Stary 18.09.2007, 10:20   #1
kubasek111
Data rejestracji: 18.09.2007
kubasek111 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z nagrywaniem na DVD
Witam,
mam problem. Chcę nagrać foldery z danymi (mp3) na płytę DVD. Wyskakuje błąd dot. kalibracji. Poniżej przedstawiam log. Cyz ktoś może powiedzieć, co się dzieje?
Kod:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 17:35:32
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15e
 (Nero Express)
Recorder:             <TSSTcorp CD/DVDW SH-W162C>Version: TS10 - HA 1 TA 0 - 6.6.0.15
 Adapter driver:      <atapi>                   HA 1
 Drive buffer  :      2048kB
 Bus Type      :      via Inquiry data (1) -> ATAPI, detected: ATAPI
 Connected to MMC as unknown drive with class-nr : 1
 Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM:               <TSSTcorp CD/DVDW SH-W162C>Version: TS10 - HA 1 TA 0 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral       : WDC WD800BB-22JHC0               atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : TSSTcorp CD/DVDW SH-W162C        atapi Port 1 ID 0  DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW SH-W162C  D:   CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 510MB (522672kB)
Free physical memory: 133MB (137056kB)
Memory in use       : 73 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
15.9.2007
ISO compilation
10:41:21	#1 Text 0 File Isodoc.cpp, Line 6314
	Iso document burn settings
	Simulate                : FALSE
	Write                   : TRUE
	Finalize CD             : TRUE
	Multisession            : FALSE
	Burning mode            : DAO
	Mode                    : 1
	ISO Level               : 1 (Max. of 11 = 8 + 3 char)
	Character set           : ISO 9660
	Joliet                  : TRUE
	Allow more than 255 characters in path  : TRUE
	Write ISO9660 ;1 file extensions        : TRUE
10:41:21	#2 Text 0 File Reader.cpp, Line 127
	Reader running
10:41:21	#3 Text 0 File Writer.cpp, Line 122
	Writer TSSTcorp CD/DVDW SH-W162C running
10:41:21	#4 ISO9660GEN -11 File geniso.cpp, Line 3309
10:41:22	#5 Text 0 File Burncd.cpp, Line 3231
10:41:22	#6 Text 0 File DlgWaitCD.cpp, Line 267
	Last possible write address on media:  2298495 (510:46.45, 4489MB)
	Last address to be written:            2217231 (492:43.06, 4330MB)
10:41:22	#7 Text 0 File DlgWaitCD.cpp, Line 279
10:41:22	#8 Text 0 File DlgWaitCD.cpp, Line 2457
	Recorder: TSSTcorp CD/DVDW SH-W162C, Media type: DVD-R
	 Disc Manufacturer: CMC MA - G. AM3
	 Disc Application Code: 64, Disc Physical Code: 193
10:41:22	#9 Text 0 File DlgWaitCD.cpp, Line 445
10:41:22	#10 Text 0 File ThreadedTransferInterface.cpp, Line 830
	 0: TRM_DATA_MODE1 ()
	    original disc pos #0 + 2217232 (2217232) = #2217232/492:43.7
	    relocatable, disc pos for caching/writing not required/ required, no patch infos
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2217232 blocks [TSSTcorp CD/DVDW SH-W162C]
10:41:22	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
	Prepare recorder [TSSTcorp CD/DVDW SH-W162C] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 Tracks 1 to 1:
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4540891136, ISRC ""
	DAO layout:
	 __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
	       0 |  lead-in |   0 |    0x41 | 0x00
	       0 |        1 |   0 |    0x41 | 0x00
	       0 |        1 |   1 |    0x41 | 0x00
	 2217232 | lead-out |   1 |    0x41 | 0x00
10:41:22	#12 Phase 24 File dlgbrnst.cpp, Line 1832
	Caching of files started
10:41:22	#13 Text 0 File Burncd.cpp, Line 4116
	Cache writing successful.
10:41:22	#14 Phase 25 File dlgbrnst.cpp, Line 1832
	Caching of files completed
10:41:22	#15 Phase 36 File dlgbrnst.cpp, Line 1832
	Burn process started at 4x (5 540 KB/s)
10:41:22	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
10:41:22	#17 Text 0 File DVDR.cpp, Line 2340
	Recording mode: Sequential Recording Mode
10:41:22	#18 Text 0 File Mmc.cpp, Line 21627
	Set BUFE: Super Link -> ON
10:41:22	#19 Text 0 File DVDR.cpp, Line 2494
	Start write address at LBA 0
10:41:22	#20 Text 0 File Cdrdrv.cpp, Line 8821
	---- DVD Structure: Physical Format Information (00h) ----
	Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD-R   (2), Part Version: 5
	 Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
	 End Physical Sector Number of Data Area:      0 h
	 End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
	  Start sector number of the current Border-Out: 0 h
	  Start sector number of the next Border-In:     0 h
	 Media Specific [16..63]:
	      00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00    .`...0@P...!....
	      00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
10:43:32	#21 SCSI -1106 File Cdrdrv.cpp, Line 1436
	SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0AE50000
	Status:     0x04 (0x01, SCSI_ERR)
	HA-Status   0x00 (0x00, OK)
	TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
	Sense Key:  0x03 (KEY_MEDIUM_ERROR)
	Sense Code: 0x73
	Sense Qual: 0x03
	CDB Data:   0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
	Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
	            0x00 0x00 0x00 0x00 0x73 0x03
10:43:32	#22 CDR -1106 File Writer.cpp, Line 311
	Power calibration error
10:43:32	#23 Text 0 File ThreadedTransfer.cpp, Line 228
10:43:32	#24 Text 0 File ThreadedTransfer.cpp, Line 222
	conversion idle, stopping reader
10:43:32	#25 Text 0 File DVDR.cpp, Line 2732
	EndDAO: Last written address was -1
10:43:39	#26 Phase 38 File dlgbrnst.cpp, Line 1832
	Burn process failed at 4x (5 540 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 2006-05-19 23:16:24
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 2006-05-16 22:23:54 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 20:59:44 (Adapter driver for rec)
Registry Keys:
Ostatnio zmieniany przez Reetou : 18.09.2007 o godz. 11:08
kubasek111 jest offline   Odpowiedz cytując ten post
Stary 18.09.2007, 11:38   #2
yahol
Głupi Yasio
Avatar użytkownika yahol
Data rejestracji: 27.05.2003
DMA!!!, ASPI, itepe....
tasiemka 80, naped solo na master.
itepe....
Stary 18.09.2007, 11:43   #3
Kunte
MasteR of PuppetS
Avatar użytkownika Kunte
Data rejestracji: 31.08.2005
Kunte zaczyna zdobywać reputację <1 - 49 pkt>
Po 1 szukałeś na forum? Było już o tym parę razy.
Po 2 jaka nagrywarka i w jaki sposób podłączona.
Po 3 to co napisał yahol .
Po 4 sprawdź na innym komputerze.
Po 5 jak to błąd kalibracji to może to oznaczać koniec nagrywarki.
Kunte
Kunte jest offline   Odpowiedz cytując ten post
Stary 18.09.2007, 13:33   #4
seku
Avatar użytkownika seku
wpierw to ja bym zmieni***322; no***347;niki bo te nie s***261; pierwszej jako***347;ci
polecam np. Verbatim SONY
kiepskiej jako***347;ci no***347;nik w tym wypadku domniemywam TDK lub Platinum w po***322;***261;czeniu z nie najlepsza spawarka nie wr***243;***380;y nic dobrego
Stary 18.09.2007, 16:09   #5
kubasek111
dzi***281;ki
Wszystkie czasy w strefie CET. Aktualna godzina: 20:42.
