Data rejestracji: 05.02.2006
| #ads | |
Tu log jest potrzebny, a nie obrazek.
Tu jest Log.
Kod:
L 1C81-A0K5-19E5-MAAX-400E-M6E8-**** Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A106 - HA 1 TA 0 - 7.10.1.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <AXV CD/DVD-ROM >Version: 2.2a - HA 1 TA 1 - 7.10.1.0 Adapter driver: <SCSI> HA 1 === Scsi-Device-Map === DiskPeripheral : Hitachi HDS721616PLAT80 atapi Port 0 ID 0 DMA: On DiskPeripheral : ST3120023A atapi Port 0 ID 1 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 1 ID 0 DMA: On CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 1 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GSA-4163B K: CdRom0 AXV CD/DVD-ROM L: CdRom1 AXV CD/DVD-ROM M: CdRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 1023MB (1048048kB) Free physical memory: 465MB (476816kB) Memory in use : 54 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 11.10.2009 Nagraj obraz DVD 22:11:30 #1 Text 0 File SCSIPTICommands.cpp, Line 424 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 22:11:30 #2 IMAGEGEN -10 File ImageGen.cpp, Line 366 Image was written as DAO. DAOI: MediaCatalogNumber = '' TocType = 0x00 Finalized = 1 First/Last Track = 1 / 1 1: ISRC = '' Blocksize = 2048 TrackMode = 'TRM_DATA_MODE1' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 7777714176 CUES: MTYP: Mediumtype = DVD (old format) (0x1C) Image file name: <C:\Documents and Settings\Leszek\Pulpit\Polowanie na czerwony Październik.nrg> 22:11:30 #3 Text 0 File Burncd.cpp, Line 3508 Turn on Disc-At-Once, using DVD media 22:11:30 #4 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 4173823 (927:30.73, 8151MB) Last address to be written: 3797711 (843:56.11, 7417MB) 22:11:30 #5 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 22:11:30 #6 Text 0 File DlgWaitCD.cpp, Line 2972 Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R9 Double Layer Disc Manufacturer ID: RICOHJPN, Media Type ID: D01, Product revision number: 67 Disc Application Code: 0, Extended Information Indicators: 3 22:11:30 #7 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 22:11:30 #8 Text 0 File ThreadedTransferInterface.cpp, Line 793 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (1 - DVD-ROM) 2 indices, index0 (150) not provided original disc pos #0 + 3797712 (3797712) = #3797712/843:56.12 not relocatable, disc pos for caching/writing not required/not required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3797712 blocks [K: HL-DT-ST DVDRAM GSA-4163B] -------------------------------------------------------------- 22:11:31 #9 Text 0 File ThreadedTransferInterface.cpp, Line 995 Prepare [K: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7777714176, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 3797712 | 0 | 0x00 3797712 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 22:11:31 #10 Text 0 File SCSIPTICommands.cpp, Line 215 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 22:11:31 #11 Text 0 File Burncd.cpp, Line 4294 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 22:11:31 #12 Phase 24 File dlgbrnst.cpp, Line 1762 Caching of files started 22:11:31 #13 Text 0 File Burncd.cpp, Line 4413 Cache writing successful. 22:11:31 #14 Phase 25 File dlgbrnst.cpp, Line 1762 Caching of files completed 22:11:31 #15 Phase 36 File dlgbrnst.cpp, Line 1762 Burn process started at 2.4x (3 324 KB/s) 22:11:31 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 22:11:31 #17 Text 0 File DVDPlusDualLayer.cpp, Line 494 Disc finalized, LBA total Image size: 3797712 (7417MB), Last LBA L0: 1898863 (3708MB) 22:11:35 #18 SPTI -1135 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00 Sense Area: 0x70 00 03 00 00 00 00 10 35 2D 00 0E 0C Buffer x06751940: Len xc 0x00 0A 00 00 00 00 00 00 00 1C F9 70 22:11:35 #19 Text 0 File DVDPlusDualLayer.cpp, Line 670 L0 Data Zone Capacity not set. Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB) 22:11:35 #20 CDR -1135 File ThreadedTransferInterface.cpp, Line 1752 Write error K: HL-DT-ST DVDRAM GSA-4163B 22:11:35 #21 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752 Could not perform start of Disc-at-once 22:11:35 #22 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 22:11:35 #23 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 2.4x (3 324 KB/s) 22:11:35 #24 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 22:11:39 #25 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 22:11:39 #26 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Ostatnio zmieniany przez joujoujou : 11.10.2009 o godz. 23:38 Powód: code |
Key medium error - zmień nośniki.
| Problem z Dogrywaniem Plików w LG GSA 4163B | Gizmous | Napędy optyczne DVD | 0 | 18.03.2007 19:20 |
| Problem z LG GSA - 4163B | Greg077 | Napędy optyczne DVD | 7 | 25.02.2007 18:29 |
| LG GSA 4163b Problem!!! | leon_xx | Napędy optyczne DVD | 7 | 21.01.2007 08:53 |
| Problem z LG GSA 4163b | D8wid | Napędy optyczne DVD | 12 | 21.08.2006 06:55 |
| Problem z nagrywarką LG, Nero 6.6.0.16 i trybem DAO | freemanek | Napędy optyczne DVD | 7 | 02.10.2005 13:45 |
