.:Obey Your Master:.
Data rejestracji: 18.12.2003
Co się zwaliło że nie nagrywa??
Nie mogę nagrywać na DVD-R. Spaliłem już 3 płyty. Nero wywala mi taki komunikat. Nagrywara podpięta przez USB, wszystko zainstalowane. Aż się boję dalej próbować. To jest z log file z Nero: Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 1997-12-23 02:23:24 ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06 Nero version: 6.3.0.2 Recorder: <LITE-ON DVDRW SOHW-812S> Version: US05 - HA 4 TA 0 - 6.3.0.2 Adapter driver: <> HA 4 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <HL-DT-ST DVD-ROM GDR8162B>Version: 0015 - HA 0 TA 1 - 6.3.0.2 Adapter driver: <atapi> HA 0 === Scsi-Device-Map === CdRomPeripheral : TEAC CD-W552G atapi Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVD-ROM GDR8162B atapi Port 0 ID 1 DMA: On DiskPeripheral : ST380013AS 3.18 si3112r Port 2 ID 0 DMA: Off CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 3 ID 0 DMA: Off === CDRom-Device-Map === TEAC CD-W552G F: CDRom0 HL-DT-ST DVD-ROM GDR8162 G: CDRom1 AXV CD/DVD-ROM H: CDRom2 LITE-ON DVDRW SOHW-812S I: CDRom3 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 511MB (523760kB) Free physical memory: 251MB (257800kB) Memory in use : 50 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 14.10.2004 UDF/ISO compilation 18:42:36 #1 Phase 112 File dlgbrnst.cpp, Line 1800 DVD-Video files reallocation started 18:42:36 #2 Phase 114 File dlgbrnst.cpp, Line 1800 DVD-Video files reallocation completed (no file modified) 18:42:36 #3 Text 0 File Isodoc.cpp, Line 6029 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet :FALSE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 18:42:36 #4 Phase 111 File dlgbrnst.cpp, Line 1800 DVD-Video files sorted 18:42:36 #5 Text 0 File Reader.cpp, Line 118 Reader running 18:42:36 #6 Text 0 File Writer.cpp, Line 124 Writer LITE-ON DVDRW SOHW-812S running 18:42:36 #7 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000) |
Wyjechać Ci z bani ?
Data rejestracji: 26.02.2004
dma masz wylaczone na dysku twardym to po pierwsze a masz zainstalowane aspi
Choćby było z gówna nic mu w życiu nie dorówna. Telekomunikacja - nie burdel. Nie każdy klient musi być zadowolony. Żale kierować TU lub TU 50102055581111133885000064 INTELIGO Zbieram na drugi palnik - LITEK lub BENQ kazdy grosz sie liczy Juz nie szukam pracy ![]() Plextor PX-716A bios 1.04 RPC1 |
#3 | |
ja ma aspi 4.6 i smiga wiec moze zainstaluj nowsze 4.6 lub najnowsze 4.72 lub 4 nie pamietam dokladnie
#5 | |
Dobrze?? Lamerskie pytania ale robię to pierwszy raz. |
#6 | |
dupa a nie
Data rejestracji: 06.08.2004
dobrze robisz
a jakie masz nero ktora wersje
#8 | |
Iniemamocny
Data rejestracji: 01.09.2004
Nero wersja 6.3.0.2. Okienko jakie się pojawia przy starcie Nero poniżej.
-Edit- DMA mam włączone na AUTO. Zawsze tak miałem i nagrywało ok. |
wgraj nowsze nero to cos z nero jest
ja mam jako dodatek nero wersja 6.3.1.17 teraz 6.3.1.25 i mial xp pro z sp1 i teraz z sp2 i zadnego klopotu
#11 |
Ok dzięki nagrało płytkę, torchę nagrywara myślała, ale poszło.
Nie mogę jednak jej odtworzyć w Power DVD. Wyskakuje taki komunikat. Cóż to znowu za gówno. Wykorzystam to że zaglądacie do tego tematu.
#12 |
przeinstaluj powerdvd powinno pomoc
#13 | |
Iniemamocny
Ostatnio zmieniany przez adax : 14.10.2004 o godz. 23:22 |
#14 | |
#15 |
ja uzywam 5 deluxe i jak dla mnie jest super
wszystko pieknie chodzi lacznie z dts'em
