Stary 12.11.2007, 17:07   #1
kurak
Data rejestracji: 19.05.2005
kurak w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z nagraniem DVD DL
Witam. Mam problem z nagraniem płyty TDK DVD DL. Nagrywarkę mam:
Lite-on DVDRW SHM 165P6S. Używam Nero 7.7.5.1. Gdy próbuje nagrać obraz płyty poprzez burn image wywala mi taki błąd z poczatku:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.7.5.1
Internal Version: 7, 7, 5, 1
Recorder: <LITE-ON DVDRW SHM-165P6S>Version: MS0R - HA 1 TA 0 - 7.7.5.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <LITE-ON DVDRW SHM-165P6S>Version: MS0R - HA 1 TA 0 - 7.7.5.1
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW SHM-165P6S nvata Port 0 ID 0 DMA: Off
CdRomPeripheral : SONY CD-ROM CDU5221 nvata Port 0 ID 1 DMA: Off
DiskPeripheral : WDC WD1600JB-00GVC0 nvata Port 0 ID 2 DMA: Off
DiskPeripheral : ST3300620AS nvata Port 1 ID 2 DMA: Off
CdRomPeripheral : WV3170X SBE691M 1.0 aidynob0 Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW SHM-165P6S G: CDRom0
SONY CD-ROM CDU5221 H: CDRom1
WV3170X SBE691M I: CDRom2
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 574MB (588392kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
12.11.2007
Burn DVD Image
15:56:53 #1 Text 0 File SCSIPTICommands.cpp, Line 411
15:56:53 #2 Text 0 File Burncd.cpp, Line 3465
15:56:53 #3 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3313957 (736:26.07, 6472MB)
15:56:53 #4 Text 0 File DlgWaitCD.cpp, Line 318
15:56:53 #5 Text 0 File DlgWaitCD.cpp, Line 2912
Recorder: LITE-ON DVDRW SHM-165P6S, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RICOHJPN, Media Type ID: D01, Product revision number: 67
Disc Application Code: 0, Extended Information Indicators: 3
15:56:53 #6 Text 0 File DlgWaitCD.cpp, Line 490
15:56:53 #7 Text 0 File ThreadedTransferInterface.cpp, Line 823
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
original disc pos #0 + 3313958 (3313958) = #3313958/736:26.8
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3313808 blocks [G: LITE-ON DVDRW SHM-165P6S]
15:56:53 #8 Text 0 File ThreadedTransferInterface.cpp, Line 1026
Prepare [G: LITE-ON DVDRW SHM-165P6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 6786985984, ISRC ""
DAO layout:
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 3313958 | 3313808 | 0x00
0 | 1 | 1 | 0x41 | 3313958 | 3313808 | 0x00
3313958 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
15:56:53 #9 Text 0 File SCSIPTICommands.cpp, Line 209
15:56:53 #10 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 6x (8*310 KB/s)
15:56:53 #11 Text 0 File ThreadedTransferInterface.cpp, Line 2764
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:56:53 #12 Text 0 File DVDPlusDualLayer.cpp, Line 475
Disc finalized, LBA total Image size: 3313958 (6472MB), Last LBA L0: 1656991 (3236MB)
15:57:11 #13 SPTI -1106 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x04c2f400: Len xc
0x00 0A 00 00 00 00 00 00 00 19 48 A0
15:57:11 #14 Text 0 File DVDPlusDualLayer.cpp, Line 651
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
15:57:11 #15 CDR -1106 File ThreadedTransferInterface.cpp, Line 1785
Power calibration error
15:57:11 #16 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1785
Could not perform start of Disc-at-once
15:57:11 #17 Phase 38 File dlgbrnst.cpp, Line 1760
Burn process failed at 6x (8*310 KB/s)
15:57:11 #18 Text 0 File SCSIPTICommands.cpp, Line 254
15:57:14 #19 Text 0 File Cdrdrv.cpp, Line 10529
15:57:14 #20 Text 0 File SCSIPTICommands.cpp, Line 411
Existing drivers:
Registry Keys:
Co najdziwniejsze, jeszcze jakiś czas temu, nagrywarka nagrywała DL. Proszę o pomoc. Z góry dzięki.
kurak jest offline   Odpowiedz cytując ten post
Stary 12.11.2007, 17:24   #2
Zaktualizuj firmware i zajmij si***281; DMA.
https://forum.cdrinfo.pl/showthread.php?t=57073
Stary 13.11.2007, 19:19   #3
Chudus
Data rejestracji: 12.11.2007
Chudus w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Angry Nudze bo znów o DVD DL
Posiadam Benq DW1650. Tak to teraz bywa ***380;e gierki maj***261; grubo ponad 5GB. Z pomoc***261; przysz***322;y mi Platinum DVD9.... No ale wyskakuje b***322;***261;d czym bym nie przegrywa***322; a oto log:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 1999-09-10 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 17:35:32
Nero Version: 6.6.0.14
Internal Version: 6, 6, 0, 14d
(Nero Express)
Recorder: <BENQ DVD DD DW1650> Version: BCIC - HA 1 TA 0 - 6.6.0.14
Adapter driver: <atapi> HA 1
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <BENQ DVD DD DW1650 >Version: BCIC - HA 1 TA 0 - 6.6.0.14
DiskPeripheral : ST380011A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : BENQ DVD DD DW1650 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON CD-RW SOHR-5238S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : LS2013H MHE140B atapi Port 2 ID 0 DMA: On
CdRomPeripheral : LS2013H MHE140B 1.0 ar420r99 Port 3 ID 0 DMA: Off
CdRomPeripheral : LS2013H MHE140B 1.0 ar420r99 Port 3 ID 1 DMA: Off
BENQ DVD DD DW1650 E: CDRom0
LITE-ON CD-RW SOHR-5238S F: CDRom1
LS2013H MHE140B H: CDRom4
LS2013H MHE140B G: CDRom2
LS2013H MHE140B I: CDRom3
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1279MB (1310236kB)
Free physical memory: 792MB (811944kB)
Memory in use : 38 %
Use Inquiry : 1
13.11.2007
Burn DVD Image
17:16:59 #1 Text 0 File Burncd.cpp, Line 2945
BENQ DVD DD DW1650
Seamless Link activated
17:16:59 #2 Text 0 File Reader.cpp, Line 127
Reader running
17:16:59 #3 Text 0 File Writer.cpp, Line 122
Writer BENQ DVD DD DW1650 running
17:16:59 #4 Text 0 File Burncd.cpp, Line 3230
17:16:59 #5 Text 0 File DlgWaitCD.cpp, Line 267
17:16:59 #6 Text 0 File DlgWaitCD.cpp, Line 279
17:16:59 #7 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: BENQ DVD DD DW1650, Media type: DVD+R9 Double Layer
17:16:59 #8 Text 0 File DlgWaitCD.cpp, Line 445
17:16:59 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3313958 blocks [BENQ DVD DD DW1650]
17:16:59 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [BENQ DVD DD DW1650] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
3313958 | lead-out | 1 | 0x41 | 0x00
17:16:59 #11 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
17:16:59 #12 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
17:16:59 #13 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
17:16:59 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11 080 KB/s)
17:16:59 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643
17:16:59 #16 Text 0 File DVDPlusDualLayer.cpp, Line 445
17:17:00 #17 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0C650600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
17:17:00 #18 Text 0 File DVDPlusDualLayer.cpp, Line 595
L0 Data Zone Capacity set to 1656992 (1948A0h, 3236MB) -> OK, confirmed setting
17:17:00 #19 CDR -1205 File DVDPlusDualLayer.cpp, Line 622
Burning Layer 1
17:17:00 #20 Text 0 File DVDPlusDualLayer.cpp, Line 632
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
17:17:00 #21 SCSI -1066 File Cdrdrv.cpp, Line 1182
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
17:17:00 #22 Text 0 File DVDR.cpp, Line 5770
Drive: BENQ DVD DD DW1650
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
17:17:00 #23 CDR -1211 File DVDR.cpp, Line 4937
Book Type set to: DVD-ROM
17:17:00 #24 Text 0 File DVDPlusRW.cpp, Line 655
Start write address at LBA 0
DVD high compatibility mode: No
17:17:53 #25 SCSI -1176 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0C1C0000
Sense Code: 0x72
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x72 0x01
17:17:53 #26 CDR -1176 File Writer.cpp, Line 311
Session fixation error
17:17:53 #27 Text 0 File ThreadedTransfer.cpp, Line 228
17:17:53 #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
17:17:54 #29 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
17:17:54 #30 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
17:17:54 #31 Text 0 File DVDR.cpp, Line 5770
17:17:54 #32 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11 080 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 2007-03-08 00:51:00
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 1999-09-10 12:06:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 2007-03-08 00:51:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 2004-08-04 07:59:42 (Adapter driver for rec)
Registry Keys:
Dodam ***380;e mam zainstalowane ATAPI i pow***322;***261;czne DMA. Raz ju***380; nagra***322;em jedna p***322;yte DL.
Ostatnio zmieniany przez Chudus : 13.11.2007 o godz. 19:23
Chudus jest offline   Odpowiedz cytując ten post
Wszystkie czasy w strefie CET. Aktualna godzina: 23:36.
