Stary 11.10.2009, 23:03   #1
leprom
Data rejestracji: 05.02.2006
leprom w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Question Problem z DAO w LG 4163B
Czy ktoś może mi pomóc ?
[img=http://img15.imageshack.us/img15/1161/problemzdao.jpg]
leprom jest offline   Odpowiedz cytując ten post
Stary 11.10.2009, 23:09   #2
Tu log jest potrzebny, a nie obrazek.
Stary 11.10.2009, 23:14   #3
leprom
Tu jest Log.
Kod:
L
1C81-A0K5-19E5-MAAX-400E-M6E8-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder:             <HL-DT-ST DVDRAM GSA-4163B>Version: A106 - HA 1 TA 0 - 7.10.1.0
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <AXV      CD/DVD-ROM      >Version: 2.2a - HA 1 TA 1 - 7.10.1.0
 Adapter driver:      <SCSI>                    HA 1
=== Scsi-Device-Map ===
DiskPeripheral       : Hitachi HDS721616PLAT80          atapi Port 0 ID 0  DMA: On
DiskPeripheral       : ST3120023A                       atapi Port 0 ID 1  DMA: On
CdRomPeripheral      : HL-DT-ST DVDRAM GSA-4163B        atapi Port 1 ID 0  DMA: On
CdRomPeripheral      : AXV     CD/DVD-ROM      2.2a  a347scsi Port 2 ID 0  DMA: Off
CdRomPeripheral      : AXV     CD/DVD-ROM      2.2a  a347scsi Port 2 ID 1  DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4163B  K:   CdRom0
AXV CD/DVD-ROM             L:   CdRom1
AXV CD/DVD-ROM             M:   CdRom2
AutoRun : 1
Excluded drive IDs:
BUFE           : 0
Physical memory     : 1023MB (1048048kB)
Free physical memory: 465MB (476816kB)
Memory in use       : 54 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
11.10.2009
Nagraj obraz DVD
22:11:30	#1 Text 0 File SCSIPTICommands.cpp, Line 424
22:11:30	#2 IMAGEGEN -10 File ImageGen.cpp, Line 366
	Image was written as DAO.
	DAOI:
	 MediaCatalogNumber = ''
	 TocType = 0x00
	 Finalized =  1
	 First/Last Track =  1 /  1
	  1: ISRC = ''
	     Blocksize = 2048
	     TrackMode = 'TRM_DATA_MODE1'
	     TrackConfig = 0x00
	     First/Last Index =  0 /  1
	     Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 7777714176
	CUES:
	MTYP: Mediumtype =  DVD (old format) (0x1C)
	Image file name: <C:\Documents and Settings\Leszek\Pulpit\Polowanie na czerwony Październik.nrg>
22:11:30	#3 Text 0 File Burncd.cpp, Line 3508
22:11:30	#4 Text 0 File DlgWaitCD.cpp, Line 307
	Last possible write address on media:  4173823 (927:30.73, 8151MB)
	Last address to be written:            3797711 (843:56.11, 7417MB)
22:11:30	#5 Text 0 File DlgWaitCD.cpp, Line 319
22:11:30	#6 Text 0 File DlgWaitCD.cpp, Line 2972
	Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R9 Double Layer
	 Disc Manufacturer ID: RICOHJPN, Media Type ID: D01, Product revision number: 67
	 Disc Application Code: 0, Extended Information Indicators: 3
22:11:30	#7 Text 0 File DlgWaitCD.cpp, Line 493
22:11:30	#8 Text 0 File ThreadedTransferInterface.cpp, Line 793
	 0: TRM_DATA_MODE1 (1 - DVD-ROM)
	    original disc pos #0 + 3797712 (3797712) = #3797712/843:56.12
	    not relocatable, disc pos for caching/writing not required/not required
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3797712 blocks [K: HL-DT-ST DVDRAM GSA-4163B]
22:11:31	#9 Text 0 File ThreadedTransferInterface.cpp, Line 995
	Prepare [K: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    7777714176, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	        0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
	        0 |        1 |   0 |    0x41 |        0 |        0 | 0x00
	        0 |        1 |   1 |    0x41 |  3797712 |        0 | 0x00
	  3797712 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
22:11:31	#10 Text 0 File SCSIPTICommands.cpp, Line 215
22:11:31	#11 Text 0 File Burncd.cpp, Line 4294
	Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
22:11:31	#12 Phase 24 File dlgbrnst.cpp, Line 1762
	Caching of files started
22:11:31	#13 Text 0 File Burncd.cpp, Line 4413
	Cache writing successful.
22:11:31	#14 Phase 25 File dlgbrnst.cpp, Line 1762
	Caching of files completed
22:11:31	#15 Phase 36 File dlgbrnst.cpp, Line 1762
	Burn process started at 2.4x (3 324 KB/s)
22:11:31	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2721
	Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
22:11:31	#17 Text 0 File DVDPlusDualLayer.cpp, Line 494
	Disc finalized, LBA total Image size: 3797712 (7417MB), Last LBA L0: 1898863 (3708MB)
22:11:35	#18 SPTI -1135 File SCSIPassThrough.cpp, Line 179
	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
	Sense Key:  0x03 (KEY_MEDIUM_ERROR)
	Sense Code: 0x0C
	Sense Qual: 0x00
	CDB Data:   0xBF 00 00 00 00 00 00 20 00 0C 00 00
	Sense Area: 0x70 00 03 00 00 00 00 10 35 2D 00 0E 0C
	Buffer x06751940: Len xc
	0x00 0A 00 00 00 00 00 00 00 1C F9 70
22:11:35	#19 Text 0 File DVDPlusDualLayer.cpp, Line 670
	L0 Data Zone Capacity not set.
	Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
22:11:35	#20 CDR -1135 File ThreadedTransferInterface.cpp, Line 1752
	Write error
22:11:35	#21 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
	Could not perform start of Disc-at-once
22:11:35	#22 Text 0 File ThreadedTransfer.cpp, Line 269
	Pipe memory size 83836800
22:11:35	#23 Phase 38 File dlgbrnst.cpp, Line 1762
	Burn process failed at 2.4x (3 324 KB/s)
22:11:35	#24 Text 0 File SCSIPTICommands.cpp, Line 261
22:11:39	#25 Text 0 File Cdrdrv.cpp, Line 11185
22:11:39	#26 Text 0 File SCSIPTICommands.cpp, Line 424
Existing drivers:
Registry Keys:
Ostatnio zmieniany przez joujoujou : 12.10.2009 o godz. 00:38 Powód: code
Stary 12.10.2009, 00:40   #4
Key medium error - zmień nośniki.
Stary 13.10.2009, 01:26   #5
Nagrywarka stara już jest.
Może coś pomóc wgranie najnowszego firmware, o ile jeszcze tego nie zrobiłeś.
Problem z Dogrywaniem Plików w LG GSA 4163B Gizmous Napędy optyczne DVD 0 18.03.2007 19:20
Problem z LG GSA - 4163B Greg077 Napędy optyczne DVD 7 25.02.2007 18:29
LG GSA 4163b Problem!!! leon_xx Napędy optyczne DVD 7 21.01.2007 08:53
Problem z LG GSA 4163b D8wid Napędy optyczne DVD 12 21.08.2006 07:55
Problem z nagrywarką LG, Nero 6.6.0.16 i trybem DAO freemanek Napędy optyczne DVD 7 02.10.2005 14:45
Wszystkie czasy w strefie CET. Aktualna godzina: 21:25.
