Data rejestracji: 23.05.2009
Problem z wypaleniem gry na Xbox 360...
Witam.
Mam wypalarke LG GSA-5160D na interfejs ATA. Problem polega na tym, ze nie moge na niej wypalic gry na Xboxa 360 (oczywiscie posiadam oryginal). Wypalam programem ImgBurn i podczas wypalania wyskakuje blad i plyta caly czas nadaje sie do uzytku. Log: I 16:43:04 ImgBurn Version 2.4.4.0 started! I 16:43:04 Microsoft Windows XP Professional (5.1, Build 2600) I 16:43:04 Total Physical Memory: 523*760 KB - Available: 344*288 KB I 16:43:04 Initialising SPTI... I 16:43:04 Searching for SCSI / ATAPI devices... I 16:43:04 Found 1 DVD-ROM and 1 DVD***177;RW/RAM! I 16:46:21 Operation Started! I 16:46:21 Source File: C:\Downloads\Pro_Evolution_Soccer_2009_PAL_XBOX360-STRANGE\strange-pes2009.dvd I 16:46:21 Source File Sectors: 3*825*924 (MODE1/2048) I 16:46:21 Source File Size: 7*835*492*352 bytes I 16:46:21 Source File Volume Identifier: XGD2DVD_NTSC I 16:46:21 Source File Volume Set Identifier: 34672923 I 16:46:21 Source File Implementation Identifier: Sonic Scenarist 3.1 I 16:46:21 Source File File System(s): ISO9660; UDF (1.02) I 16:46:21 Destination Device: [0:1:0] HL-DT-ST DVDRAM GSA-5160D A302 (F (ATA)I 16:46:21 Destination Media Type: DVD+R DL (Disc ID: CMC MAG-D04-00) (Speeds: 4x) I 16:46:21 Destination Media Sectors: 4*173*824 I 16:46:21 Write Mode: DVD I 16:46:21 Write Type: DAO I 16:46:21 Write Speed: 2,4x I 16:46:21 Link Size: Auto I 16:46:21 Lock Volume: Yes I 16:46:21 Test Mode: No I 16:46:21 OPC: No I 16:46:21 BURN-Proof: Enabled I 16:46:22 Book Type Setting: DVD-ROM I 16:46:22 Optimal L0 Data Zone Capacity: 1*913*760 I 16:46:22 Optimal L0 Data Zone Method: Copied From Original Disc E 16:48:21 Set L0 Data Zone Capacity Failed! - Reason: Write Error E 16:48:21 Operation Failed! - Duration: 00:01:59 I 16:48:21 Average Write Rate: N/A - Maximum Write Rate: N/A I 16:56:13 Close Request Acknowledged I 16:56:13 Closing Down... I 16:56:13 Shutting down SPTI... I 16:56:13 ImgBurn closed! Poprawnie powinno byc: ... Optimal L0 Data Zone Capacity: 1*913*760 Optimal L0 Data Zone Method: Copied From Original Disc Set L0 Data Zone Capacity Succeeded! Czy wiecie moze w czym tkwi problem? Nosnik - Platinum. Z gory dzieki za odpowiedzi. Pozdrawiam. |
| #ads | |
#2 | |
To nie nośnik, tylko podstawka pod
Nie wydaje mi sie, poniewaz duzo osob wypala na tych plytach i wszystko jest ok. Macie jeszcze jakies inne pomysly?
Technik Informatyk
Data rejestracji: 22.01.2005
Nastepny niedowiarek, to ze duzo na tych plytach wypalasz nie znaczy ze one sa dobre, kup porządne plyty Verbatima lub Sony i nagraj
No dobra, obadam sprawe na nosnikach Verbatim, chociaz i tak sie nie wypali. Ja stawiam na stara wypalarke, ktorej na interfejs ATA nigdy nie widzialem (nawet w necie nie ma). Tylko na USB.
Spokoooooooojnie...
Skoro kolega wie lepiej, to niech kombinuje...
Prywatne wiadomości lub przez komunikatory będą ignorowane. ![]() Ostatnio zmieniany przez czary2mary : 10.03.2015 o godz. 17:54 |
Ja tylko prosze o pomoc. A jezeli nie chcecie pomagac to przynajmniej nie nabijajcie postow. Moze ktos inny mial podobny problem i odpowie. W ogole pierwszy raz stykam sie z takim problemem. Jak juz wyskakuje blad (u innych) to w polowie wypalania, a nie przed wypalaniem (jak program probuje odczytac to "Optimal L0 Data Zone Capacity"). I dlatego nie wiem czego to jest wina.
Bardzo przepraszam, jestem zażenowany i czuję się podle, bo nabiłem posta i zostałem zbesztany.
![]() Jakkolwiek imgburn jest bardzo dobrym programem do nagrywania, to jego log daje niezbyt dużo przydatnych informacji w porównaniu z nero (heh, ciekawe, jeden dobrze nagrywa, drugi daje szczegółowe logi ). Tu, na forum, najczęstsze problemy powodują shitowe nośniki, potem shitowe nagrywarki, a następnie userzy, którzy nie bardzo wiedzą czego chcą (broń boże nie bierz tego do siebie). ![]() Dobry program już masz, więc kolejnym etapem pomocnym w dojściu do przyczyny problemu jest kwestia nośników - dlatego też dostałeś takie, a nie inne, rady.
W takim razie kupie markowa plyte (Verbatim) i zobacze. A nie uwazasz ze moja DVD-RW moze byc za stara? I jaka tania wypalarke polecasz (konkretnie do wypalania gier na X`a)? Z gory dzieki za odpowiedz.
Data rejestracji: 29.11.2003
Wyłącz w Imageburner opcje sprawdania zapisu lasera(otimal), nagrywarke zmien na NECA, i sprawdz system, podobne sytuace mjałem i ja. A płytki nie mają tu nic do powiedzenia. Jedyna sytuacja z płytkami to jest taka że jeśli wypalałęś na (-) to zmień na (+) , Xbox pracuje bardzo dobrże z plusami , to jest prawdopodobnie główna przyczyna.
#11 | |
Technik Informatyk
#12 | |
Słusznie.
Niewykluczone, niestety. Cytat:
#13 |
Jutro dam plyte kumplowi ktory wypalil juz mase gier na swojej wypalarce (Asus) i obadam co i jak. Dzieki za odpowiedzi. Pozdro.
#14 | |
Spamerzyna
Data rejestracji: 24.09.2006
#15 |
Grzesiu748, jeśli ww. autor tematu nie posiada napędu, do którego napisano specjalny fw, a nie chce rozbebeszać konsoli to niestety nie zrobi obrazu gry. IMO zasysanie z sieci w takich przypadkach jest etycznie ok. (a prawnie to nie wiem, pewnie nie, ale nadgorliwość ponoć gorsza od faszyzmu ;])
| AVI -> VCD [poradnik] | sc0rpi0 | DVD-Video | 282 | 28.11.2011 13:34 |
| Przykład jak mozna zarobic na naiwnosci ludzi | Ice | Off topic | 7 | 03.10.2005 01:41 |
| Teksty nauczycieli | Tribunal | Off topic | 47 | 11.04.2004 22:39 |
| jestesmy narodem wybranym ;D | mr_spock | Off topic | 3 | 03.11.2003 10:29 |
| 535 śmiesznych tekstów | mallow | Humor | 6 | 01.06.2003 16:49 |
