Data rejestracji: 25.11.2006
Witam!
Zdenerwowałem siętroche;/ Proboweałem dzisiaj nagrac DVD i wyskakiwał mi taki bląd: ![]() Pełny raport: Kod:
1K22-1867-0795-66M4-5774-9233-**** Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 8.3.6.0 Internal Version: 8, 3, 6, 0 Recorder: <Optiarc DVD RW AD-5170A> Version: 1.11 - HA 1 TA 0 - 8.3.6.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default CD-ROM: <Optiarc DVD RW AD-5170A >Version: 1.11 - HA 1 TA 0 - 8.3.6.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD1600YS-01SHB0 atapi Port 0 ID 0 DMA: On DiskPeripheral : SAMSUNG HD401LJ atapi Port 1 ID 0 DMA: On CdRomPeripheral : TP2663U GMR300W atapi Port 4 ID 0 DMA: On CdRomPeripheral : Optiarc DVD RW AD-5170A 1.11 JRAID Port 5 ID 0 DMA: Off === CDRom-Device-Map === Optiarc DVD RW AD-5170A F: CdRom0 TP2663U GMR300W G: CdRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 2046MB (2095532kB) Free physical memory: 1319MB (1351532kB) Memory in use : 35 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 24.2.2009 Kompilacja ISO 15:24:22 #1 Text 0 File SCSIPTICommands.cpp, Line 450 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 15:24:23 #2 Text 0 File Isodoc.cpp, Line 6713 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 15:24:23 #3 ISO9660GEN -11 File Geniso.cpp, Line 3349 First writeable address = 0 (0x00000000) 15:24:23 #4 Text 0 File Burncd.cpp, Line 3568 Turn on Disc-At-Once, using DVD media 15:24:23 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142 FS Settings: using validator 'CUDFSettingsValidatorDVD' ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical' Changing UDF revision from '1.02' to '1.02' 15:24:23 #6 Text 0 File DlgWaitCD.cpp, Line 311 Last possible write address on media: 2297887 (510:38.37, 4488MB) Last address to be written: 2222863 (493:58.13, 4341MB) 15:24:23 #7 Text 0 File DlgWaitCD.cpp, Line 323 Write in overburning mode: NO (enabled: CD) 15:24:23 #8 Text 0 File DlgWaitCD.cpp, Line 2948 Recorder: Optiarc DVD RW AD-5170A, Media type: DVD-R Disc Manufacturer ID: <INFOME> <DIAR30> Disc Application Code: 64, Disc Physical Code: 193 15:24:23 #9 Text 0 File DlgWaitCD.cpp, Line 497 >>> Protocol of DlgWaitCD activities: <<< ========================================= 15:24:23 #10 Text 0 File ThreadedTransferInterface.cpp, Line 754 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2222864 (2222864) = #2222864/493:58.14 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2222864 blocks [F: Optiarc DVD RW AD-5170A] -------------------------------------------------------------- 15:24:26 #11 Text 0 File ThreadedTransferInterface.cpp, Line 956 Prepare [F: Optiarc DVD RW AD-5170A] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4552425472, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 2222864 | 0 | 0x00 2222864 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 15:24:26 #12 Text 0 File SCSIPTICommands.cpp, Line 240 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 15:24:26 #13 Text 0 File Burncd.cpp, Line 4359 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 15:24:26 #14 Phase 24 File dlgbrnst.cpp, Line 1767 Caching of files started 15:24:26 #15 Text 0 File Burncd.cpp, Line 4481 Cache writing successful. 15:24:26 #16 Phase 25 File dlgbrnst.cpp, Line 1767 Caching of files completed 15:24:26 #17 Phase 36 File dlgbrnst.cpp, Line 1767 Burn process started at 8x (11*080 KB/s) 15:24:26 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2673 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 15:24:26 #19 Text 0 File DVDR.cpp, Line 3297 Recording mode: Sequential Recording Mode for Multisession 15:24:26 #20 Text 0 File DVDR.cpp, Line 3451 Start write address at LBA 0 DVD high compatibility mode: Yes 15:24:26 #21 Text 0 File Cdrdrv.cpp, Line 10187 ---- Disc Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) Outer Limit of Data Recordable Area: 26127F h Data in Burst Cutting Area (BCA) does not exist Revision number of maximum recording speed: 6.0 Revision number of minimum recording speed: - Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - - Class: 0, Extended part version: 33 Start PSN of the Extra Border Zone: 2FE10 h Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h Media Specific [16..783]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 01 40 C1 FD 9E D8 52 00 - 02 85 0E 0D 99 AB 80 00 .@....R......... 03 49 4E 46 4F 4D 45 00 - 04 44 49 41 52 33 30 00 .INFOME..DIAR30. 05 88 80 00 00 00 02 00 - 06 09 0B 15 87 78 90 00 .............x.. 07 88 80 00 00 00 00 00 - 08 08 13 0D 11 0C 08 00 ................ 09 95 07 0E 0B 78 88 00 - 0A A0 00 20 00 20 10 00 .....x.......... 0B 09 19 17 97 88 85 00 - 0C B6 B9 2B 82 30 23 00 ...........+.0#. 0D 00 00 D0 00 00 00 00 - 0E 09 23 35 2D 25 19 00 ..........#5-%.. 0F 50 17 27 15 98 B5 00 - 10 88 80 00 00 00 00 00 .P.'............ 11 00 00 00 00 00 00 00 - 12 09 2D 37 2F 2D 19 00 ..........-7/-.. 13 50 1D 2B 15 A8 B5 00 - 14 88 80 00 00 00 00 00 .P.+............ 15 00 00 00 00 00 00 00 - 16 09 3C 45 3D 20 29 00 ..........<E=.). 17 70 1F 2F 1A A7 B5 00 - 18 88 8C 00 0C 00 0C 00 .p./............ 19 00 00 00 00 00 00 00 - 1A 08 53 44 3D 2C 21 00 ..........SD=,!. 1B 70 1D 2C 13 6B B5 00 - 1C 88 8C 00 0C 00 0C 00 .p.,.k.......... 1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 15:24:26 #22 Text 0 File DVDR.cpp, Line 3589 Reserved Track size: 2222864 (21EB10h, 4341MB) -> return code 0 15:24:26 #23 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 15:25:33 #24 SPTI -1106 File SCSIPassThrough.cpp, Line 214 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03 Buffer x09590040: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15:25:33 #25 CDR -1106 File Writer.cpp, Line 306 Power calibration error F: Optiarc DVD RW AD-5170A 15:25:35 #26 Phase 133 File dlgbrnst.cpp, Line 1767 Writing short lead-out 15:25:36 #27 SPTI -1023 File SCSIPassThrough.cpp, Line 214 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1023) CDB Data: 0x5B 01 02 00 00 03 00 00 00 00 00 00 Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x2C Sense Qual: 0x00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 2C 15:25:38 #28 Text 0 File DVDR.cpp, Line 3857 EndDAO: Last written address was -1 (FFFFFFFFh)Close Session/Border, function 2, track: 3, finalize disc: NO, ret: -1023 15:25:38 #29 CDR -1023 File WriterStatus.cpp, Line 292 Command sequence error F: Optiarc DVD RW AD-5170A 15:25:38 #30 TRANSFER -24 File WriterStatus.cpp, Line 292 Could not perform end of Disc-at-once 15:25:39 #31 Phase 38 File dlgbrnst.cpp, Line 1767 Burn process failed at 8x (11*080 KB/s) 15:25:40 #32 Text 0 File SCSIPTICommands.cpp, Line 287 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 15:25:43 #33 Text 0 File Cdrdrv.cpp, Line 11450 DriveLocker: UnLockVolume completed 15:25:43 #34 Text 0 File SCSIPTICommands.cpp, Line 450 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Dodam, ze nigdy wczesniej tak się nie robiło.
Ostatnio zmieniany przez joujoujou : 24.02.2009 o godz. 16:37 Powód: code ;p |
Włącz DMA ( https://forum.cdrinfo.pl/showthread.php?t=57073 ) i zmień nośniki.
na forum "key medium error"
#3 | |
Sprawdzałem to: ![]() I wszędzie mam włączone DMA
Sprawdzałem nagrywarkę na innym komputerze (z inną taśmą) i było to samo + pisało coś z kalilbracją.
Co można w tej sytuacji zrobić? Czy moze pomoc zainstalowanie nowego firmware? Jesli tak to jak moge sprawdzić jaki jest najnowszy i najlepszy firmware (wersja), oraz skąd ściągnąc, tak aby było to wiarygone źródło- bo na stronei producenta nic takiego nie znalazłem ;/
A z innymi płytami sprawdziłeś? Te Infome nie mają strategii zapisu w biosie tej nagrywarki. Weź jakiegoś Verbatima i zobacz.
Własnie probowałem wypalic Verbatima i się nie dało. Probowałem jeszce Philipsa.
Dodatkowo sprobowałem wypalic tego samego verbatima na drugim kompie (inna nagrywarka- tej samej firmy, ale starsza) i sięudało, ale kiedy probowałem ją odczytac w tej nagrywarce o ktorej teraz mowa- nie dało się- wywalało błąd. Zaktualizowałem firmware Najpierw z 1.11, do 1.12, było to samo, potem znalazłem najnowszy- 1.14 i zainstalowałem go. W tym momencie nagrywarka odczytałą mi wczesniej wypalne DVD, o którym pisałem wyzej i było ok, ale nagrywac nadal nie chce ^^
No to chyba koniec nadszedł. Już nie doradzam pogrzebu, teraz, podobno, tylko, trzeba utylizować.
Zrobiłem jeszcze coś takiego:
Jesli chodzi o DMA, to co moze byc nei tak? Sprawdziłem wszystkie kontrolery, wyglądały tak: ![]() Jesli chdozi o napędy, to mam tylko ten jeden napęd podłączony, oraz dwa dyski sata. Płytki to: Verbatim i Philips. ///edit: Everest: http://www.nnh.na7.pl/Report.htm Odinstalowałem kontrolery, potem 3x reset. Napęd był ustawiony na master i podpięty pod ostatnie złącze w tasmie. Probowalem jeszce raz nagrac- prędkośc 8, symulacja zakończona powodzenie, ale przy nagrywaniu było to samo.. Błąd kalibracji mocy Zapis krótkiego Lead-Out Błąd sekwencji polecenia Nie mozna wykonać polecenia Zakończ w trybie DAO. Do tego dodam, ze płytki się nie "palą" po tych błędach.
#9 | |
A łyżka na to: niemożliwe!
![]() W logu wyraźnie widać: Cytat:
![]() Skoro wymiana taśmy nie pomogła, skoro na innym kompie jest podobnie, to przed wyrzuceniem na śmietnik wgraj coś stąd, ale nie rób sobie zbyt dużych nadziei. ![]()
Ja bym jeszcze poinstalował wszystkie drivery do płyty... Co to za nieznane urządzenia?
#11 |
Nie wiem, co to za urządzenia... Wkładałem płytke z windowse, płytke ze sterownikami do płyty i urządzeń na niej i nic mi nie znalazło.
Sprawa wygląda tak (troche smiesznie, jak ta nagrywarka ma byc zepsuta ^^), ze padł mi zasilacz i cos było spieprzone na karcie graficznej. Oddałem kompa do serwisu (bez dysków, które zatrzymałem w domu). Komputer otrzymałem po miesiącu ;/ Dodatkowo, nie oddali mi jeszcze karty graficznej, bo nie została naprawiona i dali mi inną w zastępstwo (ATI, gdzie wczesniej takze posiadałem ATI). Podłączyłem dyski i wszystko wydawało się być OK. Poza tym, ze lampki na obudowie mi świecą słabiej ;/ Dopiero wczoraj proboweałem cos nagrac i okazało się ze jest jakis problem- własnie ten, o ktorym jest ten temat. Aha, dodam, ze oba dyski podłączałęm jeszcze w innym kompie, zeby miec dostęp do dancyh, ale nie jako dysk startucjący (zeby z niego odpalał sięwindows), wiec ze sterownikami chyba nic sie nie powinno stac.
| Nagrywarka LG widzi płyty CDR a nie widzi DVD | Jerremi | Napędy optyczne CD | 3 | 23.10.2005 00:45 |
| Projekt Freeware | Calme | Komputery - oprogramowanie i sprzęt | 0 | 16.05.2005 21:31 |
| Błąd przy nagrywaniu płyty w Nero 6 | tyfus | Napędy optyczne CD | 2 | 15.08.2003 20:42 |
| Błąd przy nagrywaniu CDRW | pigeon | Napędy optyczne CD | 3 | 03.07.2003 12:25 |
| Yamaha 2100E konflikt z dvd rom przy nagrywaniu | bystry | Napędy optyczne CD | 2 | 05.04.2001 02:10 |
