Stary 04.03.2007, 15:00   #1
mlodywilq
Data rejestracji: 04.03.2007
mlodywilq w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
problem przy nagrywaniu plyt dvd
Witam! nagle pojawil mi sie problem przy nagrywaniu plyt wczesniej bylo wszystko ok normlanie nagrywalem na verbatimach a tu nagle blad ponizej wklejam log z nero. Prosze o pomoc
NEMO
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 20:18:06
Wersja Nero: 6.3.1.17 (Nero Express)
Nagrywarka: <HL-DT-ST DVDRAM GSA-4167B>Wersja: DL13 - HA 1 TA 2 - 6.3.1.17
Sterownik adaptera: <nvatabus> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 11
Drive is autodetected - recorder class: DVD+R9 DL recorder
CD-ROM: <JK3111Q HOQ162J >Wersja: 1.0 - HA 5 TA 0 - 6.3.1.17
Sterownik adaptera: <a1raar9w> HA 5
=== Scsi-Device-Map ===
DiskPeripheral : MDT MD1200JB-00DUA3 nvatabus Port 1 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4167B nvatabus Port 1 ID 2 DMA: Off
CdRomPeripheral : JK3111Q HOQ162J 1.0 a1raar9w Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4167 E: CDRom0
JK3111Q HOQ162J H: CDRom1
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 628MB (643324kB)
Memory in use : 38 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
4.3.2007
Nagraj obraz DVD
13:49:38 #1 Text 0 File Reader.cpp, Line 118
Reader running
13:49:38 #2 Text 0 File Writer.cpp, Line 124
Writer HL-DT-ST DVDRAM GSA-4167B running
13:49:38 #3 Text 0 File Burncd.cpp, Line 3172
13:49:39 #4 Text 0 File DlgWaitCD.cpp, Line 245
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2254901 (501:05.26, 4404MB)
13:49:39 #5 Text 0 File DlgWaitCD.cpp, Line 257
13:49:39 #6 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: HL-DT-ST DVDRAM GSA-4167B, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
13:49:39 #7 Text 0 File DlgWaitCD.cpp, Line 418
13:49:39 #8 Text 0 File ThreadedTransferInterface.cpp, Line 813
0: TRM_DATA_MODE1 (2 - CD-ROM Tryb 1, ISO 9660)
original disc pos #0 + 2254902 (2254902) = #2254902/501:5.27
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2254902 blocks [HL-DT-ST DVDRAM GSA-4167B]
13:49:39 #9 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [HL-DT-ST DVDRAM GSA-4167B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4618039296, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2254902 | lead-out | 1 | 0x00 | 0x41
13:49:39 #10 Phase 24 File dlgbrnst.cpp, Line 1845
Rozpocz***281;to buforowanie plik***243;w
13:49:39 #11 Text 0 File Burncd.cpp, Line 4182
Cache writing successful.
13:49:39 #12 Phase 25 File dlgbrnst.cpp, Line 1845
Zako***324;czono buforowanie plik***243;w
13:49:39 #13 Phase 36 File dlgbrnst.cpp, Line 1845
Rozpocz***281;to zapis z pr***281;dko***347;ci***261; 16x (22*160 KB/s)
13:49:39 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
13:49:39 #15 Text 0 File Cdrdrv.cpp, Line 8120
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
13:49:39 #16 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 3:35,350 (215350ms) -> OK
13:49:39 #17 Text 0 File DVDPlusRW.cpp, Line 613
Start write address at LBA 0
13:50:06 #18 SCSI -1135 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x0B9C3000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x35 0x2D 0x03 0x0E 0x0C 0x00
13:50:06 #19 SCSI -1064 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x0B550000
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x10
0x2A 0x00 0x00 0x0E 0x21 0x02
13:50:06 #20 CDR -1135 File Writer.cpp, Line 304
B***322;***261;d zapisu!
HL-DT-ST DVDRAM GSA-4167B\H1 T2
13:50:06 #21 Text 0 File ThreadedTransfer.cpp, Line 229
13:50:06 #22 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
13:50:19 #23 Phase 127 File dlgbrnst.cpp, Line 1845
Generowanie granic wysokiej zgodno***347;ci DVD
13:50:20 #24 SCSI -1135 File Cdrdrv.cpp, Line 1188
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
13:50:20 #25 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
13:50:20 #26 Phase 129 File dlgbrnst.cpp, Line 1845
Generowanie granic wysokiej zgodno***347;ci DVD zako***324;czy***322;o si***281; powodzeniem!
13:50:20 #27 Text 0 File dlgbrnst.cpp, Line 1703
13:50:20 #28 Phase 38 File dlgbrnst.cpp, Line 1845
Zapis z pr***281;dko***347;ci***261; 16x (22*160 KB/s) nie powi***243;d***322; si***281;!
Existing drivers:
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0534 built by: WinDDK, size=92800 bytes, created 2005-05-17 10:45:08 (Adapter driver for rec)
Registry Keys:
0
mlodywilq jest offline   Odpowiedz cytując ten post
Stary 04.03.2007, 15:08   #2
Prezesik
Człekokształtny
Avatar użytkownika Prezesik
Data rejestracji: 27.12.2004
zacznij od w***322;***261;czenia DMA
http://forum.cdrinfo.pl/showthread.php?t=57073
Seny, pit i collons!
Stary 04.03.2007, 15:24   #3
mlodywilq
to jak to mozliwe ze wczesniej plyty nagrywalem i wszystko ok a teraz nie dziala;] z tego co widze to mam chyba wlaczone dma
Stary 04.03.2007, 15:31   #4
Nero InfoTool> Configuration poprosz***281;, bo przy sterownikach nVidii to menad***380;erowi nie wierz***281;. w logu z Nero by***322;o off. a dla czego nagle ***378;le? zobaczymy. mi si***281; te***380; ostatnio DMA wy***322;***261;czy***322;o na wszystkim nie wiem czemu...tajemnice Windowsa
Stary 04.03.2007, 15:40   #5
mlodywilq
probowalem nagrac plyte w alcoholu dvd descrypter i w nero.wczesniej wszystko ok a tera nagle bledy. z gory dziekuje za zainteresowanie i poswiecenie czasu
Stary 04.03.2007, 15:44   #6
Prezesik
Człekokształtny
odinstaluj sterowniki nVidii i zrestartuj komputer
Stary 04.03.2007, 15:45   #7
no tak. przy tych sterach to ju***380; nic nie wida***263;...ja bym je usun***261;***322; i nagrywa***322; na systemowych - takie moje zdanie
Stary 04.03.2007, 18:22   #8
mlodywilq
odinstalowalem sterowniki nforce ale windows xp nachalnie zmusza mnie do ich odzyskania ;]te windowsa nie pasuja ;] przypuszczam ze to nei chodzi o dma bo wczesniej nagrywalo normalnie . przejrzalem posty na temat tej nagrywarki i sa problemy ze po 3% nagrywania staje i wyskakuje ten blad. na poczatku myslalem ze to wina obrazu ktory nagrywalem na plyte ale to widocznie wina napedu dvd. Moze oddac na gwarancje?
Stary 04.03.2007, 23:51   #9
Popielaty
Avatar użytkownika Popielaty
Data rejestracji: 24.01.2004
Jeżeli masz możliwość to sprawdź napęd na innym komputerze.
Popielaty jest offline   Odpowiedz cytując ten post
Stary 14.03.2007, 19:40   #10
mlodywilq
Witam! oddalem naped Dvd na gwarancje i przyslali mi dzisiaj inny naped orientuje sie ktos moze czy ten nowy czyli LG GSA-H42N jest lepszy od mojego poprzedniego GSA-4167B?
Wszystkie czasy w strefie CET. Aktualna godzina: 09:23.
