Data rejestracji: 18.08.2005
Problem Samsung SHW08A
Mam problem z wypaleniem obrazu, przed formatem były małe problemy z nagrywarką, ale wypalało się dobrze. Używałem płytek tdk, sony, verbatim dvd-r, czasami obraz się wypali jednak najcześciej log wygląda tak
Kod:
########################### System Information ###########################
Windows XP Professional 5.1 Dodatek Service Pack 2 (Build 2600)
Processor info: AMD Athlon(tm) XP 2500+ (1837MHz)
Memory Available to Windows: 523*760 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\_Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: Alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2008 Alcohol Soft Development Team
Version: 1.9.7 ( Build 6221 )
Date: 2008/02/22
Hash: ee833b4b446b7fa2e05541d4090f3c33
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Company Name: Alcohol Soft Co., Ltd.
Description: Alcohol virtual device control library
Original: alcoholx.dll
Product: Alcohol
Copyright: Copyright (C) 2000-2008
Version: 4.12.0 ( Build 0 )
Date: 2008/01/18
Hash: f1274ca402d9296cd31eacc34a88bbea
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2006 Alcohol Soft Development Team
Version: 2.5.4 ( Build 222 )
Date: 2008/02/22
Hash: 4b22ef831539d9f5b6923d3d286141e7
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 204
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: No
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: Polish
############################ Device(s) List ############################
(D:) SAMSUNG DVD R/RW SH-W08A (atapi, Port 0, Bus 0, Target 1, Lun 0)
(E:) TEAC CD-540E (atapi, Port 1, Bus 0, Target 0, Lun 0)
(F:) TU7383P VUU050X (apj9gwnp, Port 2, Bus 0, Target 0, Lun 0)
(G:) TU7383P VUU050X (apj9gwnp, Port 2, Bus 0, Target 1, Lun 0)
##################### Installed Device Drivers List #####################
ACPI.sys afd.sys ALCXWDM.SYS amdk7.sys apj9gwnp.SYS
Aspi32.SYS atapi.sys audstub.sys azv2anym.SYS Beep.SYS
BOOTVID.dll Cdfs.SYS cdrom.sys CLASSPNP.SYS CO_Mon.sys
disk.sys dmio.sys dmload.sys drmk.sys dump_atapi.sys
dump_WMILIB.SYS Dxapi.sys dxg.sys dxgthk.sys eeCtrl.sys
EraserUtilRebootDrv.sys fdc.sys fetnd5.sys Fips.SYS fltMgr.sys
Fs_Rec.SYS ftdisk.sys hal.dll HTTP.sys i8042prt.sys
imapi.sys ipnat.sys ipsec.sys isapnp.sys kbdclass.sys
KDCOM.DLL kmixer.sys ks.sys KSecDD.sys mnmdd.SYS
mouclass.sys MountMgr.sys mrxdav.sys mrxsmb.sys Msfs.SYS
msgpc.sys mssmbios.sys Mup.sys NAVENG.SYS NAVEX15.SYS
NDIS.sys ndistapi.sys ndisuio.sys ndiswan.sys NDProxy.SYS
netbios.sys netbt.sys Npfs.SYS ntdll.dll Ntfs.sys
ntoskrnl.exe Null.SYS nv4_disp.dll nv4_mini.sys parport.sys
PartMgr.sys ParVdm.SYS pci.sys PCIIDEX.SYS portcls.sys
psched.sys ptilink.sys rasacd.sys rasl2tp.sys raspppoe.sys
raspptp.sys raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys
redbook.sys SCSIPORT.SYS serenum.sys serial.sys SPBBCDrv.sys
spcq.sys sr.sys SRTSP.SYS SRTSPX.SYS srv.sys
swenum.sys SYMDNS.SYS SYMEVENT.SYS SYMFW.SYS SYMIDS.SYS
SymIDSCo.sys SymIM.sys SYMNDIS.SYS SYMREDRV.SYS SYMTDI.SYS
sysaudio.sys tcpip.sys TDI.SYS termdd.sys uagp35.sys
update.sys USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS
usbprint.sys usbuhci.sys vga.sys viaide.sys VIDEOPRT.SYS
VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys win32k.sys
WMILIB.SYS WudfPf.sys
################## Detailed Information of Device(s) ##################
(D:) SAMSUNG DVD R/RW SH-W08A(0:1) detail information.
Vendor Identification: SAMSUNG
Product Identification: DVD R/RW SH-W08A
Production Revision Level: 1S31
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: Yes
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
(E:) TEAC CD-540E(1:0) detail information.
Vendor Identification: TEAC
Product Identification: CD-540E
Production Revision Level: 1.0A
Response Data Format: 01h
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Test Write: No
DVD-ROM Read: No
DVD-R Read/Write: No/No
DVD-RAM Read/Write: No/No
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
(F:) TU7383P VUU050X(2:0) detail information.
Vendor Identification: TU7383P
Product Identification: VUU050X
Production Revision Level: 1.01
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
Audio Play: Yes
Composite Audio and Video Data Stream: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
P through W in Lead-In: No
(G:) TU7383P VUU050X(2:1) detail information.
Test Write: No
DVD-ROM Read: Yes
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
###################### Source Disc/Image Information ######################
Typ: Plik obrazu Standard ISO
Ścieżka: C:\Downloads\Tony Hawk's American Wasteland [PS2] [NTSC]\
Nazwa: THAW.iso
Rozmiar: 3836.00 MB
Ilość sesji: 1
Ilość ścieżek: 1
Sesja 01:
Ścieżka 01: DVD, Rozmiar: 1964032(3.75 GB), Adres: 000000
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 2008-04-26 23:51:49 *********
23:51:49 Procesor: AMD Athlon(tm) XP 2500+ (1837MHz)
23:51:49 Pamięć dostępna dla systemu: 523*760 KB
23:51:49 Za mało pamięci! Ustaw rozmiar bufora pamięci na 204 MB.
23:51:50 Ładowanie obrazu płyty: C:\Downloads\Tony Hawk's American Wasteland [PS2] [NTSC]\THAW.iso
23:51:50 DVD Informacje o źródle: Sesja: 1, Ścieżka: 1, Rozmiar: 3.75 GB / 1964032
23:51:57 (D:) SAMSUNG DVD R/RW SH-W08A(0:1): Tryb zapisu/Prędkość
23:51:57 Zapis - DAO - 4.0X (5540 KB/s)
(D:) SAMSUNG DVD R/RW SH-W08A(0:1) - Media format: DVD-R
23:54:15 (D:) SAMSUNG DVD R/RW SH-W08A(0:1) - [Write ERROR] LBA: 356320, Length: 32
S:KEY - 03/0C/00 - "Write Error"
23:54:15 (D:) SAMSUNG DVD R/RW SH-W08A(0:1): Zapis nie powiódł się!
23:54:15 Błąd: [03/0C/00] - Write Error
23:54:15 Ładowanie obrazu płyty przerwane!
23:54:17 Błąd w procedurze zapisu! Sprawdź plik z logiem i wyślij informacje o błędach do Pomocy Technicznej.
#2 | |
Technik Informatyk
Data rejestracji: 22.01.2005
Ciekaw jestem czy ty czytales ten log bo chyba nie
W***322;a***347;nie chodzi o to, ***380;e jak***261; warto***347;***263; bym nie ustwi***322; to mi pojawia si***281;, ***380;e bufor za ma***322;y. Dam 256 pojawia si***281; "bufor za ma***322;y ustaw na 256" (czasami pojawia si***281; tez "ustaw na 147"). Zmarnowa***322;em ju***380; kilka p***322;ytek nie wiem czemu tak jest, ale przed formatem nigdy takiego b***322;***281;du nie by***322;o. Zawsze pojawia si***281; on 18,1***37;
Ostatnio zmieniany przez Mufas : 27.04.2008 o godz. 18:06 |
Technik Informatyk
to wypal ten obraz w programie imgburn
Mo***380;e alcohol ***378;le kupiony?
![]() ![]() Spr***243;buj IMGburn. ![]() Edit: ta szybko***347;***263; mojego modemu... :\
No na imgburn posz***322;o i pytanie czy u***380;ywa***263; domy***347;lnych ustawie***324; czy zmieni***263; (domy***347;lnie bufor 20mb)?
A co do alcoholu to uzywa***322;em triala czyli chyba nie by***322; "***378;le kupiony" |
| Samsung DVD P370 (Problem) | czyzyk1990 | Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) | 1 | 16.03.2008 22:40 |
| problem z odtwarzaczem dvd hd-860 samsung | ziombol | Domowy sprzęt Audio/Video (nagrywarki, odtwarzacze DVD, Blu-ray, odtwarzacze sieciowe, TV) | 9 | 19.09.2007 22:51 |
| Problem z nagrywarka samsung | latron | Napędy optyczne DVD | 1 | 15.12.2005 20:52 |
| samsung sw-212B problem z firmware - prosze o pomoc | piostem | Napędy optyczne CD | 0 | 03.04.2003 13:39 |
| Problem z Samsung SW-212B | Kropel | Napędy optyczne CD | 1 | 18.03.2002 23:46 |
