Stary 21.01.2010, 19:22   #1
Mario4all
Avatar użytkownika Mario4all
Data rejestracji: 22.09.2006
Mario4all w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z płytami Dl
Mianowicie jest tak, że jak nagram płytkę to u mnie nie widzi a u innych tak. Nagrałem na Verbatimie. Podaje log do sprawdzenia:
Kod:
Mario
1C82-0000-19E5-MAAX-4009-6719-****
Windows XP 6.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.7.5.1
Internal Version: 7, 7, 5, 1
 (Nero Express)
Recorder:             <TSSTcorp CDDVDW SH-S203P>Version: SB01 - HA 1 TA 0 - 7.7.5.1
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <YJM      K56VODQFWLI     >Version: 1.03 - HA 1 TA 2 - 7.7.5.1
=== Scsi-Device-Map ===
CdRomPeripheral      : YJM     K56VODQFWLI     1.03  art4xua8 Port 6 ID 0  DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CDDVDW SH-S203P   F:   CDRom0
YJM K56VODQFWLI            H:   CDRom2
AutoRun : 1
Excluded drive IDs:
BUFE           : 0
Physical memory     : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use       : 29 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
21.1.2010
Kopia DVD 'w locie'
17:57:43	#1 Text 0 File SCSIPTICommands.cpp, Line 411
17:57:43	#2 Text 0 File SCSIPTICommands.cpp, Line 411
17:57:43	#3 Text 0 File SCSIPTICommands.cpp, Line 209
17:57:44	#4 Text 0 File DVDCopy.cpp, Line 319
	DVD Track-Information from source disc:
	 Media Type: DVD-ROM
	 Last LBA on layer 0 =  2084959 / 0x1FD05F / 4072MB
	  S01 T01 Con 0x04 Start        0 Len  3668960 NWA       -1 (gap     0) Blank 0 Res 0 Dmg 0 Open Trk 0 Mode TRM_DATA_MODE1 (0)
17:57:44	#5 Text 0 File DVDCopy.cpp, Line 434
	Max -1 tracks of 1 allowed to copy
	 1:        0 -  3668960 =  3668960, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options)
17:57:44	#6 Text 0 File Burncd.cpp, Line 3465
17:57:44	#7 Text 0 File DlgWaitCD.cpp, Line 306
	Last possible write address on media:  4173823 (927:30.73, 8151MB)
	Last address to be written:            3668959 (815:19.34, 7165MB)
17:57:44	#8 Text 0 File DlgWaitCD.cpp, Line 318
17:57:44	#9 Text 0 File DlgWaitCD.cpp, Line 2912
	Recorder: TSSTcorp CDDVDW SH-S203P, Media type: DVD+R9 Double Layer
	 Disc Manufacturer ID: MKM, Media Type ID: 003, Product revision number: 0
	 Disc Application Code: 0, Extended Information Indicators: 3
17:57:44	#10 Text 0 File DlgWaitCD.cpp, Line 490
17:57:44	#11 Text 0 File ThreadedTransferInterface.cpp, Line 823
	 0: TRM_DATA_MODE1 (1 - Dane (tryb 1))
	    original disc pos #0 + 3668960 (3668960) = #3668960/815:19.35
	    not relocatable, disc pos for caching/writing not required/not required
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3668960 blocks [F: TSSTcorp CDDVDW SH-S203P]
17:57:44	#12 Text 0 File ThreadedTransferInterface.cpp, Line 1026
	Prepare [F: TSSTcorp CDDVDW SH-S203P] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x40; Session Closed, disc fixated
	 Tracks 1 to 1:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    7514030080, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	        0 |  lead-in |   0 |    0x41 |        0 |        0 | 0x00
	        0 |        1 |   0 |    0x41 |  3668960 |  3668960 | 0x00
	        0 |        1 |   1 |    0x41 |  3668960 |  3668960 | 0x00
	  3668960 | lead-out |   1 |    0x41 |        0 |        0 | 0x00
17:57:44	#13 Text 0 File SCSIPTICommands.cpp, Line 209
17:57:44	#14 Phase 36 File dlgbrnst.cpp, Line 1760
	Burn process started at 8x (11*080 KB/s)
17:57:46	#15 Text 0 File ThreadedTransferInterface.cpp, Line 2764
	Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
17:58:27	#16 SPTI -1066 File SCSIPassThrough.cpp, Line 179
	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
	Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
	Sense Code: 0x24
	Sense Qual: 0x00
	CDB Data:   0xAD 00 00 00 00 00 00 21 08 04 00 00
	Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
	Buffer x04b3f5c0: Len x804
17:58:27	#17 Text 0 File DVDPlusDualLayer.cpp, Line 640
	L0 Data Zone Capacity set to 2084960 (1FD060h, 4072MB) -> OK, confirmed setting
17:58:27	#18 CDR -1205 File DVDPlusDualLayer.cpp, Line 667
	Burning Layer 1
17:58:27	#19 Text 0 File DVDPlusDualLayer.cpp, Line 677
	Start writing layer 1 at address 0 (0h)
	Recording mode: unknown Recording Mode
17:58:27	#20 Text 0 File Cdrdrv.cpp, Line 9288
	---- DVD Structure: Physical Format Information (00h) ----
	Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD+R DL (14), Part Version: 1.0x (1)
	 Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
	 Number of Layers: 2,    Track Path: Opposite Track Path (OTP),  Layer Type: recordable
	 Linear Density:         0,293 um/bit,  Track Density:  0,74 um/track
	 End Physical Sector Number of Data Area:      FCFFFF h
	 End Sector Number in Layer 0:                 22D7FF h (LBN: 1FD7FF h, 4075 MB)
	  Disc Application Code: 0 / 0 h
	  Extended Information indicators: 3 h
	  Disc Manufacturer ID: MKM.....
	  Media type ID: 003
	  Number of Physical format information bytes in use in ADIP up to byte 63: 64
	 Media Specific [16..63]:
	    00 00 03 4D 4B 4D 00 00 - 00 00 00 30 30 33 00 40    ...MKM.....003.@
	    25 25 37 0C 02 2D 66 02 - 2D 66 21 23 0D 0E 14 14    %%7..-f.-f!#....
	    02 01 01 10 00 21 23 0D - 0E 14 14 02 01 01 10 00    .....!#.........
17:58:27	#21 Text 0 File Cdrdrv.cpp, Line 9288
	  Media type ID: 003
17:58:27	#22 Text 0 File Cdrdrv.cpp, Line 9288
	  Media type ID: 003
17:58:27	#23 Text 0 File DVDR.cpp, Line 8107
	Drive: TSSTcorp CDDVDW SH-S203P
	Book Type request [TSST]: DVD-ROM
	Changing the Book Type was finished successfully, return code 0
17:58:27	#24 CDR -1211 File DVDR.cpp, Line 6195
	Book Type set to: DVD-ROM
17:58:27	#25 Text 0 File DVDPlusRW.cpp, Line 674
	Start write address at LBA 0
18:05:26	#26 CDR -1206 File DVDPlusDualLayer.cpp, Line 1950
	Burning Layer 2
18:05:26	#27 Text 0 File DVDPlusDualLayer.cpp, Line 1961
	Perform layer 1 to 2 jump before writing at address 2084960 (1FD060h)
18:10:52	#28 Text 0 File WriterStatus.cpp, Line 113
	<F: TSSTcorp CDDVDW SH-S203P> start writing Lead-Out at LBA 3668960 (37FBE0h), length 0 blocks
18:13:37	#29 Phase 37 File dlgbrnst.cpp, Line 1760
	Burn process completed successfully at 8x (11*080 KB/s)
18:13:38	#30 Text 0 File SCSIPTICommands.cpp, Line 254
18:13:38	#31 Text 0 File SCSIPTICommands.cpp, Line 411
18:13:38	#32 Text 0 File Cdrdrv.cpp, Line 10529
18:13:38	#33 Text 0 File SCSIPTICommands.cpp, Line 254
18:13:42	#34 Text 0 File Cdrdrv.cpp, Line 10529
18:13:42	#35 Text 0 File SCSIPTICommands.cpp, Line 411
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs :  (Security Option)
Obstawiam, że wina lasera. Czy czyszczenie pomoże? No bo gwarancji już niestety nie ma...
Mario4all jest offline   Odpowiedz cytując ten post
Stary 21.01.2010, 23:03   #2
Mario4all
Zrobiłem test na lapku w Nero. Oto rezultat http://img20.yfrog.com/i/testfwq.jpg/
Testu nawet nie zrobiło do końca bo wywaliło gdzieś tak bodaj w połowie no seek error. Heh to chyba wszystko jest jasne ;P
Stary 22.01.2010, 00:28   #3
Bródka
Technik Informatyk
Avatar użytkownika Bródka
Data rejestracji: 22.01.2005
Wywalilo w polowie bo Philips nie jest w stanie zrobic testu jakosci na drugiej warstwie o ile w ogole testy robione tym laptopowym philipsem sa wiarygodne albo nagrywarka na ktorej nagrywales te plyty konczy zywota albo te plyty to podróba lub testy jakosci sa bardzo przeklamane
A no i nie testuje sie plyt przy maksymalnej predkosci
Optiarc AD-7703S v1.03
Mój Mondek - PolskaJazda.pl
Stary 03.02.2010, 23:36   #4
Mario4all
Chwilowo nie mam na czym stestować. Mam zamiar kupić Liteona to wtedy bym wiedział na czym stoję. No ale tak jak mówie... problem dotyczy głównie płyt verbatim czy inna. Może za szybko nagrywam ? 8x wypalałem. No ale u innych da radę odczytać ;/
Stary 04.02.2010, 23:44   #5
Bródka
Technik Informatyk
Litek tez nie potrafi testowac na drugiej warstwie, do tego potrzebujesz jakiegos prawdziwego plextora ktorego w sumie nie kupisz nowego lub benq i tego takze nie kupisz nowego
Memorex DVD+R DL 8x - problem z zapisem. d-t-x Nośniki optyczne 9 04.03.2008 11:56
Problem z BENQ DW 1655 i DL d4knez Napędy optyczne DVD 5 18.01.2008 00:17
Problem z wypaleniem plyty DL. Pioneer 111D framling Napędy optyczne DVD 1 27.12.2007 22:35
BENQ DVD DD DW1640 problem z nagrywaniem płyt DVD DL !! Indianin23 Napędy optyczne DVD 5 17.12.2007 21:44
Problem - nagrywanie DVD DL dreak Napędy optyczne DVD 7 30.07.2007 23:48
Wszystkie czasy w strefie CET. Aktualna godzina: 04:30.
