Stary 26.02.2006, 21:50   #1
Deadiana
Data rejestracji: 26.02.2006
Deadiana w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
LG GSA-4163B - problem z DVD+R
Moja nagrywarka DVD LG GSA-4163B jak do tej pory spisywała się bez zarzutu. Nagrywała CD-R,RW oraz DVD-R. Kiedy jednak ostatnio próbowałam wypalić DVD+R wystąpił błąd. Poniżej umieszczam log z Nero 7:
Kod:
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 97-12-23 02:23:24
ahead WinASPI: File 'F:\PROGRAM FILES\NERO 7\NERO 7\CORE\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 04-11-02 12:54:32
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
Recorder:             <HL-DT-ST DVDRAM GSA-4163B>Version: A100 - HA 1 TA 0 - 7.0.1.2
 Adapter driver:      <ESDI_506>                HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ATAPI
CD-ROM:               <PIONEER  DVD-ROM DVD-106 >Version: 1.22 - HA 1 TA 1 - 7.0.1.2
HL-DT-ST DVDRAM GSA-4163B (Target 0, H:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
PIONEER DVD-ROM DVD-106 (Target 1, I:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
Generic DVD-ROM (Target 0, J:): Autoinsert On, DMA ?, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 511MB (523424kB)
Free physical memory: 30MB (31308kB)
Memory in use       : 64 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
23.1.2006
ISO compilation
13:47:17   #1 Text 0 File Isodoc.cpp, Line 6411
   Iso document burn settings
   Simulate                : FALSE
   Write                   : TRUE
   Finalize CD             : TRUE
   Multisession            : FALSE
   Burning mode            : DAO
   Mode                    : 1
   ISO Level               : 2 (Max. of 31 chars)
   Character set           : ISO 9660
   Joliet                  : TRUE
   Allow more than 255 characters in path  : TRUE
   Write ISO9660 ;1 file extensions        : TRUE
13:47:17   #2 Text 0 File ThreadedTransfer.cpp, Line 525
   ReadBuffer-Pipe got 72704KB of Memory
13:47:18   #3 Text 0 File Reader.cpp, Line 124
   Reader running
13:47:18   #4 Text 0 File Writer.cpp, Line 113
   Writer H: HL-DT-ST DVDRAM GSA-4163B running
13:47:18   #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
13:47:18   #6 Text 0 File Burncd.cpp, Line 3302
13:47:18   #7 Text 0 File DlgWaitCD.cpp, Line 279
   Last possible write address on media:  2295103 (510:01.28, 4482MB)
   Last address to be written:            2180319 (484:30.69, 4258MB)
13:47:18   #8 Text 0 File DlgWaitCD.cpp, Line 291
13:47:18   #9 Text 0 File DlgWaitCD.cpp, Line 2578
   Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R
    Disc Manufacturer ID: RITEK, Media Type ID: R05, Product revision number: 1
    Disc Application Code: 0, Extended Information Indicators: 7
13:47:18   #10 Text 0 File DlgWaitCD.cpp, Line 458
13:47:18   #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
    0: TRM_DATA_MODE1 ()
       original disc pos #0 + 2180320 (2180320) = #2180320/484:30.70
       relocatable, disc pos for caching/writing not required/ required, no patch infos
       -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2180320 blocks [H: HL-DT-ST DVDRAM GSA-4163B]
13:47:18   #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
   Prepare recorder [H: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
   DAO infos:
    MCN: ""
    Tracks 1 to 1:
      1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4465295360, ISRC ""
   DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
          0 |  lead-in |   0 |    0x41 | 0x00
          0 |        1 |   0 |    0x41 | 0x00
          0 |        1 |   1 |    0x41 | 0x00
    2180320 | lead-out |   1 |    0x41 | 0x00
13:47:18   #13 Phase 24 File dlgbrnst.cpp, Line 1725
   Caching of files started
13:47:19   #14 Text 0 File Burncd.cpp, Line 4132
   Cache writing successful.
13:47:19   #15 Phase 25 File dlgbrnst.cpp, Line 1725
   Caching of files completed
13:47:19   #16 Phase 36 File dlgbrnst.cpp, Line 1725
   Burn process started at 4x (5 540 KB/s)
13:47:19   #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
13:47:19   #18 Text 0 File Cdrdrv.cpp, Line 8411
   ---- DVD Structure: Physical Format Information (00h) ----
   Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R   (10), Part Version: 1.0x (1)
    Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
    Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
    Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
    End Physical Sector Number of Data Area:      26053F h
    End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
     Disc Application Code: 0 / 0 h
     Extended Information indicators: 7 h
     Disc Manufacturer ID: RITEK...
     Media type ID: R05
     Number of Physical format information bytes in use in ADIP up to byte 63: 56
    Media Specific [16..63]:
         00 00 07 52 49 54 45 4B - 00 00 00 52 30 35 01 38    ...RITEK...R05.8
         23 54 37 13 00 44 73 00 - 84 6D 15 15 0B 0B 08 08    #T7..Ds..m......
         01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00    ................
13:47:19   #19 Text 0 File DVDR.cpp, Line 5400
   Drive: HL-DT-ST DVDRAM GSA-4163B
   Book Type request [LG]: DVD-ROM
   Changing the Book Type was finished successfully, return code 0
13:47:19   #20 CDR -1207 File DVDR.cpp, Line 5330
   Book Type automatically set to: DVD-ROM
13:47:19   #21 Text 0 File DVDPlusRW.cpp, Line 666
   Start write address at LBA 0
13:47:40   #22 SCSI -1135 File SCSIInterface.cpp, Line 622
   SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04EE0000
   Status:     0x04 (0x01, SCSI_ERR)
   HA-Status   0x00 (0x00, OK)
   TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
   Sense Key:  0x03 (KEY_MEDIUM_ERROR)
   Sense Code: 0x0C
   Sense Qual: 0x00
   CDB Data:   0x2A 0x00 0x00 0x00 0x02 0x20 0x00 0x00 0x20 0x00 0x00 0x00
   Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
               0x35 0x2D 0x00 0x0E 0x0C 0x00
13:47:40   #23 CDR -1135 File Writer.cpp, Line 302
   Write error
13:47:40   #24 Text 0 File ThreadedTransfer.cpp, Line 228
13:47:40   #25 Text 0 File ThreadedTransfer.cpp, Line 222
   conversion idle, stopping reader
13:47:40   #26 SCSI -1135 File SCSIInterface.cpp, Line 366
   Sense Code: 0x0C
   Sense Qual: 0x00
   CDB Data:   0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
   Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
13:47:40   #27 Phase 127 File dlgbrnst.cpp, Line 1725
   Generating DVD high compatibility borders
13:47:40   #28 CDR -1135 File WriterStatus.cpp, Line 167
   Write error
13:47:40   #29 TRANSFER -24 File WriterStatus.cpp, Line 167
   Could not perform end of Disc-at-once
13:47:40   #30 Phase 38 File dlgbrnst.cpp, Line 1725
   Burn process failed at 4x (5 540 KB/s)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 99-05-05 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 02-03-11 10:55:38
File 'IoSubsys\DRVWPPQT.VXD': Ver=3.10.36a, size=228223 bytes, created 99-05-05 22:22:00
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 99-05-05 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 99-05-05 22:22:00
File '..\System32\Drivers\1394bus.sys': Ver=4.10.2222, size=37328 bytes, created 99-05-05 22:22:00
File '..\System32\Drivers\Ohci1394.sys': Ver=4.10.2222, size=35648 bytes, created 99-05-05 22:22:00
File '..\System32\Drivers\Ntmap.sys': Ver=4.10.2222, size=9360 bytes, created 99-05-05 22:22:00
File 'IoSubsys\Ntmaphlp.pdr': Ver=4.10.2222, size=9825 bytes, created 99-05-05 22:22:00
File '..\System32\Drivers\Sbp2port.sys': Ver=4.10.2222, size=32592 bytes, created 99-05-05 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69574 bytes, created 99-05-05 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 99-05-05 22:22:00
File 'IoSubsys\ElbyCDIO.vxd': Ver=3, 3, 1, 1, size=15635 bytes, created 01-12-19 00:12:14
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 99-05-05 22:22:00 (Adapter driver for rec)
Początkowo myślałam,że zakupione płyty są niesprawne (marki Philips), jednak u kolegi, który ma ten sam model nagrywarki, wypalenie poszło bez problemu (tyle,że w WinXP). Nie wiem w czym jest problem, skoro sprzęt umożliwia wypalanie tego typu płyt. Może ktoś mógłby mi wskazać przyczynę i ewentualny sposób na rozwiązanie mojego problemu?
Deadiana jest offline
Stary 27.02.2006, 23:32   #2
Biskup
Data rejestracji: 20.11.2004
Biskup w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Moim zdaniem nie używaj nero 7 bo na dzisiaj to kicha pełna błędów,nie wszystko dobre co nowe,użyj nero 6
Biskup jest offline
Stary 01.03.2006, 22:57   #3
Deadiana
Próbowałam już w Nero 6 i to samo było, próbowałam też w Win2000 i wciąż się nie nagrywa
Stary 04.03.2006, 14:03   #4
Hegemonic
Data rejestracji: 28.01.2006
Hegemonic w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Twój firmware w LG jest stary jak świat! Wgraj najnowszy A106 i pozbędziesz się problemów.
Hegemonic jest offline
Stary 06.03.2006, 22:46   #5
Lejek
Data rejestracji: 16.04.2003
Lejek w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Mam identyczny problem moglby ktos...;-( i mam pytanie bo jestem sklonny wgrac nowy firmware ale czy nie utrace gwarancji przez to...
dodam test z nero infotool (co oznaczaja bledy C2 przy DVD+R)
Ostatnio zmieniany przez Lejek : 06.03.2006 o godz. 22:56
Lejek jest offline
Stary 06.03.2006, 22:55   #6
ynsiwy
egipski bóg
Avatar użytkownika ynsiwy
Data rejestracji: 28.02.2004
firmware udostepniany jest na oficjalnej stronie producenta wiec jak wykonaszy wszystko wg. instrukcji nie bedzie problemow
ynsiwy jest offline
Wszystkie czasy w strefie CET. Aktualna godzina: 17:01.
