Stary 13.07.2004, 18:32   #1
latet
Data rejestracji: 04.08.2003
Napisany przez KC42
Część tu pisze po Angielsku a ja nie władam tym językiem
Shame on you, KC42
Nawer plugawi orkowie władają Wspólną Mową!
latet
latet jest offline   Odpowiedz cytując ten post
Stary 13.07.2004, 23:33   #2
KC42
Data rejestracji: 14.12.2003
KC42 zaczyna zdobywać reputację <1 - 49 pkt>
Napisany przez latet
Shame on you, KC42
latet
Czy to jest Polskie forum czy Angielskie ?
PAL DVDs options
(...)The four rightmost "NTSC" options are not available if DVD2DVD-R detects a PAL DVD, anyway (greyed). If the PAL source is progressive, check Progressive and ZigZag Scanning Order only. If it's interlaced, then all options should be turned off, except for bff interlaced video (BV: 'Field topfirst: no') where "Upper Field First" should be checked. --thanks RB
Q10: What's the deal with the "Upper Field First" option? I heard it has a bug?
The confusion about this option arises from that it works different from what you think. Naturally, you'd think that you set this option according to the field order of the video to be encoded, that is, deactivate it if source is bff (bottom field first) and activate it if source is tff (top field first). However, when you do this the encoded video plays back jerky with artifacts typical for incorrect field order.
So how do we set it right? First, you have to know that CCE (SP as well as Basic) always outputs video that is flagged "top field first" (there is a flag in the MPEG header that tells the player which field of the decoded frame to display first on a TV screen). There is no way in CCE to change this. According to Custom Technology, this is not a bug but a feature of CCE... Actually what happens if you check "Upper Field First" is that CCE assumes that source is bff and converts it to tff so it complies with the always set tff flag. It does so by shifting each frame up by one line, ensuring that the previously bottom fields are now top fields and the video is played back correctly. This is not the most sophisticated way to handle the situation, but it works and you won't notice the missing line at the top.
So here is the rule of thumb: Always uncheck "Upper Field First" unless your video is interlaced AND bottom field first. Progressive material is always top field first.
The four rightmost "NTSC" options are not available if DVD2DVD-R detects a PAL DVD, anyway (greyed). If the PAL source is progressive, check Progressive and ZigZag Scanning Order only. If it's interlaced, then all options should be turned off, except for bff interlaced video (BV: 'Field topfirst: no') where "Upper Field First" should be checked."
i ta
"Always uncheck "Upper Field First" unless your video is interlaced AND bottom field first. Progressive material is always top field first."
KC42 jest offline   Odpowiedz cytując ten post
Stary 14.07.2004, 02:52   #3
Michal2004
czytelnik ;)
Avatar użytkownika Michal2004
Data rejestracji: 06.02.2004
Michal2004 zaczyna zdobywać reputację <1 - 49 pkt>
@ KC 42
zawsze ODZNACZAJ w DVD2DVD-R "Upper field first".
Sa wyjatki, ale raczej chodzi wtedy o nagrania z kamer DV...
to tak w skrocie.
Jelsi chcesz zebym to przetlumaczyl na polski musisz poczekac, moze jutro to zrobie.
Michal2004 jest offline   Odpowiedz cytując ten post
Stary 14.07.2004, 11:14   #4
KC42
Napisany przez Michal2004
@ KC 42
to tak w skrocie.
No to czyli wszystkie filmy około 70 sztuk mam skopane, bo to wszystko sprawdzałem Bitrate Viewer i tam pokazywał że mam to zaznaczać a teraz się okazało że on pokazuje złe dane to chyba afera wyszła.
no jak byś mógł to przetłumaczyćten tekst
Stary 14.07.2004, 11:30   #5
latet
Napisany przez KC42
Skopane?
Aż tak źle wyglądają?
Nie działają w odtwarzaczach?
Latet
Stary 14.07.2004, 12:14   #6
Miho
Avatar użytkownika Miho
Data rejestracji: 25.01.2004
Miho zaczyna zdobywać reputację <1 - 49 pkt>
>Czy masz moze program Bitrate Viewer? Moglbys - tak celem sprawdzenia - wrzucic ta swoja kopie zapasowa Terminatora 2 , otworzyc Bitrate Viewer, wczytac jakiegos VOB-a (jakis srodkowy) na przyklad: "VTS_01_3.VOB" i pozniej przekopiowac te "raporty" z BV tutaj na forum?
To samo jakbys mogl zrob tez z Highlanderem.<
Wspomnianego programiku nie posiadam ale sobie poszukam i jak tylko znajdę chwilkę to zamieszcze info.Z tym drobnym zastrzeżeniem że obecna moja kopia zapasowa legalnie nabytego oryginału z musu wykonałem Clony dvd.Aczkolwiek nie zadowala mnie jej jakość Ale dorzyce jeszcze odczyt drugiej zapasowej kopi którą sobie trzymam na twardzielku
Miho jest offline   Odpowiedz cytując ten post
Stary 14.07.2004, 12:18   #7
Miho
Terminator 2
Aha zapomniałem dopisać że robiąc ten backup wszystkie pola miałem odznaczone( tzn.puste bez "ptaszków" )
Stary 14.07.2004, 12:24   #8
KC42
Skopane?
Latet
Nie no chodzą OK, albo nie wiem o jakie błędy chodzi i tego nie zauważyłem. może napisz czego szukać w błędnym włączemiu opcji "Upper field first"
Stary 14.07.2004, 14:44   #9
Michal2004
czytelnik ;)
@ KC42
wiesz... jesli filmy odtwarzaja sie na stacjonarce OK to jest OK tak mi sie wydaje. Oni tam pisali o "jerky playing", czyli jesli cos skacze w dynamicznych scenach... ale jak widzisz zrobilem test (pisalem w pierwszym chyba watku w tym temacie) i mimo to nie zmienil tego, moze dlatego ze nie byl spelniony drugi warunek (material INTERLACED), moze to jakies zabezpiecznie...
nie mam teraz za bardzo czasu na pisanie, ale nawet jesli te filmy bylyby z tym bledem, to mozna to spokojnie odkrecic. Tak pisza na doom9. Jest program restream....
aha trzeba tez pamietac, ze jakby nie bylo w instrukcji na forum byla mowa, zeby to jednak odznaczac..
/edit
KC42 - sprawdz jak mozesz te kopie Bitrate Viewerem, i zobacz czy jest tak taki zapis: "Field topfirst: Yes" czy taki: "Field topfirst: No".
Ostatnio zmieniany przez Michal2004 : 14.07.2004 o godz. 15:44
Wszystkie czasy w strefie CET. Aktualna godzina: 22:18.
