Stary 11.04.2006, 20:36   #1
Spajkers
Data rejestracji: 11.04.2006
Spajkers w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Benq1640 - Problem
Nie moge nagrac zadnego nosnika DVD - nagrywanie trwa ok. 30 minut (bez wzgledu na predkosc dedykowana) - weryfikacja zawsze daje wynik negatywny.
Log z Nero - >
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2002-07-17 10:20:56
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:32
Nero Version: 6.6.0.14
Internal Version: 6, 6, 0, 14d
(Nero Express)
Recorder: <BENQ DVD DD DW1640> Version: BSOB - HA 1 TA 1 - 6.6.0.14
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <ER5255V APD591B >Version: 1.0 - HA 2 TA 0 - 6.6.0.14
Adapter driver: <dtscsi> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800BB-00FRA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : BENQ DVD DD DW1640 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : ER5255V APD591B 1.0 dtscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
BENQ DVD DD DW1640 E: CDRom0
ER5255V APD591B F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (83886080) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 18MB (18752kB)
Memory in use : 92 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
11.4.2006
ISO compilation
18:56:05 #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
18:56:05 #2 Text 0 File Reader.cpp, Line 127
Reader running
18:56:05 #3 Text 0 File Writer.cpp, Line 122
Writer BENQ DVD DD DW1640 running
18:56:05 #4 ISO9660GEN -11 File geniso.cpp, Line 3297
18:56:05 #5 Text 0 File Burncd.cpp, Line 3230
18:56:06 #6 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2167727 (481:43.02, 4233MB)
18:56:06 #7 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO
18:56:06 #8 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: BENQ DVD DD DW1640, Media type: DVD-R
Disc Manufacturer: MAM8XG - 01
Disc Application Code: 64, Disc Physical Code: 193
18:56:06 #9 Text 0 File DlgWaitCD.cpp, Line 445
18:56:06 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2167728 (2167728) = #2167728/481:43.3
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2167728 blocks [BENQ DVD DD DW1640]
18:56:06 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [BENQ DVD DD DW1640] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4439506944, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2167728 | lead-out | 1 | 0x41 | 0x00
18:56:06 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
18:56:06 #13 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
18:56:06 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
18:56:06 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5 540 KB/s)
18:56:06 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
18:56:06 #17 Text 0 File DVDR.cpp, Line 2316
Recording mode: Sequential Recording Mode
18:56:06 #18 Text 0 File Mmc.cpp, Line 21592
Set BUFE: Seamless Link -> ON
18:56:06 #19 Text 0 File DVDR.cpp, Line 2470
Start write address at LBA 0
18:56:06 #20 Text 0 File Cdrdrv.cpp, Line 8821
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
19:21:23 #21 Text 0 File WriterStatus.cpp, Line 116
<BENQ DVD DD DW1640 > start writing Lead-Out at LBA 2167728 (2113B0h), lenght 0 blocks
19:21:23 #22 Text 0 File ThreadedTransfer.cpp, Line 228
19:21:23 #23 Text 0 File DVDR.cpp, Line 2708
EndDAO: Last written address was 2167727
19:22:25 #24 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 4x (5 540 KB/s)
19:22:25 #25 Phase 78 File dlgbrnst.cpp, Line 1832
Data verification started
19:29:04 #26 SCSI -1128 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x0E6C0600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x20 0xB1 0xA0 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x11 0x00
19:29:14 #27 SCSI -1128 File Cdrdrv.cpp, Line 1436
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x28 0x00 0x00 0x20 0xE5 0xC0 0x00 0x00 0x10 0x00 0x00 0x00
19:29:14 #28 SectorVerify 20 File Cdrdrv.cpp, Line 9853
Read errors from sector 2142624 to 2142639
19:29:22 #29 Text 0 File ThreadedTransfer.cpp, Line 228
19:29:23 #30 SectorVerify 20 File Cdrdrv.cpp, Line 9853
Read errors from sector 2155968 to 2155983
19:29:23 #31 Phase 81 File dlgbrnst.cpp, Line 1832
Data verification failed
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=5.3.2.31, size=58000 bytes, created 2006-03-05 01:59:48
File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.31, size=23420 bytes, created 2006-03-05 01:59:48
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 2002-07-17 09:53:02
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-12-05 07:12:26 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 2003-06-19 14:05:04 (Adapter driver for rec)
File 'Drivers\dtscsi.sys': Ver=?.?.?.?, size=223128 bytes, created 2006-03-05 11:46:56 (Adapter driver for src)
Registry Keys:
HKLM\Software\CPUCooL (Power saving: CPUCooL)
Pomocy
Spajkers jest offline
Stary 11.04.2006, 22:07   #2
A czy czasami płytka na której nagrywasz
To nie jest nośnik firmy Nośnik?
VIZZARD jest offline
Stary 11.04.2006, 23:13   #3
Spajkers
Probowalem wczesniej na verbatimach =p
Wszystkie czasy w strefie CET. Aktualna godzina: 15:20.
