Data rejestracji: 13.01.2007
Problem z nagrywaniem (LH-18A1H)
Dopiero co kupi***322;em t***261; nagrywark***281;, kupi***322;em sobie p***322;ytki TDK DVD-R, instaluje Nero kt***243;re mi do***322;***261;czyli do nagrywarki czyli Nero Express 6.6.1.6 Bundle no i chce nagrywa***263;, zaczyna nagrywanie a tu b***322;***261;d: b***322;ad fiksacji sesji i ***380;e nie mo***380;e wykona***263; operacji zako***324;cz w trybie DAO.
Kod:
qwerty Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:31 NT-SPTI used Nero Version: 6.6.1.6 Internal Version: 6, 6, 1, 6 (Nero Express) Recorder: <LITE-ON DVDRW LH-18A1H> Version: HL01 - HA 1 TA 0 - 6.6.1.6 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: <LITE-ON DVDRW LH-18A1H >Version: HL01 - HA 1 TA 0 - 6.6.1.6 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === CdRomPeripheral : LITE-ON DVDRW LH-18A1H nvatabus Port 1 ID 0 DMA: Off CdRomPeripheral : LITE-ON LTR-52327S nvatabus Port 1 ID 1 DMA: Off DiskPeripheral : ST3160811AS nvatabus Port 2 ID 0 DMA: Off === CDRom-Device-Map === LITE-ON DVDRW LH-18A1H G: CDRom0 LITE-ON LTR-52327S M: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523760kB) Free physical memory: 106MB (109384kB) Memory in use : 79 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 15.1.2007 Kompilacja ISO 00:32:49 #1 Text 0 File Isodoc.cpp, Line 6475 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 00:32:49 #2 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 72704KB of Memory 00:32:49 #3 Text 0 File Reader.cpp, Line 124 Reader running 00:32:49 #4 Text 0 File Writer.cpp, Line 122 Writer LITE-ON DVDRW LH-18A1H running 00:32:49 #5 ISO9660GEN -11 File geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 00:32:49 #6 Text 0 File Burncd.cpp, Line 3305 Turn on Disc-At-Once, using DVD media 00:32:50 #7 Text 0 File DlgWaitCD.cpp, Line 281 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1791167 (398:02.17, 3498MB) 00:32:50 #8 Text 0 File DlgWaitCD.cpp, Line 293 Write in overburning mode: NO (enabled: CD) 00:32:50 #9 Text 0 File DlgWaitCD.cpp, Line 2612 Recorder: LITE-ON DVDRW LH-18A1H, Media type: DVD-R Disc Manufacturer: TTG02 - Disc Application Code: 64, Disc Physical Code: 193 00:32:50 #10 Text 0 File DlgWaitCD.cpp, Line 459 >>> Protocol of DlgWaitCD activities: <<< ========================================= 00:32:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 1791168 (1791168) = #1791168/398:2.18 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1791168 blocks [LITE-ON DVDRW LH-18A1H] -------------------------------------------------------------- 00:32:50 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [LITE-ON DVDRW LH-18A1H] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3668312064, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 1791168 | lead-out | 1 | 0x41 | 0x00 00:32:50 #13 Text 0 File SCSIPassThrough.cpp, Line 38 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 00:32:50 #14 Text 0 File SCSIPassThrough.cpp, Line 83 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 00:32:50 #15 Phase 24 File dlgbrnst.cpp, Line 1685 Caching of files started 00:32:50 #16 Text 0 File Burncd.cpp, Line 4145 Cache writing successful. 00:32:50 #17 Phase 25 File dlgbrnst.cpp, Line 1685 Caching of files completed 00:32:50 #18 Phase 36 File dlgbrnst.cpp, Line 1685 Burn process started at 4x (5 540 KB/s) 00:32:50 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 00:32:50 #20 Text 0 File DVDR.cpp, Line 2743 Recording mode: Sequential Recording Mode for Multisession 00:32:50 #21 Text 0 File DVDR.cpp, Line 2899 Start write address at LBA 0 DVD high compatibility mode: Yes 00:32:50 #22 Text 0 File Cdrdrv.cpp, Line 8648 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 0 h Start sector number of the next Border-In: 0 h Media Specific [16..63]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00:33:15 #23 SPTI -1106 File SCSIPassThrough.cpp, Line 289 G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03 Buffer x08440000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00:33:15 #24 CDR -1106 File Writer.cpp, Line 311 Power calibration error G: LITE-ON DVDRW LH-18A1H 00:33:15 #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 00:33:16 #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 00:33:16 #27 Text 0 File DVDR.cpp, Line 3139 EndDAO: Last written address was -1 00:33:16 #28 Phase 133 File dlgbrnst.cpp, Line 1685 Writing short lead-out 00:33:16 #29 SPTI -1176 File SCSIPassThrough.cpp, Line 289 G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x72 Sense Qual: 0x04 CDB Data: 0x5B 01 02 00 00 03 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 04 00:33:16 #30 CDR -1176 File WriterStatus.cpp, Line 167 Session fixation error G: LITE-ON DVDRW LH-18A1H 00:33:16 #31 TRANSFER -24 File WriterStatus.cpp, Line 167 Could not perform end of Disc-at-once 00:33:16 #32 Phase 38 File dlgbrnst.cpp, Line 1685 Burn process failed at 4x (5 540 KB/s) Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 2006-08-25 04:47:00 File 'Drivers\PXHELP20.SYS': Ver=3.00.33a, size=36528 bytes, created 2006-08-25 04:47:00 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Ostatnio zmieniany przez Reetou : 15.01.2007 o godz. 01:48 |
CdRomPeripheral : LITE-ON LTR-52327S nvatabus Port 1 ID 1 DMA: Off DiskPeripheral : ST3160811AS nvatabus Port 2 ID 0 DMA: Off DMA ma by***263; ON - jak to zrobi***263; poszukaj na forum - by***322;o setki razy |
#3 | |
Nieważne, okazało się, że moja nagrywarka nie nagrywa płytek bez znaczka RW, dziwne. Teraz włożyłem emteca z logiem RW i nagrało, hmmm... BTW co oznacza to RW? Myślałem że RW to płytki do wielokrotnego zapisu, a jednak nie tylko... W każdym razie tamte TDK były jakeiś stare, kupione daaawno przez nabyciem spawarki. Teraz typu w sklepie mówuił że ma tylko te z RW i takie też będę kupował Nie wiem o co w tym wszystkim chodzi ale skoro te RW nagrywa to będę je kupował
No to exxxtra
![]() Tylko pami***281;taj przy nast***281;pnej zr***261;banej p***322;ytce o http://forum.cdrinfo.pl/showpost.php...33&postcount=2 ... |
Nie rozumiem, piszecie ***380;e z tego loga wynika ***380;e nie mam dma a ja otwieram mened***380;er urz***261;dze***324; i widze co***347; takiego:
![]() To jak mam to DMA czy nie, je***347;li nie, to jak ustawi***263;, nie znalaz***322;***281;m an forum KONKRETNEJ instrukcji jak to zrobi***263; w WinXP. |
Wywal kontrolery nvidii i daj windowsowi zainstalowa***263; w***322;asne (zawsze mo***380;esz do nich wr***243;ci***263; jakby co) - nie raz na forum opisywano problemy wynikaj***261;ce z u***380;ywania w***322;a***347;nie kontroler***243;w nforce.
