Stary 24.08.2004, 15:45   #16
.:SiN:.
Welcome In The Heaven
Avatar użytkownika .:SiN:.
Data rejestracji: 22.08.2004
.:SiN:. w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
heh ... alcohola uzywam ale... to nie to samo co clone cd
...nie wiecie jaki jest dokladny adres (do sciagniecia) biosu 812S@832S ??
.:SiN:. jest offline
Stary 24.08.2004, 17:16   #17
.:SiN:.
Wiecie co?? mniejsza z tym ... przerobilem 812S@832S jest luz ale
(sporne wersje 2 checkbox'ow)
-------------------Earlier shift (faster burn) for 8x +R ------------------------
This was one of the two components that made up what used to be called a "burn-adjusted" firmware. This patch will cause your drive to shift into higher speeds earlier and more aggressively, thus speeding up the burn. On some burners, this aggressive shifting may result in lower-quality burns, which is why it is highly recommended that you experiment with it and see if it works well for your particular drive. If it doesn't, then don't use it. If you select this, then you should also select the "force-shifting" patch (if it is available; for some firmwares, such as the _11S firmwares, "force-shifting" is not needed, nor is it an available option).
znaczy ze zagrywarka wczesniej zaczyna wchodzic na wyzsze predkosci , co na niektorych napedach moze spowodowac slabsza jakosc przegrywanej/nagrywanej plyty (a tego nikt nie lubi) - wiec ja doradzam wylaczyc , a poza tym to plytki +R co to wogole jest lepiej nagrywac na -R hehehe @ja nie wlaczylem@
--------------------Utilize "force-shifting" for 6x/8x burns---------------------------
This, along with the earlier shift patch (see above), made up the "burn-adjusted" firmwares. In some firmwares, there are OPC checks that are run at the 6x and 8x shift points. If the drive decides that the OPC result is too bad, it will cancel the upshift and wait until later before shifting. This resulted in slower burns, and because of a problem with laser calibration in some of the firmwares (though this problem seems to have disappeared in the newer firmwares), a failed upshift would actually result in higher errors (which is ironic, since the whole point of this check is to reduce errors). This patch will make the OPC check less sensitive, avoiding the failed upshift in most cases. The primary purpose of this patch is to speed up burns by eliminating the unnecessary slowdowns, though sometimes, this has a secondary side-effect of improving burn quality. Like the patch above, it is recommended that you try this out and see if it works well for your particular drive
no a to cos do tego pierwszego sprawdza czy moze wejsc na wyzszy bieg... a jak nie moze to czeka az bedzie moglo... metoda wolna i moze powodowac bledna kalibracje lasera... a patch opracowany by nagrywac szybciej bez zwolnien jednym slowem ... kicha ja tam w to nie wierze po zyjemy zobaczymy a tymczasem nagrywac tak jak nagrywarka pozwala @tego tez nie wlaczylem@
Stary 24.08.2004, 22:22   #18
legion
XII
Avatar użytkownika legion
Data rejestracji: 02.06.2004
Napisany przez .:SiN:.
ustawiena w omni sam sobie wybierasz jak najlepiej bedzie ci palic na nich
legion jest offline
Stary 25.08.2004, 03:00   #19
.:SiN:.
legion ja wiem....ale po co te 2 funkcje wlaczac?? hmmm?? sa malo przydatne... a lepiej chyba nagrac lepiej a nie krocej.... jakos ponad wszystko...
a mozna powiedziec chyba ze 2-3 minuty nikogo nie zbawia chyba ze ktos uczestniczy w turnieju na najszybsze wypalenie plytki dvd lol
Stary 25.08.2004, 10:16   #20
legion
XII
ja ich nie wlaczalem i postawilem na jakosc
legion jest offline
Stary 25.08.2004, 17:28   #21
.:SiN:.
no i to jest prawdziwe profesjonalne podejscie do wypalania plytek
nie jestem sam lol
pozdro
a cloncd jak nie szedl ta nie idzie :/
Wszystkie czasy w strefie CET. Aktualna godzina: 00:52.
