Stary 03.06.2005, 12:05   #1
patryciusz
LAIK(onik)
Avatar użytkownika patryciusz
Data rejestracji: 03.06.2005
patryciusz w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z NERO??
Witam wszystkich.
Mam problem z nagraniem na płytę dvd kilku plików avi.Przy próbie wypalania
wywala mi błąd...Bardzo proszę o pomoc.Oto LOG z NERO:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=6656 bytes, created 2005-02-07 13:44:02
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:34
Nero Version: 6.6.0.13
Internal Version: 6, 6, 0, 13c
(Nero Express)
Recorder: <LITE-ON DVDRW SOHW-1673S>Version: JS01 - HA 1 TA 0 - 6.6.0.13
Adapter driver: <nvidesm> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <WIRTUAL CD/DVD-ROM >Version: 2.2a - HA 2 TA 0 - 6.6.0.13
Adapter driver: <a347scsi> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : ST3120026A 3.06 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-STRW/DVD GCC-4521B1.00 nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : LITE-ON DVDRW SOHW-1673SJS01 nvidesm Port 1 ID 0 DMA: Off
CdRomPeripheral : WIRTUAL CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST RW/DVD GCC-4521B I: CDRom0
LITE-ON DVDRW SOHW-1673S G: CDRom1
WIRTUAL CD/DVD-ROM H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 243MB (249184kB)
Memory in use : 52 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
3.6.2005
Kompilacja ISO
10:56:52 #1 Text 0 File Isodoc.cpp, Line 6194
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
10:56:52 #2 Text 0 File Reader.cpp, Line 127
Reader running
10:56:52 #3 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW SOHW-1673S running
10:56:52 #4 ISO9660GEN -11 File geniso.cpp, Line 3293
10:56:52 #5 Text 0 File Burncd.cpp, Line 3167
10:56:52 #6 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1430975 (317:59.50, 2794MB)
10:56:52 #7 Text 0 File DlgWaitCD.cpp, Line 272
10:56:52 #8 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: LITE-ON DVDRW SOHW-1673S, Media type: DVD+R
Disc Manufacturer ID: PRODISC, Media Type ID: R03, Product revision number: 3
Disc Application Code: 0, Extended Information Indicators: 3
10:56:52 #9 Text 0 File DlgWaitCD.cpp, Line 438
10:56:52 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1430976 (1430976) = #1430976/317:59.51
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1430976 blocks [LITE-ON DVDRW SOHW-1673S]
10:57:13 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [LITE-ON DVDRW SOHW-1673S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2930638848, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1430976 | lead-out | 1 | 0x41 | 0x00
10:57:13 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
10:57:14 #13 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
10:57:14 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
10:57:14 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 6x (8 310 KB/s)
10:57:14 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
10:57:14 #17 Text 0 File Cdrdrv.cpp, Line 8438
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: PRODISC.
Media type ID: R03
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 50 52 4F 44 49 - 53 43 00 52 30 33 03 38 ...PRODISC.R03.8
23 54 37 0F 02 54 6B 02 - 94 63 15 15 0B 0A 08 08 #T7..Tk..c......
01 1C 1E 0B 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
10:57:14 #18 Text 0 File DVDPlusRW.cpp, Line 652
Start write address at LBA 0
10:57:20 #19 SCSI -31 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0B150000
Status: 0xE6 (0x0E, SCSI_BUFFER_TO_BIG)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
10:57:20 #20 SCSI -31 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0B7E0600
Sense Code: 0x26
Sense Qual: 0x02
10:57:20 #21 Text 0 File Mmc.cpp, Line 19101
Writer-Buffer for LITE-ON DVDRW SOHW-1673S\H1 T0 reduced to 32768Bytes
10:57:20 #22 SCSI -31 File Cdrdrv.cpp, Line 1436
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00
10:57:20 #23 CDR -31 File Writer.cpp, Line 311
Buffer too large
10:57:20 #24 Text 0 File ThreadedTransfer.cpp, Line 228
10:57:20 #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
10:57:20 #26 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
10:57:20 #27 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
10:57:20 #28 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 6x (8 310 KB/s)
Existing drivers:
File 'Drivers\nvidesm.sys': Ver=5.10.2600.0284 built by: WinDDK, size=19712 bytes, created 2002-10-04 10:23:00 (Adapter driver for rec)
File 'Drivers\a347scsi.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 2004-04-30 09:33:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) [/COLOR] [/B] [B]
patryciusz jest offline
Stary 03.06.2005, 12:15   #2
ma być DMA: on
ed hunter jest offline
Stary 03.06.2005, 12:21   #3
nimal
Author
Avatar użytkownika nimal
Data rejestracji: 29.03.2003
gwoli wyjasnienia: to nie ustawinie nero tylko windowsa
panel sterowania/system/sprzet/menager uzadzen/kontrolery ide/...
klikaj po kolei i ustaw dma
jak sie nie da to usun kontrolery i restart
nimal jest offline
Stary 03.06.2005, 12:24   #4
Napisany przez nimal
kurczę, nie Dałeś człowiekowi szansy wypróbować szukaj
Stary 03.06.2005, 14:22   #5
nimal
Author
pierwszy post - taryfa ulgowa
nimal jest offline
Stary 04.06.2005, 13:14   #6
patryciusz
LAIK(onik)
Dzięki!
Panowie-bardzo dziękuje za pomoc....Metodą prób i błędów doszedłem do tego i wszystko jest ok...Jeszcze raz wielkie dzięki.Pozdrawiam
Wszystkie czasy w strefie CET. Aktualna godzina: 13:47.
