Data rejestracji: 17.06.2004
Problem z nagrywaniem i wymazywaniem płyt DVD+RW - "Buffer too large"
witam
To jest tak: niezależnie od programu (DVD Shrink, ImgBurnTool) nie udaje mi się wymazać sesji - mimo, że pojawia się komunikat "Disc Sucessfully Erased!" - a cała operacja tego "fikcyjnego" kasowania trwa 2-3 sekundy. Próby dokonania tego pod NERO owocują komunikatem "Bufor zbyt duży HL-DT-ST DVDRAM GSA-4163B\H1 T0". log z próby zapisu w ImgBurnTool jest taki: ============================================ Log date: Sun Apr 03 10:05:12 2005 ============================================ Project: NO_NAME ============================================ Using ImgTool Version 1.1.9 Can't open INI file (C:\Program Files\ImgTool Burn\ImgTool.ini), using default settings... Opening NeroAPI.DLL Nero API version 6.6.0.8 Initialization of the NeroAPI successful. Found the following devices: HL-DT-ST DVDRAM GSA-4163B Image Recorder ========================================= Starting Burn Process... ========================================= Using Device "HL-DT-ST DVDRAM GSA-4163B" Using ISO Flags: ISO UDF Realloc ============================== try to building DVD ISO Tree... ============================== Start path: "C:\M" AUDIO_TS dir present... VIDEO_TS dir present... Adding files in directory "C:\M\AUDIO_TS"... ============================== building VIDEO_TS Tree... ============================== Adding VIDEO_TS.IFO File: "VIDEO_TS.VOB" doesn't exist ==> create ISO without it! Adding VIDEO_TS.BUP Adding VTS_01_0.IFO Adding VTS_01_1.VOB Adding VTS_01_2.VOB Adding VTS_01_3.VOB Adding VTS_01_4.VOB Adding VTS_01_5.VOB Adding VTS_01_0.BUP Adding files in directory "C:\M"... Writing on DVD Media... Using Speed: 2.4x (3324kB/s) ===> DVD-Video files reallocation started ===> DVD-Video files reallocation completed (no file modified) ===> DVD-Video files sorted => Reading directories => Creating directories => Finishing => Reading directories => Creating directories => Checking discs => Writing to cache ===> Caching of files started ===> Caching of files completed => Writing to disc ===> Burn process started at 2.4x (3á324 KB/s) => Writing lead-in ===> Buffer too large HL-DT-ST DVDRAM GSA-4163B\H1 T0 ===> Burn process failed at 2.4x (3á324 KB/s) 1A25-0006-7130-1352-4239-7903 Windows XP 5.2 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 17:35:34 Nero API version: 6.6.0.8 Using interface version: 5.5.10.15 Installed in: C:\Program Files\Ahead\Nero\ Application: ahead\Nero - Burning Rom Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A102 - HA 1 TA 0 - 6.6.0.8 Adapter driver: <viadsk> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI === Scsi-Device-Map === DiskPeripheral : WDC WD800JB-00JJA0 05.0 viadsk Port 0 ID 0 DMA: Off DiskPeripheral : ST380021A 3.51 viadsk Port 0 ID 1 DMA: Off CdRomPeripheral : HL-DT-STDVDRAM GSA-4163BA102 viadsk Port 1 ID 0 DMA: Off CdRomPeripheral : TEAC CD-W58E 1.0A viadsk Port 1 ID 1 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GSA-4163 V: CDRom0 TEAC CD-W58E F: CDRom1 ======================= AutoRun : 0 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523764kB) Free physical memory: 158MB (162732kB) Memory in use : 68 Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 3.4.2005 NeroAPI 10:05:00 #1 Phase 112 File APIProgress.cpp, Line 276 DVD-Video files reallocation started 10:05:00 #2 Phase 114 File APIProgress.cpp, Line 276 DVD-Video files reallocation completed (no file modified) 10:05:00 #3 Phase 111 File APIProgress.cpp, Line 276 DVD-Video files sorted 10:05:00 #4 Text 0 File Reader.cpp, Line 127 Reader running 10:05:00 #5 Text 0 File Writer.cpp, Line 122 Writer HL-DT-ST DVDRAM GSA-4163B running 10:05:00 #6 Text 0 File AudioCompilationImpl.cpp, Line 842 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 10:05:00 #7 ISO9660GEN -11 File geniso.cpp, Line 3293 First writeable address = 0 (0x00000000) 10:05:00 #8 ISO9660GEN -11 File geniso.cpp, Line 3293 First writeable address = 0 (0x00000000) 10:05:00 #9 Text 0 File Burncd.cpp, Line 3153 Turn on Disc-At-Once, using DVD media 10:05:01 #10 Text 0 File DlgWaitCD.cpp, Line 259 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2286111 (508:01.36, 4465MB) 10:05:01 #11 Text 0 File DlgWaitCD.cpp, Line 271 Write in overburning mode: NO 10:05:01 #12 Text 0 File DlgWaitCD.cpp, Line 2316 Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+RW Disc Manufacturer ID: MCC, Media Type ID: A01, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 0 10:05:01 #13 Text 0 File DlgWaitCD.cpp, Line 433 >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:05:01 #14 Text 0 File ThreadedTransferInterface.cpp, Line 830 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [HL-DT-ST DVDRAM GSA-4163B] -------------------------------------------------------------- 10:05:01 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043 Prepare recorder [HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2286112 | lead-out | 1 | 0x41 | 0x00 10:05:01 #16 Phase 24 File APIProgress.cpp, Line 276 Caching of files started 10:05:01 #17 Text 0 File Burncd.cpp, Line 4040 Cache writing successful. 10:05:01 #18 Phase 25 File APIProgress.cpp, Line 276 Caching of files completed 10:05:01 #19 Phase 36 File APIProgress.cpp, Line 276 Burn process started at 2.4x (3á324 KB/s) 10:05:01 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 10:05:01 #21 Text 0 File Cdrdrv.cpp, Line 8430 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+RW (9), Part Version: 2 Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 0 h Disc Manufacturer ID: MCC..... Media type ID: A01 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 57 Media Specific [16..63]: 00 00 00 4D 43 43 00 00 - 00 00 00 41 30 31 00 39 ...MCC.....A01.9 23 02 84 78 68 02 1D 02 - 92 78 68 02 1B 02 8A 78 #..xh....xh....x 68 02 1C 22 13 00 E0 10 - 00 00 00 00 00 00 00 00 h.."............ 10:05:01 #22 Text 0 File DVDR.cpp, Line 4842 Drive: HL-DT-ST DVDRAM GSA-4163B Book Type request [LG]: DVD-ROM Book Type setting not supported for the loaded disc type 10:05:01 #23 Text 0 File DVDPlusRW.cpp, Line 638 Start write address at LBA 0 DVD high compatibility mode: Yes 10:05:04 #24 SCSI -31 File Cdrdrv.cpp, Line 1435 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x024D0000 Status: 0xE6 (0x0E, SCSI_BUFFER_TO_BIG) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 10:05:04 #25 SCSI -31 File Cdrdrv.cpp, Line 1435 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02E60200 Status: 0xE6 (0x0E, SCSI_BUFFER_TO_BIG) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 10:05:04 #26 Text 0 File Mmc.cpp, Line 18866 Writer-Buffer for HL-DT-ST DVDRAM GSA-4163B\H1 T0 reduced to 32768Bytes 10:05:04 #27 SCSI -31 File Cdrdrv.cpp, Line 1435 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02E60200 Status: 0xE6 (0x0E, SCSI_BUFFER_TO_BIG) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 10:05:04 #28 CDR -31 File Writer.cpp, Line 311 Buffer too large HL-DT-ST DVDRAM GSA-4163B\H1 T0 10:05:04 #29 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:05:04 #30 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 10:05:04 #31 Phase 38 File APIProgress.cpp, Line 276 Burn process failed at 2.4x (3á324 KB/s) 10:05:04 #32 Text 0 File AudioCompilationImpl.cpp, Line 867 DRM: DRM burn session terminated. 10:05:04 #33 Text 0 File AudioCompilationImpl.cpp, Line 896 DRM: Closing entire DRM handling. Bye. Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 2004-12-20 20:37:14 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Error: Burn failed. Logfile saved at: Sun Apr 03 10:05:12 2005 ^~^~^~^~^~^~^~^~^~^~^~^~^~^~^~^~^~^~^~^~^ Nagrywarka to ofkors LG GSA-4163B, system to ws2k3 a nośnik to Verbatim 2.4x (do tej pory bezproblemowo kasowany w innej wypalarce). Proszę o podpowiedź - co jest grane? Piotrek Ostatnio zmieniany przez Kalosz : 03.04.2005 o godz. 10:09 Powód: korekta opisu + log |
Data rejestracji: 14.04.2005
Mam to samo. Napisz, jak "Menedżer urządzeń" widzi twoje napędy optyczne? Czy jest tam sygnatura SCSI??
Jaki sprzęt masz? Płyta etc. |
#3 | |
inne RW kasuje? ja standardowo w takich przypadkach używam Alkohola i ustawienie ignoruj błędy TOC zawsze kasuj a inna sprawa, że temat wykopalisko i pewnie dawno po problemie. |
Kalosz, mam chyba i też dla ciebie radę.
Zajrzyj na: http://forum.cdrinfo.pl/showthread.p...t+du%BFy+bufor - po długich poszukiwaniach znalazłem :-) Tam jeden z kolegów napisał co zrobić. Ja u siebie też odinstalowałem sterowniki od IDE, po restarcie odinstalowałem również ASPI (poprzez pliki z pakietu FORCEASPI1.8) i zainstalowałem najnowsze ADAPTECa i teraz chodzi jak burza. |
