? do filmow polecam (zrobienie kopii zapasowej z posiadanego oryginalu) clonedvd2 (progz do kopiowania i kompresji) i anydvd (progz do obejscia zabezpieczen) |
Zarejestrowany dla jaj
Data rejestracji: 25.11.2004
Kto wypala dvd w locie
Zrób najpierw obraz na twardziela i dopiero pal.
#4 | |
Data rejestracji: 22.11.2003
1. Napędy na osobnych kanałach (lub external) 2. Prędkość odczytu musi być wieksza niż nagrywania. 3. Duży bufor Tak paliłem z powodzeniem. maniek
NEC 3500AG NEC 3520A BENQ 1640 XJ-HD 166S |
#5 | |
#6 | |
Data rejestracji: 21.10.2002
witam a gry na PS2 rowniez przegrywasz w locie?, a do tego wypalales x16?, sprawdzone i pewne, obraz plyty skopiowac na dysk a nastepnie wypalic i po klopocie. pozdrawiam Ostatnio zmieniany przez grzes07 : 11.02.2005 o godz. 09:36 |
a co to jest te Aspi, program do wypalania nero 6302 pl, jak to na osobnych kanałach, czy tu chodzi o to że nie na jednej taśmie, a i jest to kopia zapasowa moviesa
#8 | |
Banned
Data rejestracji: 03.10.2004
a tam np. słownik albo coś takiego http://www.cdrinfo.pl/cdr/artykuly/aspi/aspi.php |
