-   -   laptopowa matSHITa UJ-860S - problem (https://forum.cdrinfo.pl/f15/laptopowa-matshita-uj-860s-problem-76908/)
grigori 10.02.2008 03:24
No tak, zapeszylem. Pisalem, na jednym forum, ze po zakupie zmartwilo mnie to ze w moim laptopie wsadzono nagrywarke matshity. i masz babo placek! Przy probie nagrania pierwszej plyty dvd w nero 7 wyskakuje "Power Calibration Error"... Co prawda nagrywalem na jakims tanim lipnym dvd, bo takie mialem 'pod reka', ale wszedzie mozna je bylo nagrac bez problemow, tylko oczywiscie nie na matSHITcie!. Co z tym począć, mozliwe ze plyty, a co jesli nie?? Moze log z nero komus pomoze:
Kod:
4C85-2017-4045-0001-0009-7640-0800-1400-0000-4049-233C-**** (*)
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.2
Internal Version: 7, 9, 6, 2
(Nero Express)
Recorder: <MATSHITA DVD-RAM UJ-860S>Version: 1.00 - HA 1 TA 0 - 7.9.6.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <MATSHITA DVD-RAM UJ-860S >Version: 1.00 - HA 1 TA 0 - 7.9.6.2
=== Scsi-Device-Map ===
CdRomPeripheral : MATSHITA DVD-RAM UJ-860S atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST9120822AS atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-860S E: CdRom0
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1023MB (1047756kB)
Free physical memory: 382MB (391628kB)
Memory in use : 62 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
9.2.2008
ISO compilation
21:32:43 #1 Text 0 File SCSIPTICommands.cpp, Line 424
21:32:43 #2 Text 0 File Isodoc.cpp, Line 6663
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
21:32:43 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
21:32:43 #4 Text 0 File Burncd.cpp, Line 3508
21:32:43 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2150991 (477:59.66, 4201MB)
21:32:43 #6 Text 0 File DlgWaitCD.cpp, Line 319
21:32:43 #7 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: MATSHITA DVD-RAM UJ-860S, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 003, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
21:32:43 #8 Text 0 File DlgWaitCD.cpp, Line 493
21:32:43 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2150992 (2150992) = #2150992/477:59.67
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2150992 blocks [E: MATSHITA DVD-RAM UJ-860S]
21:32:46 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: MATSHITA DVD-RAM UJ-860S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4405231616, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2150992 | 0 | 0x00
2150992 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
21:32:46 #11 Text 0 File SCSIPTICommands.cpp, Line 215
21:32:46 #12 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
21:32:46 #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
21:32:46 #14 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
21:32:46 #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
21:32:46 #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11 080 KB/s)
21:32:46 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
21:32:46 #18 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: MCC.....
Media type ID: 003
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 4D 43 43 00 00 - 00 00 00 30 30 33 00 38 ...MCC.....003.8
23 54 37 15 02 52 6C 02 - B4 63 15 15 0B 0A 08 08 #T7..Rl.***9508;c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
21:32:46 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x0649bf00: Len x648
21:32:46 #20 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
21:32:46 #21 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
21:33:10 #22 SPTI -1106 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 03 00 00 00 20 00 00 00
Sense Area: 0xF1 00 03 00 00 00 00 0A 00 00 00 CD 73 03
Buffer x08ad0640: Len x10000
0xC0 29 95 70 7C 59 CA FD ED 55 41 92 AA 06 2B 71
0x85 70 7F 85 D9 60 33 2A 81 8A C3 25 37 43 2A E7
0x30 30 64 63 CB 0B 00 00 00 00 01 B6 58 F0 43 69
21:33:10 #23 CDR -1106 File Writer.cpp, Line 303
Power calibration error
21:33:22 #24 SPTI -1106 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 70 91 73 03
21:33:22 #25 SPTI -1106 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
21:33:22 #26 Phase 127 File dlgbrnst.cpp, Line 1762
Generating DVD high compatibility borders
21:33:45 #27 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 768
21:33:45 #28 CDR -1106 File WriterStatus.cpp, Line 162
21:33:45 #29 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
21:33:46 #30 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 8x (11 080 KB/s)
21:33:46 #31 Text 0 File SCSIPTICommands.cpp, Line 261
21:33:47 #32 Text 0 File Cdrdrv.cpp, Line 11185
21:33:47 #33 Text 0 File SCSIPTICommands.cpp, Line 424
Existing drivers:
Registry Keys:
PS.: Czy jest gdzies dostepny firmware wyzszy niz 1.00 do tej nagrywark?
Wszystkie czasy w strefie CET. Aktualna godzina: 11:12.
